华三F1000-S-AI 端口映射问题
2017-07-06提问
  • 1收藏,4264浏览
仁未 零段
这是配置  能帮我看下 不合适的地方
[f1000]dis current-configuration
 version 5.20, Release 3721P01
 sysname f1000
 undo voice vlan mac-address 00e0-bb00-0000
 domain default enable system
 dns server 218.203.160.194
 telnet server enable
acl number 3001
 rule 1 permit ip source 192.168.10.0 0.0.0.255
 rule 2 permit ip source 192.168.20.0 0.0.0.255
 rule 3 permit ip source 192.168.30.0 0.0.0.255
 rule 5 permit gre
vlan 1
domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
pki domain default
  crl check disable
user-group system
 group-attribute allow-guest
local-user admin
 password cipher $c$3$tQxW8dwiSyTR+ec0Ov/KnEyP+wh9XH0yZ9/8ew==
 authorization-attribute level 3
 service-type telnet
 service-type web
interface NULL0
interface Vlan-interface1
interface GigabitEthernet0/0
 port link-mode route
 ip address 192.168.0.1 255.255.255.0
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
 ip address 200.100.1.254 255.255.255.0
interface GigabitEthernet0/11
 nat outbound 3001
 nat server protocol tcp global 117.156.51.138 pptp inside 192.168.20.253 pptp
 nat server protocol tcp global 117.156.51.138 443 inside 192.168.20.253 443
 nat server protocol tcp global 117.156.51.138 2103 inside 192.168.30.227 www
 nat server protocol tcp global 117.156.51.138 2105 inside 192.168.30.227 8080
 ip address 117.156.51.138 255.255.255.252
nqa entry imclinktopologypleaseignore ping
 type icmp-echo
  destination ip 200.100.1.252
  frequency 270000
 ip route-static 0.0.0.0 0.0.0.0 117.156.51.137
 ip route-static 192.168.0.0 255.255.0.0 200.100.1.1
 snmp-agent
 snmp-agent local-engineid 800063A20374258A37FDF5
 snmp-agent community read public
 snmp-agent community write private
 snmp-agent sys-info version all
 nqa schedule imclinktopologypleaseignore ping start-time now lifetime 630720000
 load xml-configuration
user-interface con 0
user-interface vty 0 4
 authentication-mode scheme
粉丝:15人 关注:4人
接口安全区域以及域间策略的信息没有体现。
现在是怎么修改
仁未 发表时间:2017-07-06
现在是这样的 20.253 的全部映射成功 30.227 新加的 映射失败
仁未 发表时间:2017-07-06
WEB上的安全域基于域间策略配置截一下。
⁶⁶66⁶⁶⁶⁶ 发表时间:2017-07-06
web 等不进去 我现在远程等的
仁未 发表时间:2017-07-06
回复仁未:
客户端测试的时候,display session table source-ip 客户端地址 destination-ip 117.156.51.138 destination-port 2103 verbose 看看有没有会话
没有 会话
仁未 发表时间:2017-07-06
回复仁未:
没有会话有两种可能:1.报文没有到防火墙;2.报文到达防火墙,但是域间策略没有放通
谢谢 这个能ping通 域间策略是放通的吧
仁未 发表时间:2017-07-06
回复仁未:
到本地的报文和设备转发的报文不同,建议通过400-810-0504电话沟通一下
谢谢 好了 域间策略没放通 现在内网通过访问公网IP 是用不了 该怎么操作
仁未 发表时间:2017-07-06
回复仁未:
http://kms.h3c.com/View.aspx?id=29264
这是有啥需求?就是想外网通过nat server访问内网服务器?那这个配置没啥问题
对 外网通过nat server 访问内网服务器 现在外网访问不进去
仁未 发表时间:2017-07-06
