这是配置 能帮我看下 不合适的地方
[f1000]dis current-configuration
version 5.20, Release 3721P01
sysname f1000
undo voice vlan mac-address 00e0-bb00-0000
domain default enable system
dns server 218.203.160.194
telnet server enable
acl number 3001
rule 1 permit ip source 192.168.10.0 0.0.0.255
rule 2 permit ip source 192.168.20.0 0.0.0.255
rule 3 permit ip source 192.168.30.0 0.0.0.255
rule 5 permit gre
vlan 1
domain system
access-limit disable
state active
idle-cut disable
self-service-url disable
pki domain default
crl check disable
user-group system
group-attribute allow-guest
local-user admin
password cipher $c$3$tQxW8dwiSyTR+ec0Ov/KnEyP+wh9XH0yZ9/8ew==
authorization-attribute level 3
service-type telnet
service-type web
interface NULL0
interface Vlan-interface1
interface GigabitEthernet0/0
port link-mode route
ip address 192.168.0.1 255.255.255.0
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
ip address 200.100.1.254 255.255.255.0
interface GigabitEthernet0/11
nat outbound 3001
nat server protocol tcp global 117.156.51.138 pptp inside 192.168.20.253 pptp
nat server protocol tcp global 117.156.51.138 443 inside 192.168.20.253 443
nat server protocol tcp global 117.156.51.138 2103 inside 192.168.30.227 www
nat server protocol tcp global 117.156.51.138 2105 inside 192.168.30.227 8080
ip address 117.156.51.138 255.255.255.252
nqa entry imclinktopologypleaseignore ping
type icmp-echo
destination ip 200.100.1.252
frequency 270000
ip route-static 0.0.0.0 0.0.0.0 117.156.51.137
ip route-static 192.168.0.0 255.255.0.0 200.100.1.1
snmp-agent
snmp-agent local-engineid 800063A20374258A37FDF5
snmp-agent community read public
snmp-agent community write private
snmp-agent sys-info version all
nqa schedule imclinktopologypleaseignore ping start-time now lifetime 630720000
load xml-configuration
user-interface con 0
user-interface vty 0 4
authentication-mode scheme
(0)
这是有啥需求?就是想外网通过nat server访问内网服务器?那这个配置没啥问题
(0)
对 外网通过nat server 访问内网服务器 现在外网访问不进去
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
现在是怎么修改
现在是这样的 20.253 的全部映射成功 30.227 新加的 映射失败
WEB上的安全域基于域间策略配置截一下。
web 等不进去 我现在远程等的
客户端测试的时候,display session table source-ip 客户端地址 destination-ip 117.156.51.138 destination-port 2103 verbose 看看有没有会话
没有 会话
没有会话有两种可能:1.报文没有到防火墙;2.报文到达防火墙,但是域间策略没有放通
谢谢 这个能ping通 域间策略是放通的吧
到本地的报文和设备转发的报文不同,建议通过400-810-0504电话沟通一下
谢谢 好了 域间策略没放通 现在内网通过访问公网IP 是用不了 该怎么操作
http://kms.h3c.com/View.aspx?id=29264
