H3C SecPath F100-S flash文件格式化了,system.bin文件没有了
2020-07-12提问
  • 1收藏,1103浏览
粉丝: 关注:
H3C SecPath F100-S flash文件格式化了,system.bin文件没有了,哪位老师给提供一下呀,先谢谢了
https://www.h3c.com/cn/Service/Document_Software/Software_Download/IP_Security/FW/Comware_V7/
确认一下您的具体型号,从这个链接进去下载版本即可
粉丝:124人 关注:6人
F100-S的型号有好几种,请根据如下链接去查询并下载:
https://www.h3c.com/cn/Service/Document_Software/Software_Download/IP_Security/FW/Comware_V7/H3C_SecPath_F1000-AK125_F1000-AK115/
https://www.h3c.com/cn/Service/Document_Software/Software_Download/IP_Security/FW/Comware_V7/H3C_SecPath_F1000-AK120_F1000-AK108/
用户名:yx800
密码:01230123
请阅读版本说明书后下载,需注意适配的部分。
粉丝:6人 关注:1人
可以在华三官网进行下载:https://www.h3c.com/cn/Service/Document_Software/Software_Download/IP_Security/FW/Comware_V7/H3C_SecPath_F1000-AK125_F1000-AK115/
通用账号/密码:yx800/01230123
具体升级操作步骤参考:
1. 进入BootWare菜单
(1)      设备上电和重新启动的过程中,在配置终端的屏幕上首先将显示
System is starting...
Press Ctrl+D to access BASIC-BOOTWARE MENU...
Press Ctrl+T to start heavy memory test
Booting Normal Extended BootWare
The Extended BootWare is self-decompressing.....Done.
*                   H3C SecPath BootWare, Version 1.02                     *
Copyright (c) 2004-2016 New H3C Technologies Co., Ltd.
Compiled Date       : Jan 14 2016
Memory Type         : DDR3 SDRAM
Memory Size         : 2048MB
Memory Speed        : 667MHz
Flash Size          : 16MB
Nandflash Size      : 256MB
PCB Version         : Ver.A
BootWare Validating...
Press Ctrl+B to access EXTENDED-BOOTWARE MENU...
(2)      当出现“Press Ctrl+B to enter extended boot menu...”时,立即键入<Ctrl+B>,按下<Enter>后,系统将进入BootWare主菜单
在显示信息中可以查看是否使能密码恢复功能。
表7 显示信息描述表
显示信息
Password recovery capability is enabled.
密码恢复功能处于开启状态
Password recovery capability is disabled.
密码恢复功能处于关闭状态
Note: The current operating device is flash
Enter < Storage Device Operation > to select device.
===========================<EXTENDED-BOOTWARE MENU>===========================
|<1> Boot System                                                           |
|<2> Enter Serial SubMenu                                                  |
|<3> Enter Ethernet SubMenu                                                |
|<4> File Control                                                          |
|<5> Restore to Factory Default Configuration                              |
|<6> Skip Current System Configuration                                     |
|<7> BootWare Operation Menu                                               |
|<8> Skip Authentication for Console Login                                 |
|<9> Storage Device Operation                                              |
|<0> Reboot        |
Ctrl+Z: Access EXTENDED-ASSISTANT MENU
Ctrl+C: Display Copyright
Ctrl+F: Format File System
Enter your choice(0-9):
该菜单含义如下:
表8 BootWare主菜单
菜单项
<1> Boot System
引导启动文件
进入串口子菜单。子菜单详细描述请参见11
进入以太网口子菜单。子菜单详细描述请参见9
<4> File Control
文件控制子菜单。子菜单详细描述请参见15
恢复到出厂配置状态
警告
·          该功能仅在密码恢复功能处于关闭状态下执行有效
·          执行该功能后,系统将删除用户当前使用的配置文件,并且以空配置启动。请谨慎使用该功能
跳过当前配置进行启动,只是本次生效。该功能一般在用户丢失口令之后使用
该功能仅在密码恢复功能处于开启状态下执行有效
BootWare操作子菜单,用于BootWare程序操作
跳过Console口认证登录进行启动,只是本次生效。该功能一般在丢失Console口口令之后使用
存储设备控制菜单,用于存储设备的选择
<0> Reboot
重新启动设备
可以使用命令password-recovery enable开启密码恢复功能,用命令undo password-recovery enable关闭密码恢复功能。
2. 通过以太网口利用TFTP/FTP升级启动文件
(1)      BootWare主菜单下键入<3>,可以进入以太网口子菜单,系统显示如下:
==========================<Enter Ethernet SubMenu>==========================
|Note:the operating device is flash                                        |
|<1> Download Image Program To SDRAM And Run                               |
|<2> Update Main Image File                                                |
|<3> Update Backup Image File                                              |
|<4> Download Files(*.*)                                                   |
|<5> Modify Ethernet Parameter                                             |
|<0> Exit To Main Menu                                                     |
|<Ensure The Parameter Be Modified Before Downloading!>                    |
Enter your choice(0-5):
以太网口子菜单中各选项解释如下:
表9 以太网口子菜单
菜单项
通过以太网接口下载启动文件到内存并启动
升级主启动文件
升级备用启动文件
将文件服务器上文件下载到设备
修改以太网接口参数
返回BootWare主菜单
(2)      键入<5>进入以太网口配置菜单
==========================<ETHERNET PARAMETER SET>==========================
|Note:       '.' = Clear field.                                            |
|             '-' = Go to previous field.                                  |
|          Ctrl+D = Quit.                                                  |
Protocol (FTP or TFTP) :tftp
Load File Name         : F1010.ipe
Target File Name       : F1010.ipe
Server IP Address      :192.168.0.2
Local IP Address       :192.168.0.1
Subnet Mask            :0.0.0.0
Gateway IP Address     :0.0.0.0
表10 以太网参数设置说明
显示
'.' = Clear field
快捷键:“.”表示清除当前输入
快捷键:“-”表示返回到前一个参数域
Ctrl+D = Quit
快捷键:表示退出参数配置界面
使用的传输协议,可以为FTP或者TFTP
Load File Name
下载文件名,要与下载的实际文件名一致
Target File Name
下载到设备后的目标文件名。缺省情况下与下载文件名一致
Server IP Address
TFTP/FTP服务器的IP地址
Local IP Address
本地IP地址,为TFTP/FTP客户端设置的IP地址,即设备用于升级的以太网口的地址
Gateway IP Address
网关IP地址,当与服务器不在同一网段时需要配置网关地址
(3)      以升级主启动文件为例,在以太网口子菜单键入<2>
Loading.....................................................................
......................................Done.
62160896 bytes downloaded!
Image file f1010fw-cmw710-boot-E9503.bin is self-decompressing...
Saving file flash:/f1010fw-cmw710-boot-E9503.bin ...........................
...........Done.
Image file f1010fw-cmw710-system-E9503.bin is self-decompressing...
Saving file flash:/f1010fw-cmw710-system-E9503.bin .........................
......... ..Done.
当设备上有重名的文件存在时,将提示The file already exists,Overwrite it? [Y/N]”当选择Y时,会覆盖设备上重名的文件;当选择N时,将提示“Cancel to overwrite the file.”。
(4)      选择<0>,返回BootWare主菜单。再选择<1>,引导系统。
