HP RX9800小型机换盘问题
2020-07-29提问
  • 1收藏,1898浏览
设置列表 有序列表 无序列表对齐方式 靠左 居中 靠右 HP RX9800小型机共有两块硬盘,前面板一块硬盘橙色灯闪烁查看系统日志显示磁盘故障,查看小型机做的是raid1,这样可以直接热拔插跟换新的硬盘吗? 系统日志信息: Jul  4 01:26:57 ahydjsdb1 vmunix: CISS: RAID SA controller on hardware path 0/0/0/2/0/0/0 has predicted a physicalJul  4 01:26:57 ahydjsdb1 vmunix:       disk failure:Jul  4 01:26:57 ahydjsdb1 vmunix:       Connector: 1IJul  4 01:26:57 ahydjsdb1 vmunix:       Enclosure: 1Jul  4 01:26:57 ahydjsdb1 vmunix:       Bay: 1Jul  4 01:26:57 ahydjsdb1 vmunix:       WWID: 0x5000c5005fae7489Jul  4 01:26:57 ahydjsdb1 vmunix:       Failure Reason: S.M.A.R.T. ERROR REPORTEDJul  4 01:26:57 ahydjsdb1 vmunix:       Configured: NoJul  4 01:26:57 ahydjsdb1 vmunix:       Hot Spare:  NoJul  4 01:26:57 ahydjsdb1 vmunix: 255/1 mass_storageJul  4 01:26:57 ahydjsdb1 vmunix: 255/1/0 usb_ms_scsiRAID信息:ahydjsdb1#[/]sautil /dev/ciss0 ****************************************************************************** **** **** **** S A U T I L S u p p o r t U t i l i t y **** **** **** **** for the HP SmartArray RAID Controller Family **** **** **** **** version A.02.21 **** **** **** **** (C) Copyright 2003-2010 Hewlett-Packard Development Company, L.P. **** ****************************************************************************** ---- DRIVER INFORMATION ------------------------------------------------------ Driver State........................ READY ---- CONTROLLER INFORMATION -------------------------------------------------- Controller Product Number........... P410i Controller Product Name............. HP PCIe SmartArray P410i Controller mode..................... RAID MODE Hardware Path....................... 0/0/0/2/0/0/0 Serial Number....................... 500143802664CF40 Device File......................... /dev/ciss0 Hardware Revision................... 'C' Boot Block Revision................. 2.31 Firmware Revision (running)......... 5.84 Firmware Revision (in ROM).......... 5.84 Firmware Revision (inactive)........ 5.84 # of Logical Drives................. 1 # of Physical Disks Configured...... 2 # of Physical Disks Detected........ 2 Logical Drive Rebuild Priority...... 0 (low) Array Capacity Expansion Priority... 0 (low) Auto-Fail Missing Disks at Boot..... disabled SCSI Transfer Detection Mode........ Auto Detect Controller Path Selection Method.... default Max # of Logical Drives............. 64 Last firmware lockup................ 0 ---- ARRAY ACCELERATOR (CACHE) INFORMATION ----------------------------------- Array Accelerator Board Present?.... yes Cache Configuration Status.......... cache enabled Cache Ratio......................... 100% Read / 0% Write Total Cache Size (MB)............... 400 Read Cache........................ 400 Write Cache....................... 000 Transfer Buffer................... 000 Battery Pack Count.................. 0 ---- LOGICAL DRIVE SUMMARY --------------------------------------------------- # RAID Size Status 0 1+0 286063 MB OK ---- SAS/SATA DEVICE SUMMARY ------------------------------------------------- Location Ct Enc Bay WWID Type Capacity Status internal 1I 1 1 0x5000c5005fae7489 DISK 300.0 GB OK internal 1I 1 2 0x5000c5005fae969d DISK 300.0 GB OK ---- SAS/SATA ENCLOSURE SUMMARY ---------------------------------------------- Location Ct Enc Expander_count Bay_count SEP_count internal 1I 1 0 2 1 ---- LOGICAL DRIVE 0 --------------------------------------------------------- Logical Drive Device File........... /dev/dsk/c0t0d0 Fault Tolerance Mode................ RAID 1+0 (Disk Mirroring) Logical Drive Size.................. 286063 MB Logical Drive Status................ OK # of Participating Physical Disks... 2 Participating Physical Disk(s)...... Ct:Enc:Bay:WWID 1I:1:1:0x5000c5005fae7489 1I:1:2:0x5000c5005fae969d Participating Spare Disk(s)......... Ct:Enc:Bay:WWID none Stripe Size......................... 128 KB Logical Drive Cache Status.......... cache enabled Configuration Signature............. 0xA17EC473 Media Exchange Detected?............ no ---- SAS/SATA DEVICE 1I:1:1:0x5000c5005fae7489 [DISK] ------------------------ Connector Location............................... internal Connector........................................ 1I Enclosure........................................ 1 Bay.............................................. 1 WWID............................................. 0x5000c5005fae7489 Disk WWID........................................ 0x5000c5005fae748b Device Type...................................... DISK Disk Capacity.................................... 300.0 GB Device Status.................................... OK Device Vendor ID................................. HP Device Product ID................................ EH0300FBQDD Device Serial Number............................. 6XN3DQ5P0000B335AP8E Device Firmware Version.......................... HPD3 Reserved Area (cfg/status info).................. 33554.4 KB (33.6 MB) Block Size (bytes/sector)........................ 512 bytes M&P Data Stamped?................................ yes Last Failure Reason.............................. REMOVED IN HOT PLUG Media Type....................................... HDD Physical Disk Flags: Disk present and operational................... yes Non-disk device detected....................... no S.M.A.R.T. supported........................... yes S.M.A.R.T. errors (in factory M&P data)........ yes S.M.A.R.T. enabled............................. yes S.M.A.R.T. errors (in powerup M&P data)........ yes Attached to external connector................. no Configured in a logical drive.................. yes Configured as a spare disk..................... no Disk write cache enabled at spin up............ no Supports redundant controller operation........ yes Disk write cache enabled in current page....... no Disk write cache disabled in default page...... yes ---- SAS/SATA DEVICE 1I:1:2:0x5000c5005fae969d [DISK] ------------------------ Connector Location............................... internal Connector........................................ 1I Enclosure........................................ 1 Bay.............................................. 2 WWID............................................. 0x5000c5005fae969d Disk WWID........................................ 0x5000c5005fae969f Device Type...................................... DISK Disk Capacity.................................... 300.0 GB Device Status.................................... OK Device Vendor ID................................. HP Device Product ID................................ EH0300FBQDD Device Serial Number............................. 6XN3DPPB0000M335SAJ8 Device Firmware Version.......................... HPD3 Reserved Area (cfg/status info).................. 33554.4 KB (33.6 MB) Block Size (bytes/sector)........................ 512 bytes M&P Data Stamped?................................ yes Last Failure Reason.............................. REMOVED IN HOT PLUG Media Type....................................... HDD Physical Disk Flags: Disk present and operational................... yes Non-disk device detected....................... no S.M.A.R.T. supported........................... yes S.M.A.R.T. errors (in factory M&P data)........ no S.M.A.R.T. enabled............................. yes S.M.A.R.T. errors (in powerup M&P data)........ no Attached to external connector................. no Configured in a logical drive.................. yes Configured as a spare disk..................... no Disk write cache enabled at spin up............ no Supports redundant controller operation........ yes Disk write cache enabled in current page....... no Disk write cache disabled in default page...... yes ---- SAS/SATA DEVICE :0:0:0x500143802664cf4f [SES] --------------------------- Connector Location............................... internal Connector........................................ Enclosure........................................ 0 Bay.............................................. 0 WWID............................................. 0x500143802664cf4f Device Type...................................... SES Device Vendor ID................................. PMCSIERA Device Product ID................................ SRC 8x6G Device Serial Number............................. Device Firmware Version.......................... RevC M&P Data Stamped?................................ no Last Failure Reason.............................. none ****************************************************************************** **** End of SAUTIL Output **** ******************************************************************************
Dieu 九段
粉丝:19人 关注:0人
建议硬件问题收集getsysinfo,拨打400 810 0504咨询和保修
