H3C H5120-HI NTP无法同步
2017-06-28提问
  • 1收藏,3730浏览
H3C S5120-58C-HI Comware Software, Version 5.20, Release 5501P31无法同步时钟。内部可以Ping通NTP server,没有ntp-serivce enable命令,配置如下:
<SW2>dis cur | in ntp
 ntp-service source-interface Vlan-interface10
 ntp-service unicast-server 218.75.4.130
 ntp-service unicast-server 202.112.31.197
 ntp-service unicast-server 202.112.29.82
<SW2>dis cur int vl 10
 ip address 10.0.20.1 255.255.255.0
 ip address 10.0.253.1 255.255.255.248 sub
return
<SW2>ping -a 10.0.20.1 218.75.4.130
  PING 218.75.4.130: 56  data bytes, press CTRL_C to break
    Reply from 218.75.4.130: bytes=56 Sequence=1 ttl=53 time=51 ms
    Reply from 218.75.4.130: bytes=56 Sequence=2 ttl=53 time=43 ms
    Reply from 218.75.4.130: bytes=56 Sequence=3 ttl=53 time=44 ms
    Reply from 218.75.4.130: bytes=56 Sequence=4 ttl=53 time=46 ms
    Reply from 218.75.4.130: bytes=56 Sequence=5 ttl=53 time=43 ms
  --- 218.75.4.130 ping statistics ---
    5 packet(s) transmitted
    5 packet(s) received
    0.00% packet loss
    round-trip min/avg/max = 43/45/51 ms
<SW2>ping -a 10.0.20.1 -c 2 202.112.31.197
  PING 202.112.31.197: 56  data bytes, press CTRL_C to break
    Reply from 202.112.31.197: bytes=56 Sequence=1 ttl=46 time=36 ms
    Reply from 202.112.31.197: bytes=56 Sequence=2 ttl=46 time=23 ms
  --- 202.112.31.197 ping statistics ---
    2 packet(s) transmitted
    2 packet(s) received
    0.00% packet loss
    round-trip min/avg/max = 23/29/36 ms
<SW2>dis ntp stat
<SW2>dis ntp status
 Clock status: unsynchronized
 Clock stratum: 16
 Reference clock ID: none
 Nominal frequency: 100.0000 Hz
 Actual frequency: 100.0000 Hz
 Clock precision: 2^18
 Clock offset: 0.0000 ms
 Root delay: 0.00 ms
 Root dispersion: 0.00 ms
 Peer dispersion: 0.00 ms
 Reference time: 00:00:00.000 UTC Jan 1 1900(00000000.00000000)
<SW2>
zhiliao_97881 知了小白
谢谢,换了个时间服务器好了。就是晕了,我一直用的这几个服务器都挺好用的
粉丝:2人 关注:0人
S5120-HI V5版本的NTP配置不需要配置ntp-serivce enable,指定ntp server地址即可。时间同步不成功可以确认下是不是版本的原因,默认版本为version 3。
