System is starting... Press Ctrl+D to access BASIC-BOOTWARE MENU... Booting Normal Extended BootWare The Extended BootWare is self-decompressing................................. ......Done. System is starting... Press Ctrl+D to access BASIC-BOOTWARE MENU... Booting Normal Extended BootWare The Extended BootWare is self-decompressing................................. ......Done. System is starting... Press Ctrl+D to access BASIC-BOOTWARE MENU... Booting Normal Extended BootWare The Extended BootWare is self-decompressing................................. ......Done. System is starting... Press Ctrl+D to access BASIC-BOOTWARE MENU... Booting Normal Extended BootWare The Extended BootWare is self-decompressing................................. ......Done. System is starting... Press Ctrl+D to access BASIC-BOOTWARE MENU... Booting Normal Extended BootWare The Extended BootWare is self-decompressing................................. ......Done. System is starting... Press Ctrl+D to access BASIC-BOOTWARE MENU... Booting Normal Extended BootWare The Extended BootWare is self-decompressing................................. ......Done. System is starting... Press Ctrl+D to access BASIC-BOOTWARE MENU... Booting Normal Extended BootWare The Extended BootWare is self-decompressing................................. ......Done.
在终端里面看一直不停的重复这个提示,是设备坏了吗》?
(0)
1、这个是设备加载系统版本的提示,是正常现象。
2、如果频繁反复出现,且无法进入系统,则是不正常现象。
3、可能是系统版本文件损坏了,可尝试重新导入一个新的软件版本再看下是否能正常启动。
4、以下是WX2540H的下载链接:
https://www.h3c.com/cn/Service/Document_Software/Software_Download/IP_Wlan/Enterprise_Series/H3C_WX2500H/
用户名:yx800
密码:01230123
注意阅读版本说明书,特别注意适配的那一部分。
(1)
这个是不停重复的提示,断电重启试过了,RESET长按也试过了,还是提示这个!~
=====================<BASIC-BOOTWARE MENU (Ver 5.06) >====================== |<1> Modify Serial Interface Parameter | |<2> Update Extended BootWare | |<3> Update Full BootWare | |<4> Boot Extended BootWare | |<5> Boot Backup Extended BootWare | |<0> Reboot | ============================================================================ Ctrl+U: Access BASIC ASSISTANT MENU Enter your choice(0-5):
这个能刷固件吗?
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
电源适配器非原装,电压不足导致的,谢谢!~
