H3C S5600交换机如何配置镜像流量?
(0)
· Device A通过端口GigabitEthernet1/0/1和GigabitEthernet1/0/2分别连接市场部和技术部,并通过端口GigabitEthernet1/0/3连接Server。
· 通过配置源端口方式的本地端口镜像,使Server可以监控所有进、出市场部和技术部的报文。
图1-2 本地端口镜像配置组网图
(1) 配置本地镜像组
# 创建本地镜像组1。
[DeviceA] mirroring-group 1 local
# 配置本地镜像组1的源端口为GigabitEthernet1/0/1和GigabitEthernet1/0/2,目的端口为GigabitEthernet1/0/3。
[DeviceA] mirroring-group 1 mirroring-port gigabitethernet 1/0/1 gigabitethernet 1/0/2 both
[DeviceA] mirroring-group 1 monitor-port gigabitethernet 1/0/3
# 在目的端口GigabitEthernet1/0/3上关闭生成树协议。
[DeviceA-GigabitEthernet1/0/3] undo stp enable
(2) 检验配置效果
# 显示所有镜像组的配置信息。
[DeviceA] display mirroring-group all
mirroring-group 1:
type: local
status: active
mirroring port:
GigabitEthernet1/0/1 both
GigabitEthernet1/0/2 both
monitor port: GigabitEthernet1/0/3
配置完成后,用户可以通过Server监控所有进、出市场部和技术部的报文。
详细内容可参考https://www.h3c.com/cn/d_201910/1235164_30005_0.htm#_Toc357157638
(0)
1、以下是交换机本地端口镜像的典型配置,请参考:
<H3C>sys
[H3C]sysname SW1
[SW1]mirroring-group 1 local //创建本地镜像组、组号为1
[SW1]mirroring-group 1 mirroring-port GigabitEthernet 1/0/2 both //指定镜像口,监控进出流量
[SW1]mirroring-group 1 monitor-port GigabitEthernet 1/0/1 //指定监控口
[SW1]dis mirroring-group all //查看镜像组信息
Mirroring group 1:
Type: Local //本地镜像
Status: Active //镜像状态为激活
Mirroring port:
GigabitEthernet1/0/2 Both
Monitor port: GigabitEthernet1/0/1
2、以下是交换机远程端口镜像
的典型组网配置过程,请参考:
<SW1>system-view
[SW1]vlan 999 //创建VLAN999,将用于remote-vlan
[SW1-vlan999]quit
[SW1]mirroring-group 1 remote-source //创建镜像组1,指定为远程源镜像组
[SW1]mirroring-group 1 mirroring-port GigabitEthernet 1/0/2 both //指定镜像口,镜像进出流量
[SW1]mirroring-group 1 remote-probe vlan 999 //指定remote-vlan
[SW1]mirroring-group 1 reflector-port GigabitEthernet 1/0/5 //指定反射口
This operation may delete all settings made on the interface. Continue? [Y/N]: y //指定反射口时,会提示该端口的配置会全部被删除,是否要继续,选择Y
[SW1]int ran gi 1/0/1 gi 1/0/4 //将监控设备接入的端口都划分到remote-vlan中,相当于指定为监控口
[SW1-if-range]port link-type access
[SW1-if-range]port access vlan 999
[SW1-if-range]quit
[SW1]dis mirroring-group all //查看镜像组状态
Mirroring group 1:
Type: Remote source //镜像组类型为远程源镜像组
Status: Active //镜像组状态为激活
Mirroring port:
Reflector port: GigabitEthernet1/0/5
Remote probe VLAN: 999
3、以下是交换机流镜像的典型配置过程,请参考:
<H3C>sys
[H3C]sysname SW1
#创建ACL
[SW1]acl basic 2000
[SW1-acl-ipv4-basic-2000]rule 0 permit source any
[SW1-acl-ipv4-basic-2000]quit
[SW1]
#创建QOS流,绑定ACL
[SW1]traffic classifier 1
[SW1-classifier-1]if-match acl 2000
[SW1-classifier-1]quit
#创建QOS行为,指定流镜像目的端口
[SW1]traffic behavior 1
[SW1-behavior-1]mirror-to interface GigabitEthernet 1/0/1
[SW1-behavior-1]quit
#创建QOS策略,绑定QOS流和行为
[SW1]qos policy 1
[SW1-qospolicy-1]classifier 1 behavior 1
[SW1-qospolicy-1]quit
#将QOS策略下发到端口,该端口将为镜像口
[SW1]int gi 1/0/2
[SW1-GigabitEthernet1/0/2]qos apply policy 1 outbound
[SW1-GigabitEthernet1/0/2]quit
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
感谢大哥 待我测试下,么么哒
