MSR26-00路由器命令设置
2017-06-29提问
  • 1收藏,5926浏览
change 零段
各位大神,我这里有台MSR26-00,具体是这样的,因为公司财务部需要1条专线,而我们公司刚好有2条外线,但是我们公司内部有NAS需要共享文件,如果财务分出去,访问NAS会比较麻烦,于是我的想法是路由接双线,然后在路由上分2个Vlan,非财务部的走192.168.0.0 255.255.255.0网段,财务部走10.0.0.0 255.255.255.0网段,非财务部是VLan1,财务部设置为Vlan 2,然后Vlan 1走1条外线,Vlan 2走另外1条外线,并且设置VLan 1和Vlan 2之间可以互相访问数据,但是由于本人不懂H3C命令的配置方式,就咨询了H3C技术,他给了一段命令我参考,本人之前曾经学过CISCO路由交换机命令的设置,对命令配置还是有点知晓,但是大部分已经交回给老师了,所以想请教下大神们,应该怎么设置路由,并且需要输入那些命令,之前本人配置过的一些命令我也想删了重新配,现在只删了ACL几条规则,不知道怎么删policy-based-route aaa\bbb permit node 5这2条命令,反正现在怎么人都懵逼了,望大神搭救,谢谢
这是我路由现在的状态 version 5.20, Release 2513P21
 sysname H3C
 clock timezone Beijing add 08:00:00
 undo nat alg all
 domain default enable system
 dns resolve
 dns proxy enable
 telnet server enable
 dar p2p signature-file flash:/p2p_default.mtd
 qos carl 1 destination-ip-address range 192.168.0.121 to 192.168.0.199 per-address shared-bandwidth
 password-recovery enable
vlan 1
vlan 2
domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
dhcp server ip-pool vlan1 extended
 network ip range 192.168.0.121 192.168.0.199
 network mask 255.255.255.0
 gateway-list 192.168.0.1
 dns-list 192.168.0.1
dhcp server ip-pool vlan2 extended
policy-based-route aaa permit node 5
 if-match acl 3100
 apply ip-address next-hop 121.32.137.61
policy-based-route bbb permit node 5
 if-match acl 3200
 apply ip-address next-hop 183.6.135.42
user-group system
 group-attribute allow-guest
local-user admin
 password cipher $c$3$niKWDKX5i+j5vUmWHpmmSFcv0pXEues4
 authorization-attribute level 3
 service-type telnet
 service-type web
cwmp
 undo cwmp enable
interface Aux0
 async mode flow
 link-protocol ppp
interface Cellular0/0
 async mode protocol
 link-protocol ppp
interface NULL0
interface Vlan-interface1
 ip address 192.168.0.1 255.255.255.0
 dhcp server apply ip-pool vlan1
 ip flow-ordering internal
interface Vlan-interface2
 ip address 10.0.0.1 255.255.255.0
 undo dhcp select server global-pool
 dhcp server apply ip-pool vlan2
 ip policy-based-route aaa
interface GigabitEthernet0/0
 port link-mode route
 nat outbound
 shutdown
 ip address 121.32.137.61 255.255.255.0
 dns server 202.96.128.166
 dns server 202.96.134.133
interface GigabitEthernet0/1
 nat outbound
 nat server 1 protocol tcp global current-interface 9090 inside 192.168.0.218 9090
 nat server 2 protocol tcp global current-interface 3389 inside 192.168.0.218 3389
 nat server 3 protocol tcp global current-interface 5000 inside 192.168.0.252 5000
 mtu 1460
 ip address 183.6.135.42 255.255.255.0
 tcp mss 1360
 qos car inbound carl 1 cir 5000 cbs 18750 ebs 0 green pass red discard
 dns server 202.96.128.86
 ip flow-ordering external
interface GigabitEthernet0/2
 port link-mode bridge
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
voice-setup
 sip
 sip-server
  call-rule-set
  call-route
 dial-program
 aaa-client
 gk-client
 ip route-static 0.0.0.0 0.0.0.0 GigabitEthernet0/1 183.6.135.41
 ip route-static 0.0.0.0 0.0.0.0 GigabitEthernet0/0 121.32.137.1
 dhcp enable
 nms primary monitor-interface GigabitEthernet0/0
 ip flow-ordering stat-interval 10
 load xml-configuration
 load tr069-configuration
user-interface tty 12
user-interface aux 0
user-interface vty 0 4
 authentication-mode scheme
return
而这是H3C工程师给我的命令参考,我已经把里面的地址改成自己的地址
display current-configuration
sys
acl   num  3100           //匹配0.0.0网段的地址
rule  permit  ip  source 10.0.0.0 255.255.255.0  //匹配0.0.0网段的地址
int e0/0
ip add   121.32.137.61 255.255.255.0
nat  outbound
int e0/1
ip  add 183.6.135.42 255.255.255.248
nat  outbound
if-match  acl  3100
apply ip-address next-hop   121.32.137.61        //让0.0.0段从1口上网
int  vlan  2
ip  route-static  0.0.0.0  0  183.6.135.42                   //其他地址从0口上网
ip  route-static  0.0.0.0  0  121.32.137.61   preference  70       //如果1口down了,则让1口从0口上网
jlubao 五段
粉丝:5人 关注:3人
其实,H3C配置起来很简单,看官网手册中典型配置举例就行,在相对应视图下,使用undo命令删除配置,
policy-based-route这个我用undo也删不了
change 发表时间:2017-06-29
zhiliao_CLp4u 知了小白
楼主 请问你这样配完后两个内网网段通吗?
zhiliao_rwms6 知了小白
dhcp server ip-pool vlan2 extended  你没配置呀
