将HTTPS端口进行调整为88端口,将外网地址端口80转到内网服务器80端口不成功
<H3C>dis versionH3C Comware Software, Version 7.1.064, Release 0605P05Copyright (c) 2004-2017 Hangzhou H3C Tech. Co., Ltd. All rights reserved.H3C MSR830 uptime is 0 weeks, 1 day, 20 hours, 53 minutesLast reboot reason : Power onBoot image: flash:/msr830hi-cmw710-boot-r0605p05.binBoot image version: 7.1.064P34, Release 0605P05 Compiled Feb 07 2017 16:00:00System image: flash:/msr830hi-cmw710-system-r0605p05.binSystem image version: 7.1.064, Release 0605P05 Compiled Feb 07 2017 16:00:00Feature image(s) list: flash:/msr830hi-cmw710-security-r0605p05.bin, version: 7.1.064 Compiled Feb 07 2017 16:00:00 flash:/msr830hi-cmw710-voice-r0605p05.bin, version: 7.1.064 Compiled Feb 07 2017 16:00:00 flash:/msr830hi-cmw710-data-r0605p05.bin, version: 7.1.064 Compiled Feb 07 2017 16:00:00
CPU ID: 0xc1G bytes DDR3 SDRAM Memory10M bytes Flash MemoryPCB Version: 1.0CPLD Version: 0.0Basic BootWare Version: 1.01Extended BootWare Version: 1.01[SLOT 0]CON (Hardware)1.0, (Driver)1.0, (CPLD)0.0[SLOT 0]AUX (Hardware)1.0, (Driver)1.0, (CPLD)0.0[SLOT 0]GE0/0 (Hardware)1.0, (Driver)1.0, (CPLD)0.0[SLOT 0]GE0/1 (Hardware)1.0, (Driver)1.0, (CPLD)0.0[SLOT 0]GE0/2 (Hardware)1.0, (Driver)1.0, (CPLD)0.0[SLOT 0]GE0/3 (Hardware)1.0, (Driver)1.0, (CPLD)0.0[SLOT 0]GE0/4 (Hardware)1.0, (Driver)1.0, (CPLD)0.0[SLOT 0]GE0/5 (Hardware)1.0, (Driver)1.0, (CPLD)0.0[SLOT 0]GE0/6 (Hardware)1.0, (Driver)1.0, (CPLD)0.0[SLOT 0]GE0/7 (Hardware)1.0, (Driver)1.0, (CPLD)0.0[SLOT 0]GE0/8 (Hardware)1.0, (Driver)1.0, (CPLD)0.0[SLOT 0]GE0/9 (Hardware)1.0, (Driver)1.0, (CPLD)0.0[SLOT 0]CELLULAR0/0 (Hardware)1.0, (Driver)1.0, (CPLD)0.0 <H3C>
<H3C>dis cu# version 7.1.064, Release 0605P05# sysname H3C# telnet server enable# ip load-sharing mode per-flow src-ip global# nat static inbound 222.179.155.106 192.168.16.117 nat static outbound 192.168.16.117 222.179.155.106# dhcp enable dhcp server always-broadcast# dns proxy enable# password-recovery enable#vlan 1#controller Cellular0/0#interface Aux0 # interface Dialer0# interface Dialer1# interface Dialer2# interface Dialer3# interface Dialer4# interface Dialer5# interface Dialer6# interface Dialer7# interface Dialer8# interface Dialer1023# interface NULL0# interface Vlan-interface1 ip address 192.168.16.1 255.255.255.0 tcp mss 1280 undo dhcp select server# interface GigabitEthernet0/0 port link-mode route description Single_Line1 ip address 222.179.155.106 255.255.255.248 dns server 61.128.128.68 dns server 61.128.192.68 nat outbound nat server protocol tcp global 222.179.155.106 47 inside 192.168.16.117 47 nat server protocol tcp global 222.179.155.106 80 inside 192.168.16.117 80 nat server protocol tcp global 222.179.155.106 555 inside 192.168.16.117 555 nat server protocol tcp global 222.179.155.106 1723 inside 192.168.16.117 1723 nat server protocol tcp global 222.179.155.106 2002 inside 192.168.16.117 2002 nat server protocol tcp global 222.179.155.106 2017 inside 192.168.16.44 2017 nat static enable# interface GigabitEthernet0/1 port link-mode route# interface GigabitEthernet0/2 port link-mode route# interface GigabitEthernet0/3 port link-mode route combo enable copper# interface GigabitEthernet0/4 port link-mode bridge# interface GigabitEthernet0/5 port link-mode bridge# interface GigabitEthernet0/6 port link-mode bridge# interface GigabitEthernet0/7 port link-mode bridge# interface GigabitEthernet0/8 port link-mode bridge# interface GigabitEthernet0/9 port link-mode bridge# security-zone name Local# security-zone name Trust# security-zone name DMZ# security-zone name Untrust# security-zone name Management# scheduler logfile size 16# line class aux user-role network-operator# line class console user-role network-admin# line class tty user-role network-operator# line class vty user-role network-operator# line aux 0 authentication-mode none user-role network-admin# line con 0 user-role network-admin# line vty 0 63 authentication-mode scheme user-role network-operator# ip route-static 0.0.0.0 0 GigabitEthernet0/0 222.179.155.105# ssh server enable sftp server enable ssh server compatible-ssh1x enable scp server enable# domain system # domain default enable system# role name level-0 description Predefined level-0 role# role name level-1 description Predefined level-1 role# role name level-2 description Predefined level-2 role# role name level-3 description Predefined level-3 role# role name level-4 description Predefined level-4 role# role name level-5 description Predefined level-5 role# role name level-6 description Predefined level-6 role# role name level-7 description Predefined level-7 role# role name level-8 description Predefined level-8 role# role name level-9 description Predefined level-9 role# role name level-10 description Predefined level-10 role# role name level-11 description Predefined level-11 role# role name level-12 description Predefined level-12 role# role name level-13 description Predefined level-13 role# role name level-14 description Predefined level-14 role# user-group system# local-user admin class manage password hash $h$6$kZE1/qbWLOKcSmNM$S+ZPRZ8XYVZ4ZDjjeSrrsSf+PQgE/deh5ldhb8LeXg4V3FhhAEkDpeb7LGz4AnQj8eIbAbaP8cPsRYbrecUSYg== service-type telnet https authorization-attribute user-role network-admin# ip http port 88 ip https port 88 ip https enable# wlan global-configuration control-address disable# wlan ap-group default-group# cloud-management server domain oasis.h3c.com# return <H3C>
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
我将HTTP 关了
那可以抓包看一下nat是否转换正确
