SecPath F100-C-G 某个子网策略路由外网后与其他子网不能互通
2017-07-11提问
  • 0收藏,1865浏览
ryoue 一段
粉丝:2人 关注:0人
SecPath F100-C-G 设备中划分了多个子网。GigabitEthernet0/0 和 GigabitEthernet0/1 端口分别
连接两个外网线路。GigabitEthernet0/4 端口 Trunk 模式下接三层交换机。GigabitEthernet0/1端
口为缺省的外网通道。现在将其中一个子网做策略路由从 GigabitEthernet0/0 端口访问外网后,发
现该子网无法访问其他子网了。请问如何设置才能保持原来子网间互通并且该子网正常策略路由?
谢谢!
5 个回答
ryoue 一段
粉丝:2人 关注:0人
不好意思,补充下,被策略路由的子网无法PING通其他网段,其他网段可以正常PING通该子网。
 version 5.20, Release 5142P02
 sysname H3C
 clock timezone Beijing add 08:00:00
 undo voice vlan mac-address 00e0-bb00-0000
 ike local-name firewalla
 interzone policy default by-priority
 nat address-group 1 192.168.90.74 192.168.90.78
 nat address-group 2 192.168.90.34 192.168.90.38
 domain default enable system
 dns resolve
 dns proxy enable
 dns server 218.85.157.99
 dns server 218.85.152.99
 telnet server enable
 ip ttl-expires enable
 ip unreachables enable
 link-aggregation load-sharing mode destination-ip source-ip
 qos carl 1 destination-ip-address subnet 192.168.77.94 27
 qos carl 2 destination-ip-address subnet 192.168.77.94 27 per-address
 qos carl 11 destination-ip-address subnet 192.168.78.126 26
 qos carl 12 destination-ip-address subnet 192.168.78.126 26 per-address
 qos carl 21 destination-ip-address subnet 192.168.79.126 25
 qos carl 22 destination-ip-address subnet 192.168.79.126 25 per-address
 qos carl 31 destination-ip-address subnet 192.168.80.78 29
 qos carl 32 destination-ip-address subnet 192.168.80.78 29 per-address
 qos carl 41 destination-ip-address subnet 192.168.82.126 25
 qos carl 42 destination-ip-address subnet 192.168.82.126 25 per-address
 qos carl 51 destination-ip-address subnet 192.168.84.126 26
 qos carl 52 destination-ip-address subnet 192.168.84.126 26 per-address
 qos carl 61 destination-ip-address subnet 192.168.87.94 27
 qos carl 62 destination-ip-address subnet 192.168.87.94 27 per-address
 qos carl 71 destination-ip-address subnet 192.168.88.126 25
 qos carl 72 destination-ip-address subnet 192.168.88.126 25 per-address
 qos carl 81 destination-ip-address subnet 192.168.91.126 25
 qos carl 82 destination-ip-address subnet 192.168.91.126 25 per-address
 port-security enable
 undo alg dns
 undo alg rtsp
 undo alg h323
 undo alg sip
 undo alg sqlnet
 undo alg pptp
 undo alg ils
 undo alg nbt
 undo alg msn
 undo alg qq
 undo alg tftp
 undo alg sccp
 undo alg gtp
session synchronization enable
 password-recovery enable
 blacklist enable
 blacklist ip 192.168.78.93
 blacklist ip 192.168.78.107
acl number 2001
 rule 1 permit source 192.168.83.74 0
 rule 2 deny source 192.168.83.64 0.0.0.15
 rule 5 permit source 192.168.76.72 0.0.0.7
 rule 10 permit source 192.168.87.64 0.0.0.31
 rule 15 permit source 192.168.78.64 0.0.0.63
 rule 30 deny source 192.168.81.64 0.0.0.31
 rule 35 permit source 192.168.182.0 0.0.0.127
 rule 45 permit source 192.168.84.64 0.0.0.31
 rule 50 permit source 192.168.75.0 0.0.0.15
 rule 55 permit source 192.168.77.64 0.0.0.31
 rule 60 permit source 192.168.79.0 0.0.0.127
acl number 2002
 rule 0 permit source 192.168.81.64 0.0.0.31
acl number 3531
 description VLAN 753 Subnet Other uplink ACL
 rule 0 permit ip source 192.168.77.64 0.0.0.31
acl number 3532
 description VLAN 753 Subnet Other downlink ACL
 rule 0 permit ip destination 192.168.77.64 0.0.0.31
acl number 3541
 description VLAN 754 Subnet Other uplink ACL
 rule 0 permit ip source 192.168.78.64 0.0.0.63
acl number 3542
 description VLAN 754 Subnet Other downlink ACL
 rule 0 permit ip destination 192.168.78.64 0.0.0.63
acl number 3551
 description VLAN 755 Subnet Other uplink ACL
 rule 0 permit ip source 192.168.79.0 0.0.0.127
acl number 3552
 description VLAN 755 Subnet Other downlink ACL
 rule 0 permit ip destination 192.168.79.0 0.0.0.127
acl number 3561
 description VLAN 756 Subnet Other uplink ACL
 rule 0 permit ip source 192.168.80.72 0.0.0.7
acl number 3562
 description VLAN 756 Subnet Other downlink ACL
 rule 0 permit ip destination 192.168.80.72 0.0.0.7
acl number 3571
 description VLAN 757 Subnet Other uplink ACL
 rule 0 permit ip source 192.168.81.64 0.0.0.31
acl number 3572
 description VLAN 757 Subnet Other downlink ACL
 rule 0 permit ip destination 192.168.81.64 0.0.0.31
acl number 3573
 description VLAN 757 Subnet Special uplink ACL
 rule 0 permit ip source 192.168.81.93 0
 rule 5 permit ip source 192.168.81.92 0
 rule 10 permit ip source 192.168.81.90 0
 rule 15 permit ip source 192.168.81.91 0
acl number 3574
 description VLAN 757 Subnet Special downlink ACL
 rule 0 permit ip destination 192.168.81.93 0
 rule 5 permit ip destination 192.168.81.92 0
 rule 10 permit ip destination 192.168.81.90 0
 rule 15 permit ip destination 192.168.81.91 0
acl number 3581
 description VLAN 758 Subnet Other uplink ACL
 rule 0 permit ip source 192.168.182.0 0.0.0.127
acl number 3582
 description VLAN 758 Subnet Other downlink ACL
 rule 0 permit ip destination 192.168.182.0 0.0.0.127
acl number 3591
 description VLAN 759 Subnet Other uplink ACL
 rule 0 permit ip source 192.168.83.64 0.0.0.15
acl number 3592
 description VLAN 759 Subnet Other downlink ACL
 rule 0 permit ip destination 192.168.83.64 0.0.0.15
acl number 3601
 description VLAN 760 Subnet Other uplink ACL
 rule 0 permit ip source 192.168.84.64 0.0.0.63
acl number 3602
 description VLAN 760 Subnet Other downlink ACL
 rule 0 permit ip destination 192.168.84.64 0.0.0.63
acl number 3631
 description VLAN 763 Subnet Other uplink ACL
 rule 0 permit ip source 192.168.87.64 0.0.0.31
acl number 3632
 description VLAN 763 Subnet Other downlink ACL
 rule 0 permit ip destination 192.168.87.64 0.0.0.31
acl number 3641
 description VLAN 764 Subnet Other uplink ACL
 rule 0 permit ip source 192.168.88.0 0.0.0.127
acl number 3642
 description VLAN 762 Subnet Other downlink ACL
 rule 0 permit ip destination 192.168.88.0 0.0.0.127
acl number 3651
 description VLAN 765 Subnet Other uplink ACL
 rule 0 permit ip source 192.168.91.0 0.0.0.127
acl number 3652
 description VLAN 765 Subnet Other downlink ACL
 rule 0 permit ip destination 192.168.91.0 0.0.0.127
acl number 3901
 rule 5 permit ip source 192.168.81.64 0.0.0.31
 rule 10 deny ip
acl number 3903
 rule 0 permit ip source 192.168.75.0 0.0.0.15
 rule 5 permit ip source 192.168.76.72 0.0.0.7
 rule 10 permit ip source 192.168.77.64 0.0.0.31
 rule 15 permit ip source 192.168.78.64 0.0.0.63
 rule 20 permit ip source 192.168.79.0 0.0.0.127
 rule 25 permit ip source 192.168.80.72 0.0.0.7
 rule 30 permit ip source 192.168.81.64 0.0.0.31
 rule 35 permit ip source 192.168.84.64 0.0.0.63
 rule 40 permit ip source 192.168.85.0 0.0.0.127
 rule 45 permit ip source 192.168.87.64 0.0.0.31
 rule 50 permit ip source 192.168.88.0 0.0.0.127
 rule 55 permit ip source 192.168.91.0 0.0.0.127
 rule 60 permit ip source 192.168.83.64 0.0.0.31
 rule 70 deny ip
vlan 1
vlan 751 to 765
connection-limit policy 0
 limit 0 source ip 192.168.80.72 29 destination ip any protocol ip max-connections 50 per-source
 limit 1 source ip 192.168.91.0 25 destination ip any protocol ip max-connections 100 per-source
 limit 2 source ip 192.168.88.0 25 destination ip any protocol ip max-connections 100 per-source
 limit 3 source ip 192.168.78.64 26 destination ip any protocol ip max-connections 100 per-source
 limit 4 source ip 192.168.87.64 27 destination ip any protocol ip max-connections 200 per-source
 limit 5 source ip 192.168.79.0 25 destination ip any protocol ip max-connections 200 per-source
domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
pki entity en
  common-name http-server
pki domain default
  crl check disable
traffic classifier V764_Other_Uplink operator and
 if-match acl 3641
traffic classifier V764_Other_Downlink operator and
 if-match acl 3642
traffic classifier V760_Other_Uplink operator and
 if-match acl 3601
traffic classifier V760_Other_Downlink operator and
 if-match acl 3602
traffic classifier V757_Other_Uplink operator and
 if-match acl 3571
traffic classifier V757_Other_Downlink operator and
 if-match acl 3572
traffic classifier V753_Other_Uplink operator and
 if-match acl 3531
traffic classifier V753_Other_Downlink operator and
 if-match acl 3532
traffic classifier V765_Other_Uplink operator and
 if-match acl 3651
traffic classifier V765_Other_Downlink operator and
 if-match acl 3652
traffic classifier V757_Specail_Uplink operator and
 if-match acl 3573
traffic classifier V757_Specail_Downlink operator and
 if-match acl 3574
traffic classifier V758_Other_Uplink operator and
 if-match acl 3581
traffic classifier V758_Other_Downlink operator and
 if-match acl 3582
traffic classifier V754_Other_Uplink operator and
 if-match acl 3541
traffic classifier V754_Other_Downlink operator and
 if-match acl 3542
traffic classifier V759_Other_Uplink operator and
 if-match acl 3591
traffic classifier V759_Other_Downlink operator and
 if-match acl 3592
traffic classifier V755_Other_Uplink operator and
 if-match acl 3551
traffic classifier V755_Other_Downlink operator and
 if-match acl 3552
traffic classifier V763_Other_Uplink operator and
 if-match acl 3631
traffic classifier V763_Other_Downlink operator and
 if-match acl 3632
traffic classifier V756_Other_Uplink operator and
 if-match acl 3561
traffic classifier V756_Other_Downlink operator and
 if-match acl 3562
traffic behavior V764_Other_Uplink
 car cir 1500 cbs 93750 ebs 0 green pass red discard
traffic behavior V764_Other_Downlink
traffic behavior V760_Other_Uplink
 car cir 10000 cbs 625000 ebs 0 green pass red discard
traffic behavior V760_Other_Downlink
traffic behavior V757_Other_Uplink
 car cir 500 cbs 31250 ebs 0 green pass red discard
traffic behavior V757_Other_Downlink
 car cir 1000 cbs 62500 ebs 0 green pass red discard
traffic behavior V753_Other_Uplink
traffic behavior V753_Other_Downlink
 car cir 2500 cbs 156250 ebs 0 green pass red discard
traffic behavior V765_Other_Uplink
traffic behavior V765_Other_Downlink
traffic behavior V757_Specail_Uplink
traffic behavior V757_Specail_Downlink
traffic behavior V758_Other_Uplink
traffic behavior V758_Other_Downlink
traffic behavior V754_Other_Uplink
traffic behavior V754_Other_Downlink
traffic behavior V759_Other_Uplink
 car cir 3000 cbs 187500 ebs 0 green pass red discard
traffic behavior V759_Other_Downlink
traffic behavior V755_Other_Uplink
traffic behavior V755_Other_Downlink
traffic behavior V763_Other_Uplink
traffic behavior V763_Other_Downlink
 car cir 3500 cbs 218750 ebs 0 green pass red discard
traffic behavior V756_Other_Uplink
traffic behavior V756_Other_Downlink
qos policy V760_Uplink
 classifier V760_Other_Uplink behavior V760_Other_Uplink
qos policy V757_Uplink
 classifier V757_Specail_Uplink behavior V757_Specail_Uplink
 classifier V757_Other_Uplink behavior V757_Other_Uplink
qos policy V753_Uplink
 classifier V753_Other_Uplink behavior V753_Other_Uplink
qos policy V765_Uplink
 classifier V765_Other_Uplink behavior V765_Other_Uplink
qos policy V758_Uplink
 classifier V758_Other_Uplink behavior V758_Other_Uplink
qos policy V754_Uplink
 classifier V754_Other_Uplink behavior V754_Other_Uplink
qos policy V759_Uplink
 classifier V759_Other_Uplink behavior V759_Other_Uplink
qos policy V755_Uplink
 classifier V755_Other_Uplink behavior V755_Other_Uplink
qos policy V763_Uplink
 classifier V763_Other_Uplink behavior V763_Other_Uplink
qos policy V756_Uplink
 classifier V756_Other_Uplink behavior V756_Other_Uplink
qos policy V764_Uplink
 classifier V764_Other_Uplink behavior V764_Other_Uplink
qos policy All_Downlink
 classifier V753_Other_Downlink behavior V753_Other_Downlink
 classifier V754_Other_Downlink behavior V754_Other_Downlink
 classifier V755_Other_Downlink behavior V755_Other_Downlink
 classifier V756_Other_Downlink behavior V756_Other_Downlink
 classifier V758_Other_Downlink behavior V758_Other_Downlink
 classifier V760_Other_Downlink behavior V760_Other_Downlink
 classifier V763_Other_Downlink behavior V763_Other_Downlink
 classifier V764_Other_Downlink behavior V764_Other_Downlink
 classifier V765_Other_Downlink behavior V765_Other_Downlink
 classifier V757_Specail_Downlink behavior V757_Specail_Downlink
 classifier V757_Other_Downlink behavior V757_Other_Downlink
dhcp server ip-pool 192.168.75.0
 network 192.168.75.0 mask 255.255.255.240
 gateway-list 192.168.75.14
 dns-list 192.168.75.1
 domain-name abc.com
 nbns-list 192.168.75.1
dhcp server ip-pool 192.168.75.1
 static-bind ip-address 192.168.75.1 mask 255.255.255.240
 static-bind mac-address 0015-5d01-c102
 domain-name abc.com
dhcp server ip-pool 192.168.75.2
 static-bind ip-address 192.168.75.2 mask 255.255.255.240
 static-bind mac-address 0015-5d01-a201
 domain-name abc.com
dhcp server ip-pool 192.168.75.3
 static-bind ip-address 192.168.75.3 mask 255.255.255.240
 static-bind mac-address b083-fedf-fa09
 domain-name abc.com
dhcp server ip-pool 192.168.75.4
 static-bind ip-address 192.168.75.4 mask 255.255.255.240
 static-bind mac-address b083-fede-10fb
 domain-name abc.com
dhcp server ip-pool 192.168.75.5
 static-bind ip-address 192.168.75.5 mask 255.255.255.240
 static-bind mac-address b083-fede-4697
 domain-name abc.com
dhcp server ip-pool 192.168.75.6
 static-bind ip-address 192.168.75.6 mask 255.255.255.240
 static-bind mac-address b083-fede-a215
 domain-name abc.com
dhcp server ip-pool 192.168.75.7
 static-bind ip-address 192.168.75.7 mask 255.255.255.240
 static-bind mac-address b083-fede-c612
 domain-name abc.com
dhcp server ip-pool 192.168.76.72
 network 192.168.76.72 mask 255.255.255.248
 gateway-list 192.168.76.78
 domain-name abc.com
dhcp server ip-pool 192.168.76.73
 static-bind ip-address 192.168.76.73 mask 255.255.255.248
 static-bind mac-address 0015-5d01-a204
 domain-name abc.com
dhcp server ip-pool 192.168.76.74
 static-bind ip-address 192.168.76.74 mask 255.255.255.248
 static-bind mac-address 0015-5d01-c101
 domain-name abc.com
dhcp server ip-pool 192.168.77.64
 network 192.168.77.64 mask 255.255.255.224
 gateway-list 192.168.77.94
 domain-name abc.com
dhcp server ip-pool 192.168.78.64
 network 192.168.78.64 mask 255.255.255.192
 gateway-list 192.168.78.126
 domain-name abc.com
dhcp server ip-pool 192.168.79.
dhcp server ip-pool 192.168.79.64
 network 192.168.79.0 mask 255.255.255.128
 gateway-list 192.168.79.126
 domain-name abc.com
dhcp server ip-pool 192.168.79.78
dhcp server ip-pool 192.168.80.72
 network 192.168.80.72 mask 255.255.255.248
 gateway-list 192.168.80.78
 domain-name abc.com
dhcp server ip-pool 192.168.81.64
 network 192.168.81.64 mask 255.255.255.224
 gateway-list 192.168.81.94
 domain-name abc.com
 expired day 0 hour 8
dhcp server ip-pool 192.168.81.90
 static-bind ip-address 192.168.81.90 mask 255.255.255.224
 static-bind mac-address 0023-5af6-5a09
 dns-list 192.168.75.1 192.168.75.2
 domain-name abc.com
dhcp server ip-pool 192.168.83.65
 static-bind ip-address 192.168.83.65 mask 255.255.255.240
 static-bind mac-address 0021-7032-7724
 gateway-list 192.168.83.78
 domain-name abc.com
dhcp server ip-pool 192.168.83.66
 static-bind ip-address 192.168.83.66 mask 255.255.255.240
 static-bind mac-address 0022-4621-013a
 domain-name abc.com
dhcp server ip-pool 192.168.83.72
 network 192.168.83.64 mask 255.255.255.240
 domain-name abc.com
dhcp server ip-pool 192.168.83.75
 static-bind ip-address 192.168.83.75 mask 255.255.255.248
 static-bind mac-address 68f7-288d-4c7f
 domain-name abc.com
dhcp server ip-pool 192.168.87.64
 network 192.168.87.64 mask 255.255.255.224
 gateway-list 192.168.87.94
 domain-name abc.com
dhcp server ip-pool 192.168.87.88
 static-bind ip-address 192.168.87.87 mask 255.255.255.224
 static-bind mac-address 8c89-a575-d1a4
 domain-name abc.com
dhcp server ip-pool 192.168.87.89
 static-bind ip-address 192.168.87.89 mask 255.255.255.224
 static-bind mac-address bcae-c593-df49
 domain-name abc.com
dhcp server ip-pool 192.168.87.90
 static-bind ip-address 192.168.87.90 mask 255.255.255.224
 static-bind mac-address b083-fe5e-531a
 domain-name abc.com
dhcp server ip-pool 192.168.87.91
 static-bind ip-address 192.168.87.91 mask 255.255.255.224
 static-bind mac-address b083-fe5c-ef2a
 domain-name abc.com
dhcp server ip-pool 192.168.87.92
 static-bind ip-address 192.168.87.92 mask 255.255.255.224
 static-bind mac-address b083-fe5e-57f1
 domain-name abc.com
dhcp server ip-pool 192.168.87.93
 static-bind ip-address 192.168.87.93 mask 255.255.255.224
 static-bind mac-address b083-fe5c-ed1b
 domain-name abc.com
dhcp server ip-pool boardroom_760
 network 192.168.84.64 mask 255.255.255.192
 gateway-list 192.168.84.126
 domain-name abc.com
dhcp server ip-pool hxq-jtwpc17
 static-bind ip-address 192.168.78.96 mask 255.255.255.192
 static-bind mac-address b083-fe5e-579d
 domain-name abc.com
dhcp server ip-pool hzy-jtwpc30
 static-bind ip-address 192.168.78.119 mask 255.255.255.192
 static-bind mac-address b083-fe5e-5397
 domain-name abc.com
dhcp server ip-pool jtwpc01_hjr
 static-bind ip-address 192.168.77.86 mask 255.255.255.224
 static-bind mac-address 74e6-e2d7-9466
 domain-name abc.com
dhcp server ip-pool jtwpc02_xnj
 static-bind ip-address 192.168.77.89 mask 255.255.255.224
 static-bind mac-address b083-fe5e-595f
 domain-name abc.com
dhcp server ip-pool jtwpc03_yl
 static-bind ip-address 192.168.77.85 mask 255.255.255.224
 static-bind mac-address b083-fe5e-5338
 domain-name abc.com
dhcp server ip-pool jtwpc05_hpf
 static-bind ip-address 192.168.77.87 mask 255.255.255.224
 static-bind mac-address b083-fe5e-5c1a
 domain-name abc.com
dhcp server ip-pool jtwpc08
 static-bind ip-address 192.168.81.93 mask 255.255.255.224
 static-bind mac-address b083-fe5c-efaf
 domain-name abc.com
dhcp server ip-pool jtwpc24_zsj
 static-bind ip-address 192.168.77.84 mask 255.255.255.224
 static-bind mac-address b083-fe5c-f077
 domain-name abc.com
dhcp server ip-pool jtwpc30_zxh
 static-bind ip-address 192.168.77.88 mask 255.255.255.224
 static-bind mac-address b083-fe5c-ec37
 domain-name abc.com
dhcp server ip-pool outside_758
 network 192.168.182.0 mask 255.255.255.128
 gateway-list 192.168.182.126
 domain-name abc.com
dhcp server ip-pool outside_764
 network 192.168.88.0 mask 255.255.255.128
 gateway-list 192.168.88.126
 domain-name abc.com
dhcp server ip-pool outside_765
 network 192.168.91.0 mask 255.255.255.128
 gateway-list 192.168.91.126
 domain-name abc.com
dhcp server ip-pool plc-pc
 static-bind ip-address 192.168.83.73 mask 255.255.255.240
 static-bind mac-address 4437-e68d-22a1
 domain-name abc.com
dhcp server ip-pool print_753
 static-bind ip-address 192.168.77.90 mask 255.255.255.224
 static-bind mac-address 0015-999c-4cfa
 domain-name abc.com
dhcp server ip-pool ylh-note
 static-bind ip-address 192.168.81.92 mask 255.255.255.224
 static-bind mac-address b46d-8355-3647
 domain-name abc.com
dhcp server ip-pool ylhiphone
 static-bind ip-address 192.168.81.91 mask 255.255.255.224
 static-bind mac-address 0cd7-4650-cda5
 domain-name abc.com
dhcp server ip-pool zktec
 static-bind ip-address 192.168.81.88 mask 255.255.255.224
 static-bind mac-address 0017-6110-8918
 domain-name abc.com
policy-based-route Video permit node 10
 if-match acl 3901
 apply ip-precedence routine
 apply ip-address next-hop 192.168.90.33
user-group system
 group-attribute allow-guest
local-user admin
 password cipher $c$3$2NOwOYqwfeUohFfJxkRy7UqggvuWOmyFUmRu
 authorization-attribute level 3
 service-type telnet
 service-type web
ssl server-policy access-policy
cwmp
 undo cwmp enable
interface Bridge-Aggregation1
 port link-type trunk
 undo port trunk permit vlan 1
 port trunk permit vlan 751 to 752 757
 link-aggregation mode dynamic
interface NULL0
interface Vlan-interface751
 ip address 192.168.75.14 255.255.255.240
 arp send-gratuitous-arp interval 2000
interface Vlan-interface752
 ip address 192.168.76.78 255.255.255.248
interface Vlan-interface753
 ip address 192.168.77.94 255.255.255.224
 qos apply policy V753_Uplink inbound
interface Vlan-interface754
 ip address 192.168.78.126 255.255.255.192
 qos apply policy V754_Uplink inbound
interface Vlan-interface755
 ip address 192.168.79.126 255.255.255.128
 qos apply policy V755_Uplink inbound
interface Vlan-interface756
 ip address 192.168.80.78 255.255.255.248
 qos apply policy V756_Uplink inbound
interface Vlan-interface757
 ip address 192.168.81.94 255.255.255.224
 qos apply policy V757_Uplink inbound
 ip policy-based-route Video
interface Vlan-interface758
 ip address 192.168.182.126 255.255.255.128
 qos apply policy V758_Uplink inbound
interface Vlan-interface759
 ip address 192.168.83.78 255.255.255.240
interface Vlan-interface760
 ip address 192.168.84.126 255.255.255.192
 qos apply policy V760_Uplink inbound
interface Vlan-interface761
 ip address 192.168.85.126 255.255.255.128
interface Vlan-interface763
 ip address 192.168.87.94 255.255.255.224
 qos apply policy V763_Uplink inbound
interface Vlan-interface764
 ip address 192.168.88.126 255.255.255.128
 qos apply policy V764_Uplink inbound
interface Vlan-interface765
 ip address 192.168.91.126 255.255.255.128
 qos apply policy V765_Uplink inbound
interface GigabitEthernet0/0
 port link-mode route
 nat outbound 3903 address-group 2
 ip address 192.168.90.34 255.255.255.248
interface GigabitEthernet0/1
 nat outbound 3903 address-group 1
 nat server 1 protocol tcp global current-interface 9000 inside 192.168.81.93 www
 ip address dhcp-alloc
interface GigabitEthernet0/2
 port link-mode bridge
 port link-aggregation group 1
interface GigabitEthernet0/3
interface GigabitEthernet0/4
 port trunk permit vlan 2 to 4094
ospf 1
 import-route static
vd Root id 1
zone name Management id 0
 priority 100
zone name Local id 1
 priority 100
zone name Trust id 2
 priority 85
 import interface Vlan-interface751
 import interface Vlan-interface753
 import interface Vlan-interface754
 import interface Vlan-interface755
 import interface Vlan-interface756
 import interface Vlan-interface757
 import interface Vlan-interface759
 import interface Vlan-interface760
 import interface Vlan-interface763
zone name DMZ id 3
 priority 50
 import interface Vlan-interface752
 import interface Vlan-interface761
zone name Untrust id 4
 priority 5
 import interface GigabitEthernet0/0
 import interface GigabitEthernet0/1
zone name DMZ2 id 5
 priority 45
 import interface Vlan-interface758
 import interface Vlan-interface764
 import interface Vlan-interface765
switchto vd Root
 object network subnet 178.77.120.100/0.0.0.0
  subnet 178.77.120.100 0.0.0.0
 object network subnet 192.168.182.0/0.0.0.127
  subnet 192.168.182.0 0.0.0.127
 object network subnet 192.168.75.1/0.0.0.0
  subnet 192.168.75.1 0.0.0.0
 object network subnet 192.168.75.4/0.0.0.15
  subnet 192.168.75.4 0.0.0.15
 object network subnet 192.168.76.72/0.0.0.7
  subnet 192.168.76.72 0.0.0.7
 object network subnet 192.168.76.73/0.0.0.7
  subnet 192.168.76.73 0.0.0.7
 object network subnet 192.168.78.119/0.0.0.0
  subnet 192.168.78.119 0.0.0.0
 object network subnet 192.168.78.64/0.0.0.63
  subnet 192.168.78.64 0.0.0.63
 object network subnet 192.168.80.72/0.0.0.7
  subnet 192.168.80.72 0.0.0.7
 object network subnet 192.168.81.64
  subnet 192.168.81.64 0.0.0.15
 object network subnet 192.168.81.64/0.0.0.15
 object network subnet 192.168.81.64/0.0.0.31
  subnet 192.168.81.64 0.0.0.31
 object network subnet 192.168.81.67/0.0.0.0
  subnet 192.168.81.67 0.0.0.0
 object network subnet 192.168.83.64/0.0.0.15
  subnet 192.168.83.64 0.0.0.31
 object network subnet 192.168.83.64/0.0.0.31
 object network subnet 192.168.83.65/0.0.0.0
  subnet 192.168.83.65 0.0.0.0
 object network subnet 192.168.83.66/0.0.0.0
  subnet 192.168.83.66 0.0.0.0
 object network subnet 192.168.83.72/0.0.0.7
  subnet 192.168.83.72 0.0.0.7
 object network subnet 192.168.83.73/0.0.0.0
  subnet 192.168.83.73 0.0.0.0
 object network subnet 192.168.83.74/0.0.0.0
  subnet 192.168.83.74 0.0.0.0
 object network subnet 192.168.83.75/0.0.0.0
  subnet 192.168.83.75 0.0.0.0
 object network subnet 192.168.85.0/0.0.0.127
  subnet 192.168.85.0 0.0.0.127
 object network subnet 192.168.85.100/0.0.0.0
  subnet 192.168.85.100 0.0.0.0
 object network subnet 192.168.88.0/0.0.0.127
  subnet 192.168.88.0 0.0.0.127
 object network subnet 192.168.90.0/0.0.0.255
  subnet 192.168.90.0 0.0.0.255
 object network subnet 192.168.90.72/0.0.0.7
  subnet 192.168.90.72 0.0.0.7
 object network subnet 192.168.91.0/0.0.0.127
  subnet 192.168.91.0 0.0.0.127
 object network subnet 218.85.36.216/0.0.0.0
  subnet 218.85.36.216 0.0.0.0
 object network subnet 220.181.72.229/0.0.0.0
  subnet 220.181.72.229 0.0.0.0
 object network subnet dmzvideo
 object network host msaweb
  host address 218.85.36.216
  host address 220.181.72.229
 object network host pass81
  host address 192.168.81.90
  host address 192.168.81.91
  host address 192.168.81.92
  host address 192.168.81.93
 object network range qq_111.161.52.151
  range 111.161.52.151 111.161.52.158
 object network range qq_111.161.52.18
  range 111.161.52.18 111.161.52.18
 object network range qq_111.161.88.16
  range 111.161.88.16 111.161.88.31
 object network range qq_111.161.88.42
  range 111.161.88.42 111.161.88.50
 object network range qq_111.161.88.75
  range 111.161.88.75 111.161.88.81
 object network range qq_111.30.131.159
  range 111.30.131.159 111.30.131.159
 object network range qq_111.30.131.168
  range 111.30.131.168 111.30.131.175
 object network range qq_111.30.131.179
  range 111.30.131.179 111.30.131.194
  range exclude 111.30.131.190
  range exclude 111.30.131.191
  range exclude 111.30.131.192
  range exclude 111.30.131.193
 object network range qq_112.95.240.10
  range 112.95.240.10 112.95.240.13
  range exclude 112.95.240.11
  range exclude 112.95.240.12
 object network range qq_112.95.240.120
  range 112.95.240.120 112.95.240.125
  range exclude 112.95.240.122
  range exclude 112.95.240.124
 object network range qq_112.95.240.185
  range 112.95.240.185 112.95.240.185
 object network range qq_112.95.240.22
  range 112.95.240.22 112.95.240.26
  range exclude 112.95.240.24
  range exclude 112.95.240.25
 object network range qq_112.95.240.38
  range 112.95.240.38 112.95.240.39
 object network range qq_112.95.240.47
  range 112.95.240.47 112.95.240.52
  range exclude 112.95.240.51
 object network range qq_112.95.240.61
  range 112.95.240.61 112.95.240.61
 object network range qq_112.95.240.69
  range 112.95.240.69 112.95.240.69
 object network range qq_112.95.240.89
  range 112.95.240.89 112.95.240.106
  range exclude 112.95.240.90
  range exclude 112.95.240.91
  range exclude 112.95.240.93
  range exclude 112.95.240.95
  range exclude 112.95.240.97
  range exclude 112.95.240.98
  range exclude 112.95.240.100
  range exclude 112.95.240.103
  range exclude 112.95.240.105
 object network range qq_112.95.242.102
  range 112.95.242.102 112.95.242.102
 object network range qq_119.147.32.203
  range 119.147.32.203 119.147.32.203
 object network range qq_119.147.32.233
  range 119.147.32.233 119.147.32.236
  range exclude 119.147.32.234
 object network range qq_120.196.212.74
  range 120.196.212.74 120.196.212.74
 object network range qq_120.196.212.87
  range 120.196.212.87 120.196.212.87
 object network range qq_120.196.212.94
  range 120.196.212.94 120.196.212.94
 object network range qq_123.151.13.111
  range 123.151.13.111 123.151.13.112
 object network range qq_123.151.13.160
  range 123.151.13.160 123.151.13.169
  range exclude 123.151.13.163
  range exclude 123.151.13.167
 object network range qq_123.151.13.45
  range 123.151.13.45 123.151.13.50
  range exclude 123.151.13.46
  range exclude 123.151.13.47
 object network range qq_123.151.13.78
  range 123.151.13.78 123.151.13.79
 object network range qq_123.151.40.105
  range 123.151.40.105 123.151.40.105
 object network range qq_123.151.40.161
  range 123.151.40.161 123.151.40.163
 object network range qq_123.151.40.180
  range 123.151.40.180 123.151.40.191
  range exclude 123.151.40.181
  range exclude 123.151.40.182
  range exclude 123.151.40.184
  range exclude 123.151.40.186
  range exclude 123.151.40.188
 object network range qq_123.151.40.24
  range 123.151.40.24 123.151.40.25
 object network range qq_123.151.47.49
  range 123.151.47.49 123.151.47.49
 object network range qq_123.151.47.81
  range 123.151.47.81 123.151.47.81
 object network range qq_123.151.47.91
  range 123.151.47.91 123.151.47.91
 object network range qq_125.39.205.25
  range 125.39.205.25 125.39.205.27
 object network range qq_125.39.205.32
  range 125.39.205.32 125.39.205.34
  range exclude 125.39.205.33
 object network range qq_125.39.205.42
  range 125.39.205.42 125.39.205.44
  range exclude 125.39.205.43
 object network range qq_163.177.87.198
  range 163.177.87.198 163.177.87.204
  range exclude 163.177.87.200
 object network range qq_163.177.90.222
  range 163.177.90.222 163.177.90.222
 object network range qq_183.232.127.124
  range 183.232.127.124 183.232.127.124
 object network range qq_183.232.127.241
  range 183.232.127.241 183.232.127.247
 object network range qq_183.232.93.22
  range 183.232.93.22 183.232.93.29
 object network range qq_183.232.94.212
  range 183.232.94.212 183.232.94.212
 object network range qq_183.57.50.108
  range 183.57.50.108 183.57.50.108
 object network range qq_183.60.19.148
  range 183.60.19.148 183.60.19.151
  range exclude 183.60.19.149
 object network range qq_183.60.19.166
  range 183.60.19.166 183.60.19.176
  range exclude 183.60.19.168
  range exclude 183.60.19.169
  range exclude 183.60.19.170
  range exclude 183.60.19.171
  range exclude 183.60.19.172
 object network range qq_183.60.19.20
  range 183.60.19.20 183.60.19.22
  range exclude 183.60.19.21
 object network range qq_183.60.19.35
  range 183.60.19.35 183.60.19.35
 object network range qq_183.60.19.40
  range 183.60.19.40 183.60.19.41
 object network range qq_183.60.19.50
  range 183.60.19.50 183.60.19.50
 object network range qq_183.60.19.76
  range 183.60.19.76 183.60.19.76
 object network range qq_183.60.48.250
  range 183.60.48.250 183.60.48.250
 object network range qq_183.60.49.182
  range 183.60.49.182 183.60.49.182
 object network range qq_183.60.50.23
  range 183.60.50.23 183.60.50.25
  range exclude 183.60.50.24
 object network range qq_183.60.56.14
  range 183.60.56.14 183.60.56.23
  range exclude 183.60.56.16
  range exclude 183.60.56.20
 object network range qq_183.60.56.92
  range 183.60.56.92 183.60.56.102
  range exclude 183.60.56.94
  range exclude 183.60.56.96
  range exclude 183.60.56.100
 object network range qq_220.249.245.150
  range 220.249.245.150 220.249.245.156
 object network host tv
  host address 63.80.4.163
  host address 63.80.4.187
  host address 63.80.4.208
  host address 63.80.4.216
  host address 63.80.4.217
  host address 101.96.10.71
  host address 106.38.190.245
  host address 218.6.23.37
  host address 222.73.145.34
 object service msawebport
  service tcp source-port 0 destination-port 9080
 object service qqtcp443
  service tcp destination-port 443
 object service qqtcp80
  service tcp destination-port 80
 object service qqudp
  service udp destination-port 8000
 object service tcp_from_445
  service tcp source-port 445
 object service tcp_to_445
  service tcp destination-port 445
 object service udp_from_445
  service udp source-port 445
 object service udp_to_445
  service udp destination-port 445
 object-group network qq
  network-object qq_111.161.52.151
  network-object qq_111.161.52.18
  network-object qq_111.161.88.16
  network-object qq_111.161.88.42
  network-object qq_111.161.88.75
  network-object qq_111.30.131.159
  network-object qq_111.30.131.179
  network-object qq_112.95.240.10
  network-object qq_112.95.240.120
  network-object qq_112.95.240.22
  network-object qq_112.95.240.38
  network-object qq_111.30.131.168
  network-object qq_112.95.240.185
  network-object qq_112.95.240.61
  network-object qq_112.95.240.69
  network-object qq_112.95.240.89
  network-object qq_112.95.242.102
  network-object qq_119.147.32.203
  network-object qq_119.147.32.233
  network-object qq_112.95.240.47
  network-object qq_120.196.212.74
  network-object qq_120.196.212.94
  network-object qq_123.151.13.111
  network-object qq_120.196.212.87
  network-object qq_123.151.13.78
  network-object qq_123.151.13.160
  network-object qq_123.151.13.45
  network-object qq_123.151.40.105
  network-object qq_220.249.245.150
  network-object qq_183.60.48.250
  network-object qq_183.60.19.40
  network-object qq_183.60.19.35
  network-object qq_183.60.19.166
  network-object qq_183.57.50.108
  network-object qq_183.232.94.212
  network-object qq_183.232.127.241
  network-object qq_183.232.127.124
  network-object qq_163.177.90.222
  network-object qq_163.177.87.198
  network-object qq_125.39.205.42
  network-object qq_125.39.205.32
  network-object qq_183.232.93.22
  network-object qq_123.151.47.91
  network-object qq_123.151.47.81
  network-object qq_125.39.205.25
  network-object qq_123.151.47.49
  network-object qq_123.151.40.180
  network-object qq_123.151.40.161
  network-object qq_183.60.56.92
  network-object qq_183.60.19.50
  network-object qq_183.60.19.148
  network-object qq_183.60.19.20
  network-object qq_123.151.40.24
  network-object qq_183.60.49.182
  network-object qq_183.60.19.76
  network-object qq_183.60.56.14
  network-object qq_183.60.50.23
 ip virtual-reassembly
  flow-statistics enable source-ip
  flow-statistics enable destination-ip
  flow-statistics enable inbound
  flow-statistics enable outbound
 zone name DMZ id 3
 zone name DMZ2 id 5
 interzone source Trust destination DMZ
  firewall aspf enable
 interzone source Trust destination Untrust
  rule 16 deny logging
   source-ip any_address
   destination-ip any_address
   service tcp_to_445
   service udp_to_445
   rule enable
  rule 14 permit
   source-ip pass81
   service any_service
  rule 13 permit
   source-ip 192.168.78.119/0.0.0.0
   service any_service
  rule 12 deny
   source-ip 192.168.182.0/0.0.0.127
   service any_service
  rule 11 deny
   source-ip 192.168.80.72/0.0.0.7
   service any_service
  rule 10 deny
   source-ip 192.168.88.0/0.0.0.127
   service any_service
  rule 9 deny
   source-ip 192.168.91.0/0.0.0.127
   service any_service
  rule 18 permit
   source-ip 192.168.78.64/0.0.0.63
   destination-ip msaweb
   service any_service
  rule 8 deny
   service any_service
  rule 4 deny
   source-ip 192.168.81.64/0.0.0.31
   service any_service
  rule 17 permit
   source-ip 192.168.83.66/0.0.0.0
   service any_service
   rule enable
  rule 7 permit
   source-ip 192.168.83.73/0.0.0.0
   service any_service
   rule enable
  rule 3 permit
   source-ip 192.168.83.65/0.0.0.0
   service any_service
   rule enable
  rule 2 deny
   source-ip 192.168.83.64/0.0.0.31
   service any_service
   rule enable
  rule 0 permit
   service any_service
   rule enable
 interzone source DMZ destination Trust
  rule 0 permit
   source-ip 192.168.76.73/0.0.0.7
   destination-ip 192.168.75.4/0.0.0.15
   service any_service
   rule enable
  rule 2 permit
   service any_service
   rule enable
 interzone source DMZ destination Untrust
  rule 4 deny
   service tcp_to_445
   service udp_to_445
   rule enable
  rule 3 permit
   source-ip 192.168.85.100/0.0.0.0
   service any_service
  rule 2 deny
   source-ip dmzvideo
   service any_service
   rule enable
  rule 0 permit
   service any_service
   rule enable
 interzone source Untrust destination Trust
  rule 0 permit logging
   service any_service
   rule enable
 interzone source Untrust destination DMZ
  rule 0 permit
   service any_service
   rule enable
 interzone source DMZ2 destination Trust
  rule 0 permit
   destination-ip 192.168.75.1/0.0.0.0
   service dns-tcp
   service dns-udp
   rule enable
 interzone source DMZ2 destination Untrust
  rule 0 permit
   service any_service
   rule enable
 interzone source Any destination Any
 content-filtering keyword-entry 影视过滤
  keyword fix-string 优酷
  keyword fix-string 百度影音
 content-filtering url-hostname-entry youku
  url-hostname fix-string www.youku.com
 content-filtering http-policy HTTP
  url-filtering url-hostname-entry youku
  head-filtering keyword-entry 影视过滤
  body-filtering keyword-entry 影视过滤
  url-ip-blocking enable
  url-parameter-filtering enable
  activex-blocking enable
  java-applet-blocking enable
  logging enable
 content-filtering policy-template http
  http-policy HTTP
 connection-limit apply policy 0
 ssl-vpn server-policy access-policy
 ip route-static 0.0.0.0 0.0.0.0 GigabitEthernet0/1 192.168.90.73
 ip route-static 0.0.0.0 0.0.0.0 GigabitEthernet0/0 192.168.90.33 preference 61
 dhcp server forbidden-ip 192.168.75.1 192.168.75.7
 dhcp server forbidden-ip 192.168.75.14
 dhcp server forbidden-ip 192.168.77.94
 dhcp server forbidden-ip 192.168.80.78
 dhcp server forbidden-ip 192.168.81.78
 dhcp server forbidden-ip 192.168.82.78
 dhcp server forbidden-ip 192.168.83.78
 dhcp server forbidden-ip 192.168.84.78
 dhcp server forbidden-ip 192.168.76.78
 dhcp server forbidden-ip 192.168.76.73 192.168.76.74
 dhcp server forbidden-ip 192.168.85.65 192.168.85.66
 dhcp server forbidden-ip 192.168.85.78
 dhcp server forbidden-ip 192.168.87.77 192.168.87.78
 dhcp server forbidden-ip 192.168.79.125 192.168.79.126
 dhcp server detect
 dhcp enable
 ntp-service source-interface GigabitEthernet0/1
 ntp-service unicast-server 210.75.145.44
 ip https ssl-server-policy access-policy
 ip https enable
 load xml-configuration
 load tr069-configuration
user-interface con 0
user-interface vty 0 4
 authentication-mode scheme
return
粉丝:2人 关注:0人
贴一下你的路由配置
# version 5.20, Release 5142P02 # sysname H3C # clock timezone Beijing add 08:00:00 # undo voice vlan mac-address 00e0-bb00-0000 # ike local-name firewalla # interzone policy default by-priority # nat address-group 1 192.168.90.74 192.168.90.78 nat address-group 2 192.168.90.34 192.168.90.38 # domain default enable system # dns resolve dns proxy enable dns server 218.85.157.99 dns server 218.85.152.99 # telnet server enable # ip ttl-expires enable ip unreachables enable # link-aggregation load-sharing mode destination-ip source-ip # qos carl 1 destination-ip-address subnet 192.168.77.94 27 qos carl 2 destination-ip-address subnet 192.168.77.94 27 per-address qos carl 11 destination-ip-address subnet 192.168.78.126 26 qos carl 12 destination-ip-address subnet 192.168.78.126 26 per-address qos carl 21 destination-ip-address subnet 192.168.79.126 25 qos carl 22 destination-ip-address subnet 192.168.79.126 25 per-address qos carl 31 destination-ip-address subnet 192.168.80.78 29 qos carl 32 destination-ip-address subnet 192.168.80.78 29 per-address qos carl 41 destination-ip-address subnet 192.168.82.126 25 qos carl 42 destination-ip-address subnet 192.168.82.126 25 per-address qos carl 51 destination-ip-address subnet 192.168.84.126 26 qos carl 52 destination-ip-address subnet 192.168.84.126 26 per-address qos carl 61 destination-ip-address subnet 192.168.87.94 27 qos carl 62 destination-ip-address subnet 192.168.87.94 27 per-address qos carl 71 destination-ip-address subnet 192.168.88.126 25 qos carl 72 destination-ip-address subnet 192.168.88.126 25 per-address qos carl 81 destination-ip-address subnet 192.168.91.126 25 qos carl 82 destination-ip-address subnet 192.168.91.126 25 per-address # port-security enable # undo alg dns undo alg rtsp undo alg h323 undo alg sip undo alg sqlnet undo alg pptp undo alg ils undo alg nbt undo alg msn undo alg qq undo alg tftp undo alg sccp undo alg gtp # session synchronization enable # password-recovery enable # blacklist enable blacklist ip 192.168.78.93 blacklist ip 192.168.78.107 # acl number 2001 rule 1 permit source 192.168.83.74 0 rule 2 deny source 192.168.83.64 0.0.0.15 rule 5 permit source 192.168.76.72 0.0.0.7 rule 10 permit source 192.168.87.64 0.0.0.31 rule 15 permit source 192.168.78.64 0.0.0.63 rule 30 deny source 192.168.81.64 0.0.0.31 rule 35 permit source 192.168.182.0 0.0.0.127 rule 45 permit source 192.168.84.64 0.0.0.31 rule 50 permit source 192.168.75.0 0.0.0.15 rule 55 permit source 192.168.77.64 0.0.0.31 rule 60 permit source 192.168.79.0 0.0.0.127 acl number 2002 rule 0 permit source 192.168.81.64 0.0.0.31 # acl number 3531 description VLAN 753 Subnet Other uplink ACL rule 0 permit ip source 192.168.77.64 0.0.0.31 acl number 3532 description VLAN 753 Subnet Other downlink ACL rule 0 permit ip destination 192.168.77.64 0.0.0.31 acl number 3541 description VLAN 754 Subnet Other uplink ACL rule 0 permit ip source 192.168.78.64 0.0.0.63 acl number 3542 description VLAN 754 Subnet Other downlink ACL rule 0 permit ip destination 192.168.78.64 0.0.0.63 acl number 3551 description VLAN 755 Subnet Other uplink ACL rule 0 permit ip source 192.168.79.0 0.0.0.127 acl number 3552 description VLAN 755 Subnet Other downlink ACL rule 0 permit ip destination 192.168.79.0 0.0.0.127 acl number 3561 description VLAN 756 Subnet Other uplink ACL rule 0 permit ip source 192.168.80.72 0.0.0.7 acl number 3562 description VLAN 756 Subnet Other downlink ACL rule 0 permit ip destination 192.168.80.72 0.0.0.7 acl number 3571 description VLAN 757 Subnet Other uplink ACL rule 0 permit ip source 192.168.81.64 0.0.0.31 acl number 3572 description VLAN 757 Subnet Other downlink ACL rule 0 permit ip destination 192.168.81.64 0.0.0.31 acl number 3573 description VLAN 757 Subnet Special uplink ACL rule 0 permit ip source 192.168.81.93 0 rule 5 permit ip source 192.168.81.92 0 rule 10 permit ip source 192.168.81.90 0 rule 15 permit ip source 192.168.81.91 0 acl number 3574 description VLAN 757 Subnet Special downlink ACL rule 0 permit ip destination 192.168.81.93 0 rule 5 permit ip destination 192.168.81.92 0 rule 10 permit ip destination 192.168.81.90 0 rule 15 permit ip destination 192.168.81.91 0 acl number 3581 description VLAN 758 Subnet Other uplink ACL rule 0 permit ip source 192.168.182.0 0.0.0.127 acl number 3582 description VLAN 758 Subnet Other downlink ACL rule 0 permit ip destination 192.168.182.0 0.0.0.127 acl number 3591 description VLAN 759 Subnet Other uplink ACL rule 0 permit ip source 192.168.83.64 0.0.0.15 acl number 3592 description VLAN 759 Subnet Other downlink ACL rule 0 permit ip destination 192.168.83.64 0.0.0.15 acl number 3601 description VLAN 760 Subnet Other uplink ACL rule 0 permit ip source 192.168.84.64 0.0.0.63 acl number 3602 description VLAN 760 Subnet Other downlink ACL rule 0 permit ip destination 192.168.84.64 0.0.0.63 acl number 3631 description VLAN 763 Subnet Other uplink ACL rule 0 permit ip source 192.168.87.64 0.0.0.31 acl number 3632 description VLAN 763 Subnet Other downlink ACL rule 0 permit ip destination 192.168.87.64 0.0.0.31 acl number 3641 description VLAN 764 Subnet Other uplink ACL rule 0 permit ip source 192.168.88.0 0.0.0.127 acl number 3642 description VLAN 762 Subnet Other downlink ACL rule 0 permit ip destination 192.168.88.0 0.0.0.127 acl number 3651 description VLAN 765 Subnet Other uplink ACL rule 0 permit ip source 192.168.91.0 0.0.0.127 acl number 3652 description VLAN 765 Subnet Other downlink ACL rule 0 permit ip destination 192.168.91.0 0.0.0.127 acl number 3901 rule 5 permit ip source 192.168.81.64 0.0.0.31 rule 10 deny ip acl number 3903 rule 0 permit ip source 192.168.75.0 0.0.0.15 rule 5 permit ip source 192.168.76.72 0.0.0.7 rule 10 permit ip source 192.168.77.64 0.0.0.31 rule 15 permit ip source 192.168.78.64 0.0.0.63 rule 20 permit ip source 192.168.79.0 0.0.0.127 rule 25 permit ip source 192.168.80.72 0.0.0.7 rule 30 permit ip source 192.168.81.64 0.0.0.31 rule 35 permit ip source 192.168.84.64 0.0.0.63 rule 40 permit ip source 192.168.85.0 0.0.0.127 rule 45 permit ip source 192.168.87.64 0.0.0.31 rule 50 permit ip source 192.168.88.0 0.0.0.127 rule 55 permit ip source 192.168.91.0 0.0.0.127 rule 60 permit ip source 192.168.83.64 0.0.0.31 rule 70 deny ip # vlan 1 # vlan 751 to 765 # connection-limit policy 0 limit 0 source ip 192.168.80.72 29 destination ip any protocol ip max-connections 50 per-source limit 1 source ip 192.168.91.0 25 destination ip any protocol ip max-connections 100 per-source limit 2 source ip 192.168.88.0 25 destination ip any protocol ip max-connections 100 per-source limit 3 source ip 192.168.78.64 26 destination ip any protocol ip max-connections 100 per-source limit 4 source ip 192.168.87.64 27 destination ip any protocol ip max-connections 200 per-source limit 5 source ip 192.168.79.0 25 destination ip any protocol ip max-connections 200 per-source # domain system access-limit disable state active idle-cut disable self-service-url disable # pki entity en common-name http-server # pki domain default crl check disable # traffic classifier V764_Other_Uplink operator and if-match acl 3641 traffic classifier V764_Other_Downlink operator and if-match acl 3642 traffic classifier V760_Other_Uplink operator and if-match acl 3601 traffic classifier V760_Other_Downlink operator and if-match acl 3602 traffic classifier V757_Other_Uplink operator and if-match acl 3571 traffic classifier V757_Other_Downlink operator and if-match acl 3572 traffic classifier V753_Other_Uplink operator and if-match acl 3531 traffic classifier V753_Other_Downlink operator and if-match acl 3532 traffic classifier V765_Other_Uplink operator and if-match acl 3651 traffic classifier V765_Other_Downlink operator and if-match acl 3652 traffic classifier V757_Specail_Uplink operator and if-match acl 3573 traffic classifier V757_Specail_Downlink operator and if-match acl 3574 traffic classifier V758_Other_Uplink operator and if-match acl 3581 traffic classifier V758_Other_Downlink operator and if-match acl 3582 traffic classifier V754_Other_Uplink operator and if-match acl 3541 traffic classifier V754_Other_Downlink operator and if-match acl 3542 traffic classifier V759_Other_Uplink operator and if-match acl 3591 traffic classifier V759_Other_Downlink operator and if-match acl 3592 traffic classifier V755_Other_Uplink operator and if-match acl 3551 traffic classifier V755_Other_Downlink operator and if-match acl 3552 traffic classifier V763_Other_Uplink operator and if-match acl 3631 traffic classifier V763_Other_Downlink operator and if-match acl 3632 traffic classifier V756_Other_Uplink operator and if-match acl 3561 traffic classifier V756_Other_Downlink operator and if-match acl 3562 # traffic behavior V764_Other_Uplink car cir 1500 cbs 93750 ebs 0 green pass red discard traffic behavior V764_Other_Downlink car cir 1500 cbs 93750 ebs 0 green pass red discard traffic behavior V760_Other_Uplink car cir 10000 cbs 625000 ebs 0 green pass red discard traffic behavior V760_Other_Downlink car cir 10000 cbs 625000 ebs 0 green pass red discard traffic behavior V757_Other_Uplink car cir 500 cbs 31250 ebs 0 green pass red discard traffic behavior V757_Other_Downlink car cir 1000 cbs 62500 ebs 0 green pass red discard traffic behavior V753_Other_Uplink car cir 1500 cbs 93750 ebs 0 green pass red discard traffic behavior V753_Other_Downlink car cir 2500 cbs 156250 ebs 0 green pass red discard traffic behavior V765_Other_Uplink car cir 1500 cbs 93750 ebs 0 green pass red discard traffic behavior V765_Other_Downlink car cir 1500 cbs 93750 ebs 0 green pass red discard traffic behavior V757_Specail_Uplink car cir 10000 cbs 625000 ebs 0 green pass red discard traffic behavior V757_Specail_Downlink car cir 10000 cbs 625000 ebs 0 green pass red discard traffic behavior V758_Other_Uplink car cir 500 cbs 31250 ebs 0 green pass red discard traffic behavior V758_Other_Downlink car cir 1500 cbs 93750 ebs 0 green pass red discard traffic behavior V754_Other_Uplink car cir 1000 cbs 62500 ebs 0 green pass red discard traffic behavior V754_Other_Downlink car cir 1000 cbs 62500 ebs 0 green pass red discard traffic behavior V759_Other_Uplink car cir 3000 cbs 187500 ebs 0 green pass red discard traffic behavior V759_Other_Downlink car cir 3000 cbs 187500 ebs 0 green pass red discard traffic behavior V755_Other_Uplink car cir 1500 cbs 93750 ebs 0 green pass red discard traffic behavior V755_Other_Downlink car cir 2500 cbs 156250 ebs 0 green pass red discard traffic behavior V763_Other_Uplink car cir 2500 cbs 156250 ebs 0 green pass red discard traffic behavior V763_Other_Downlink car cir 3500 cbs 218750 ebs 0 green pass red discard traffic behavior V756_Other_Uplink car cir 500 cbs 31250 ebs 0 green pass red discard traffic behavior V756_Other_Downlink car cir 1000 cbs 62500 ebs 0 green pass red discard # qos policy V760_Uplink classifier V760_Other_Uplink behavior V760_Other_Uplink qos policy V757_Uplink classifier V757_Specail_Uplink behavior V757_Specail_Uplink classifier V757_Other_Uplink behavior V757_Other_Uplink qos policy V753_Uplink classifier V753_Other_Uplink behavior V753_Other_Uplink qos policy V765_Uplink classifier V765_Other_Uplink behavior V765_Other_Uplink qos policy V758_Uplink classifier V758_Other_Uplink behavior V758_Other_Uplink qos policy V754_Uplink classifier V754_Other_Uplink behavior V754_Other_Uplink qos policy V759_Uplink classifier V759_Other_Uplink behavior V759_Other_Uplink qos policy V755_Uplink classifier V755_Other_Uplink behavior V755_Other_Uplink qos policy V763_Uplink classifier V763_Other_Uplink behavior V763_Other_Uplink qos policy V756_Uplink classifier V756_Other_Uplink behavior V756_Other_Uplink qos policy V764_Uplink classifier V764_Other_Uplink behavior V764_Other_Uplink qos policy All_Downlink classifier V753_Other_Downlink behavior V753_Other_Downlink classifier V754_Other_Downlink behavior V754_Other_Downlink classifier V755_Other_Downlink behavior V755_Other_Downlink classifier V756_Other_Downlink behavior V756_Other_Downlink classifier V758_Other_Downlink behavior V758_Other_Downlink classifier V760_Other_Downlink behavior V760_Other_Downlink classifier V763_Other_Downlink behavior V763_Other_Downlink classifier V764_Other_Downlink behavior V764_Other_Downlink classifier V765_Other_Downlink behavior V765_Other_Downlink classifier V757_Specail_Downlink behavior V757_Specail_Downlink classifier V757_Other_Downlink behavior V757_Other_Downlink # dhcp server ip-pool 192.168.75.0 network 192.168.75.0 mask 255.255.255.240 gateway-list 192.168.75.14 dns-list 192.168.75.1 domain-name abc.com nbns-list 192.168.75.1 # dhcp server ip-pool 192.168.75.1 static-bind ip-address 192.168.75.1 mask 255.255.255.240 static-bind mac-address 0015-5d01-c102 gateway-list 192.168.75.14 dns-list 192.168.75.1 domain-name abc.com nbns-list 192.168.75.1 # dhcp server ip-pool 192.168.75.2 static-bind ip-address 192.168.75.2 mask 255.255.255.240 static-bind mac-address 0015-5d01-a201 gateway-list 192.168.75.14 dns-list 192.168.75.1 domain-name abc.com nbns-list 192.168.75.1 # dhcp server ip-pool 192.168.75.3 static-bind ip-address 192.168.75.3 mask 255.255.255.240 static-bind mac-address b083-fedf-fa09 gateway-list 192.168.75.14 dns-list 192.168.75.1 domain-name abc.com nbns-list 192.168.75.1 # dhcp server ip-pool 192.168.75.4 static-bind ip-address 192.168.75.4 mask 255.255.255.240 static-bind mac-address b083-fede-10fb gateway-list 192.168.75.14 dns-list 192.168.75.1 domain-name abc.com nbns-list 192.168.75.1 # dhcp server ip-pool 192.168.75.5 static-bind ip-address 192.168.75.5 mask 255.255.255.240 static-bind mac-address b083-fede-4697 gateway-list 192.168.75.14 dns-list 192.168.75.1 domain-name abc.com nbns-list 192.168.75.1 # dhcp server ip-pool 192.168.75.6 static-bind ip-address 192.168.75.6 mask 255.255.255.240 static-bind mac-address b083-fede-a215 gateway-list 192.168.75.14 dns-list 192.168.75.1 domain-name abc.com nbns-list 192.168.75.1 # dhcp server ip-pool 192.168.75.7 static-bind ip-address 192.168.75.7 mask 255.255.255.240 static-bind mac-address b083-fede-c612 gateway-list 192.168.75.14 dns-list 192.168.75.1 domain-name abc.com nbns-list 192.168.75.1 # dhcp server ip-pool 192.168.76.72 network 192.168.76.72 mask 255.255.255.248 gateway-list 192.168.76.78 dns-list 192.168.75.1 domain-name abc.com nbns-list 192.168.75.1 # dhcp server ip-pool 192.168.76.73 static-bind ip-address 192.168.76.73 mask 255.255.255.248 static-bind mac-address 0015-5d01-a204 gateway-list 192.168.76.78 dns-list 192.168.75.1 domain-name abc.com nbns-list 192.168.75.1 # dhcp server ip-pool 192.168.76.74 static-bind ip-address 192.168.76.74 mask 255.255.255.248 static-bind mac-address 0015-5d01-c101 gateway-list 192.168.76.78 dns-list 192.168.75.1 domain-name abc.com nbns-list 192.168.75.1 # dhcp server ip-pool 192.168.77.64 network 192.168.77.64 mask 255.255.255.224 gateway-list 192.168.77.94 dns-list 192.168.75.1 domain-name abc.com nbns-list 192.168.75.1 # dhcp server ip-pool 192.168.78.64 network 192.168.78.64 mask 255.255.255.192 gateway-list 192.168.78.126 dns-list 192.168.75.1 domain-name abc.com nbns-list 192.168.75.1 # dhcp server ip-pool 192.168.79. # dhcp server ip-pool 192.168.79.64 network 192.168.79.0 mask 255.255.255.128 gateway-list 192.168.79.126 dns-list 192.168.75.1 domain-name abc.com nbns-list 192.168.75.1 # dhcp server ip-pool 192.168.79.78 # dhcp server ip-pool 192.168.80.72 network 192.168.80.72 mask 255.255.255.248 gateway-list 192.168.80.78 dns-list 192.168.75.1 domain-name abc.com nbns-list 192.168.75.1 # dhcp server ip-pool 192.168.81.64 network 192.168.81.64 mask 255.255.255.224 gateway-list 192.168.81.94 dns-list 192.168.75.1 domain-name abc.com nbns-list 192.168.75.1 expired day 0 hour 8 # dhcp server ip-pool 192.168.81.90 static-bind ip-address 192.168.81.90 mask 255.255.255.224 static-bind mac-address 0023-5af6-5a09 gateway-list 192.168.81.94 dns-list 192.168.75.1 192.168.75.2 domain-name abc.com nbns-list 192.168.75.1 # dhcp server ip-pool 192.168.83.65 static-bind ip-address 192.168.83.65 mask 255.255.255.240 static-bind mac-address 0021-7032-7724 gateway-list 192.168.83.78 dns-list 192.168.75.1 192.168.75.2 domain-name abc.com nbns-list 192.168.75.1 # dhcp server ip-pool 192.168.83.66 static-bind ip-address 192.168.83.66 mask 255.255.255.240 static-bind mac-address 0022-4621-013a gateway-list 192.168.83.78 dns-list 192.168.75.1 192.168.75.2 domain-name abc.com nbns-list 192.168.75.1 # dhcp server ip-pool 192.168.83.72 network 192.168.83.64 mask 255.255.255.240 gateway-list 192.168.83.78 dns-list 192.168.75.1 192.168.75.2 domain-name abc.com nbns-list 192.168.75.1 # dhcp server ip-pool 192.168.83.75 static-bind ip-address 192.168.83.75 mask 255.255.255.248 static-bind mac-address 68f7-288d-4c7f gateway-list 192.168.83.78 dns-list 192.168.75.1 192.168.75.2 domain-name abc.com nbns-list 192.168.75.1 # dhcp server ip-pool 192.168.87.64 network 192.168.87.64 mask 255.255.255.224 gateway-list 192.168.87.94 dns-list 192.168.75.1 domain-name abc.com nbns-list 192.168.75.1 # dhcp server ip-pool 192.168.87.88 static-bind ip-address 192.168.87.87 mask 255.255.255.224 static-bind mac-address 8c89-a575-d1a4 gateway-list 192.168.87.94 dns-list 192.168.75.1 domain-name abc.com nbns-list 192.168.75.1 # dhcp server ip-pool 192.168.87.89 static-bind ip-address 192.168.87.89 mask 255.255.255.224 static-bind mac-address bcae-c593-df49 gateway-list 192.168.87.94 dns-list 192.168.75.1 domain-name abc.com nbns-list 192.168.75.1 # dhcp server ip-pool 192.168.87.90 static-bind ip-address 192.168.87.90 mask 255.255.255.224 static-bind mac-address b083-fe5e-531a gateway-list 192.168.87.94 dns-list 192.168.75.1 domain-name abc.com nbns-list 192.168.75.1 # dhcp server ip-pool 192.168.87.91 static-bind ip-address 192.168.87.91 mask 255.255.255.224 static-bind mac-address b083-fe5c-ef2a gateway-list 192.168.87.94 dns-list 192.168.75.1 domain-name abc.com nbns-list 192.168.75.1 # dhcp server ip-pool 192.168.87.92 static-bind ip-address 192.168.87.92 mask 255.255.255.224 static-bind mac-address b083-fe5e-57f1 gateway-list 192.168.87.94 dns-list 192.168.75.1 domain-name abc.com nbns-list 192.168.75.1 # dhcp server ip-pool 192.168.87.93 static-bind ip-address 192.168.87.93 mask 255.255.255.224 static-bind mac-address b083-fe5c-ed1b gateway-list 192.168.87.94 dns-list 192.168.75.1 domain-name abc.com nbns-list 192.168.75.1 # dhcp server ip-pool boardroom_760 network 192.168.84.64 mask 255.255.255.192 gateway-list 192.168.84.126 dns-list 192.168.75.1 192.168.75.2 domain-name abc.com nbns-list 192.168.75.1 # dhcp server ip-pool hxq-jtwpc17 static-bind ip-address 192.168.78.96 mask 255.255.255.192 static-bind mac-address b083-fe5e-579d gateway-list 192.168.78.126 dns-list 192.168.75.1 192.168.75.2 domain-name abc.com nbns-list 192.168.75.1 # dhcp server ip-pool hzy-jtwpc30 static-bind ip-address 192.168.78.119 mask 255.255.255.192 static-bind mac-address b083-fe5e-5397 gateway-list 192.168.78.126 dns-list 192.168.75.1 192.168.75.2 domain-name abc.com nbns-list 192.168.75.1 # dhcp server ip-pool jtwpc01_hjr static-bind ip-address 192.168.77.86 mask 255.255.255.224 static-bind mac-address 74e6-e2d7-9466 gateway-list 192.168.77.94 dns-list 192.168.75.1 192.168.75.2 domain-name abc.com nbns-list 192.168.75.1 # dhcp server ip-pool jtwpc02_xnj static-bind ip-address 192.168.77.89 mask 255.255.255.224 static-bind mac-address b083-fe5e-595f gateway-list 192.168.77.94 dns-list 192.168.75.1 192.168.75.2 domain-name abc.com nbns-list 192.168.75.1 # dhcp server ip-pool jtwpc03_yl static-bind ip-address 192.168.77.85 mask 255.255.255.224 static-bind mac-address b083-fe5e-5338 gateway-list 192.168.77.94 dns-list 192.168.75.1 192.168.75.2 domain-name abc.com nbns-list 192.168.75.1 # dhcp server ip-pool jtwpc05_hpf static-bind ip-address 192.168.77.87 mask 255.255.255.224 static-bind mac-address b083-fe5e-5c1a gateway-list 192.168.77.94 dns-list 192.168.75.1 192.168.75.2 domain-name abc.com nbns-list 192.168.75.1 # dhcp server ip-pool jtwpc08 static-bind ip-address 192.168.81.93 mask 255.255.255.224 static-bind mac-address b083-fe5c-efaf gateway-list 192.168.81.94 dns-list 192.168.75.1 192.168.75.2 domain-name abc.com nbns-list 192.168.75.1 # dhcp server ip-pool jtwpc24_zsj static-bind ip-address 192.168.77.84 mask 255.255.255.224 static-bind mac-address b083-fe5c-f077 gateway-list 192.168.77.94 dns-list 192.168.75.1 192.168.75.2 domain-name abc.com nbns-list 192.168.75.1 # dhcp server ip-pool jtwpc30_zxh static-bind ip-address 192.168.77.88 mask 255.255.255.224 static-bind mac-address b083-fe5c-ec37 gateway-list 192.168.77.94 dns-list 192.168.75.1 192.168.75.2 domain-name abc.com nbns-list 192.168.75.1 # dhcp server ip-pool outside_758 network 192.168.182.0 mask 255.255.255.128 gateway-list 192.168.182.126 dns-list 192.168.75.1 192.168.75.2 domain-name abc.com nbns-list 192.168.75.1 # dhcp server ip-pool outside_764 network 192.168.88.0 mask 255.255.255.128 gateway-list 192.168.88.126 dns-list 192.168.75.1 192.168.75.2 domain-name abc.com nbns-list 192.168.75.1 # dhcp server ip-pool outside_765 network 192.168.91.0 mask 255.255.255.128 gateway-list 192.168.91.126 dns-list 192.168.75.1 192.168.75.2 domain-name abc.com nbns-list 192.168.75.1 # dhcp server ip-pool plc-pc static-bind ip-address 192.168.83.73 mask 255.255.255.240 static-bind mac-address 4437-e68d-22a1 gateway-list 192.168.83.78 dns-list 192.168.75.1 192.168.75.2 domain-name abc.com nbns-list 192.168.75.1 # dhcp server ip-pool print_753 static-bind ip-address 192.168.77.90 mask 255.255.255.224 static-bind mac-address 0015-999c-4cfa gateway-list 192.168.77.94 dns-list 192.168.75.1 domain-name abc.com nbns-list 192.168.75.1 # dhcp server ip-pool ylh-note static-bind ip-address 192.168.81.92 mask 255.255.255.224 static-bind mac-address b46d-8355-3647 gateway-list 192.168.81.94 dns-list 192.168.75.1 192.168.75.2 domain-name abc.com nbns-list 192.168.75.1 # dhcp server ip-pool ylhiphone static-bind ip-address 192.168.81.91 mask 255.255.255.224 static-bind mac-address 0cd7-4650-cda5 gateway-list 192.168.81.94 dns-list 192.168.75.1 192.168.75.2 domain-name abc.com nbns-list 192.168.75.1 # dhcp server ip-pool zktec static-bind ip-address 192.168.81.88 mask 255.255.255.224 static-bind mac-address 0017-6110-8918 gateway-list 192.168.81.94 dns-list 192.168.75.1 192.168.75.2 domain-name abc.com nbns-list 192.168.75.1 # policy-based-route Video permit node 10 if-match acl 3901 apply ip-precedence routine apply ip-address next-hop 192.168.90.33 # user-group system group-attribute allow-guest # local-user admin password cipher $c$3$2NOwOYqwfeUohFfJxkRy7UqggvuWOmyFUmRu authorization-attribute level 3 service-type telnet service-type web # ssl server-policy access-policy # cwmp undo cwmp enable # interface Bridge-Aggregation1 port link-type trunk undo port trunk permit vlan 1 port trunk permit vlan 751 to 752 757 link-aggregation mode dynamic # interface NULL0 # interface Vlan-interface751 ip address 192.168.75.14 255.255.255.240 arp send-gratuitous-arp interval 2000 # interface Vlan-interface752 ip address 192.168.76.78 255.255.255.248 arp send-gratuitous-arp interval 2000 # interface Vlan-interface753 ip address 192.168.77.94 255.255.255.224 qos apply policy V753_Uplink inbound arp send-gratuitous-arp interval 2000 # interface Vlan-interface754 ip address 192.168.78.126 255.255.255.192 qos apply policy V754_Uplink inbound arp send-gratuitous-arp interval 2000 # interface Vlan-interface755 ip address 192.168.79.126 255.255.255.128 qos apply policy V755_Uplink inbound arp send-gratuitous-arp interval 2000 # interface Vlan-interface756 ip address 192.168.80.78 255.255.255.248 qos apply policy V756_Uplink inbound arp send-gratuitous-arp interval 2000 # interface Vlan-interface757 ip address 192.168.81.94 255.255.255.224 qos apply policy V757_Uplink inbound arp send-gratuitous-arp interval 2000 ip policy-based-route Video # interface Vlan-interface758 ip address 192.168.182.126 255.255.255.128 qos apply policy V758_Uplink inbound arp send-gratuitous-arp interval 2000 # interface Vlan-interface759 ip address 192.168.83.78 255.255.255.240 arp send-gratuitous-arp interval 2000 # interface Vlan-interface760 ip address 192.168.84.126 255.255.255.192 qos apply policy V760_Uplink inbound arp send-gratuitous-arp interval 2000 # interface Vlan-interface761 ip address 192.168.85.126 255.255.255.128 # interface Vlan-interface763 ip address 192.168.87.94 255.255.255.224 qos apply policy V763_Uplink inbound arp send-gratuitous-arp interval 2000 # interface Vlan-interface764 ip address 192.168.88.126 255.255.255.128 qos apply policy V764_Uplink inbound # interface Vlan-interface765 ip address 192.168.91.126 255.255.255.128 qos apply policy V765_Uplink inbound # interface GigabitEthernet0/0 port link-mode route nat outbound 3903 address-group 2 ip address 192.168.90.34 255.255.255.248 # interface GigabitEthernet0/1 port link-mode route nat outbound 3903 address-group 1 nat server 1 protocol tcp global current-interface 9000 inside 192.168.81.93 www ip address dhcp-alloc arp send-gratuitous-arp interval 2000 # interface GigabitEthernet0/2 port link-mode bridge port link-type trunk undo port trunk permit vlan 1 port trunk permit vlan 751 to 752 757 port link-aggregation group 1 # interface GigabitEthernet0/3 port link-mode bridge port link-type trunk undo port trunk permit vlan 1 port trunk permit vlan 751 to 752 757 port link-aggregation group 1 # interface GigabitEthernet0/4 port link-mode bridge port link-type trunk undo port trunk permit vlan 1 port trunk permit vlan 2 to 4094 # ospf 1 import-route static # vd Root id 1 # zone name Management id 0 priority 100 zone name Local id 1 priority 100 zone name Trust id 2 priority 85 import interface Vlan-interface751 import interface Vlan-interface753 import interface Vlan-interface754 import interface Vlan-interface755 import interface Vlan-interface756 import interface Vlan-interface757 import interface Vlan-interface759 import interface Vlan-interface760 import interface Vlan-interface763 zone name DMZ id 3 priority 50 import interface Vlan-interface752 import interface Vlan-interface761 zone name Untrust id 4 priority 5 import interface GigabitEthernet0/0 import interface GigabitEthernet0/1 zone name DMZ2 id 5 priority 45 import interface Vlan-interface758 import interface Vlan-interface764 import interface Vlan-interface765 switchto vd Root object network subnet 178.77.120.100/0.0.0.0 subnet 178.77.120.100 0.0.0.0 object network subnet 192.168.182.0/0.0.0.127 subnet 192.168.182.0 0.0.0.127 object network subnet 192.168.75.1/0.0.0.0 subnet 192.168.75.1 0.0.0.0 object network subnet 192.168.75.4/0.0.0.15 subnet 192.168.75.4 0.0.0.15 object network subnet 192.168.76.72/0.0.0.7 subnet 192.168.76.72 0.0.0.7 object network subnet 192.168.76.73/0.0.0.7 subnet 192.168.76.73 0.0.0.7 object network subnet 192.168.78.119/0.0.0.0 subnet 192.168.78.119 0.0.0.0 object network subnet 192.168.78.64/0.0.0.63 subnet 192.168.78.64 0.0.0.63 object network subnet 192.168.80.72/0.0.0.7 subnet 192.168.80.72 0.0.0.7 object network subnet 192.168.81.64 subnet 192.168.81.64 0.0.0.15 object network subnet 192.168.81.64/0.0.0.15 subnet 192.168.81.64 0.0.0.15 object network subnet 192.168.81.64/0.0.0.31 subnet 192.168.81.64 0.0.0.31 object network subnet 192.168.81.67/0.0.0.0 subnet 192.168.81.67 0.0.0.0 object network subnet 192.168.83.64/0.0.0.15 subnet 192.168.83.64 0.0.0.31 object network subnet 192.168.83.64/0.0.0.31 subnet 192.168.83.64 0.0.0.31 object network subnet 192.168.83.65/0.0.0.0 subnet 192.168.83.65 0.0.0.0 object network subnet 192.168.83.66/0.0.0.0 subnet 192.168.83.66 0.0.0.0 object network subnet 192.168.83.72/0.0.0.7 subnet 192.168.83.72 0.0.0.7 object network subnet 192.168.83.73/0.0.0.0 subnet 192.168.83.73 0.0.0.0 object network subnet 192.168.83.74/0.0.0.0 subnet 192.168.83.74 0.0.0.0 object network subnet 192.168.83.75/0.0.0.0 subnet 192.168.83.75 0.0.0.0 object network subnet 192.168.85.0/0.0.0.127 subnet 192.168.85.0 0.0.0.127 object network subnet 192.168.85.100/0.0.0.0 subnet 192.168.85.100 0.0.0.0 object network subnet 192.168.88.0/0.0.0.127 subnet 192.168.88.0 0.0.0.127 object network subnet 192.168.90.0/0.0.0.255 subnet 192.168.90.0 0.0.0.255 object network subnet 192.168.90.72/0.0.0.7 subnet 192.168.90.72 0.0.0.7 object network subnet 192.168.91.0/0.0.0.127 subnet 192.168.91.0 0.0.0.127 object network subnet 218.85.36.216/0.0.0.0 subnet 218.85.36.216 0.0.0.0 object network subnet 220.181.72.229/0.0.0.0 subnet 220.181.72.229 0.0.0.0 object network subnet dmzvideo subnet 192.168.85.0 0.0.0.127 object network host msaweb host address 218.85.36.216 host address 220.181.72.229 object network host pass81 host address 192.168.81.90 host address 192.168.81.91 host address 192.168.81.92 host address 192.168.81.93 object network range qq_111.161.52.151 range 111.161.52.151 111.161.52.158 object network range qq_111.161.52.18 range 111.161.52.18 111.161.52.18 object network range qq_111.161.88.16 range 111.161.88.16 111.161.88.31 object network range qq_111.161.88.42 range 111.161.88.42 111.161.88.50 object network range qq_111.161.88.75 range 111.161.88.75 111.161.88.81 object network range qq_111.30.131.159 range 111.30.131.159 111.30.131.159 object network range qq_111.30.131.168 range 111.30.131.168 111.30.131.175 object network range qq_111.30.131.179 range 111.30.131.179 111.30.131.194 range exclude 111.30.131.190 range exclude 111.30.131.191 range exclude 111.30.131.192 range exclude 111.30.131.193 object network range qq_112.95.240.10 range 112.95.240.10 112.95.240.13 range exclude 112.95.240.11 range exclude 112.95.240.12 object network range qq_112.95.240.120 range 112.95.240.120 112.95.240.125 range exclude 112.95.240.122 range exclude 112.95.240.124 object network range qq_112.95.240.185 range 112.95.240.185 112.95.240.185 object network range qq_112.95.240.22 range 112.95.240.22 112.95.240.26 range exclude 112.95.240.24 range exclude 112.95.240.25 object network range qq_112.95.240.38 range 112.95.240.38 112.95.240.39 object network range qq_112.95.240.47 range 112.95.240.47 112.95.240.52 range exclude 112.95.240.51 object network range qq_112.95.240.61 range 112.95.240.61 112.95.240.61 object network range qq_112.95.240.69 range 112.95.240.69 112.95.240.69 object network range qq_112.95.240.89 range 112.95.240.89 112.95.240.106 range exclude 112.95.240.90 range exclude 112.95.240.91 range exclude 112.95.240.93 range exclude 112.95.240.95 range exclude 112.95.240.97 range exclude 112.95.240.98 range exclude 112.95.240.100 range exclude 112.95.240.103 range exclude 112.95.240.105 object network range qq_112.95.242.102 range 112.95.242.102 112.95.242.102 object network range qq_119.147.32.203 range 119.147.32.203 119.147.32.203 object network range qq_119.147.32.233 range 119.147.32.233 119.147.32.236 range exclude 119.147.32.234 object network range qq_120.196.212.74 range 120.196.212.74 120.196.212.74 object network range qq_120.196.212.87 range 120.196.212.87 120.196.212.87 object network range qq_120.196.212.94 range 120.196.212.94 120.196.212.94 object network range qq_123.151.13.111 range 123.151.13.111 123.151.13.112 object network range qq_123.151.13.160 range 123.151.13.160 123.151.13.169 range exclude 123.151.13.163 range exclude 123.151.13.167 object network range qq_123.151.13.45 range 123.151.13.45 123.151.13.50 range exclude 123.151.13.46 range exclude 123.151.13.47 object network range qq_123.151.13.78 range 123.151.13.78 123.151.13.79 object network range qq_123.151.40.105 range 123.151.40.105 123.151.40.105 object network range qq_123.151.40.161 range 123.151.40.161 123.151.40.163 object network range qq_123.151.40.180 range 123.151.40.180 123.151.40.191 range exclude 123.151.40.181 range exclude 123.151.40.182 range exclude 123.151.40.184 range exclude 123.151.40.186 range exclude 123.151.40.188 object network range qq_123.151.40.24 range 123.151.40.24 123.151.40.25 object network range qq_123.151.47.49 range 123.151.47.49 123.151.47.49 object network range qq_123.151.47.81 range 123.151.47.81 123.151.47.81 object network range qq_123.151.47.91 range 123.151.47.91 123.151.47.91 object network range qq_125.39.205.25 range 125.39.205.25 125.39.205.27 object network range qq_125.39.205.32 range 125.39.205.32 125.39.205.34 range exclude 125.39.205.33 object network range qq_125.39.205.42 range 125.39.205.42 125.39.205.44 range exclude 125.39.205.43 object network range qq_163.177.87.198 range 163.177.87.198 163.177.87.204 range exclude 163.177.87.200 object network range qq_163.177.90.222 range 163.177.90.222 163.177.90.222 object network range qq_183.232.127.124 range 183.232.127.124 183.232.127.124 object network range qq_183.232.127.241 range 183.232.127.241 183.232.127.247 object network range qq_183.232.93.22 range 183.232.93.22 183.232.93.29 object network range qq_183.232.94.212 range 183.232.94.212 183.232.94.212 object network range qq_183.57.50.108 range 183.57.50.108 183.57.50.108 object network range qq_183.60.19.148 range 183.60.19.148 183.60.19.151 range exclude 183.60.19.149 object network range qq_183.60.19.166 range 183.60.19.166 183.60.19.176 range exclude 183.60.19.168 range exclude 183.60.19.169 range exclude 183.60.19.170 range exclude 183.60.19.171 range exclude 183.60.19.172 object network range qq_183.60.19.20 range 183.60.19.20 183.60.19.22 range exclude 183.60.19.21 object network range qq_183.60.19.35 range 183.60.19.35 183.60.19.35 object network range qq_183.60.19.40 range 183.60.19.40 183.60.19.41 object network range qq_183.60.19.50 range 183.60.19.50 183.60.19.50 object network range qq_183.60.19.76 range 183.60.19.76 183.60.19.76 object network range qq_183.60.48.250 range 183.60.48.250 183.60.48.250 object network range qq_183.60.49.182 range 183.60.49.182 183.60.49.182 object network range qq_183.60.50.23 range 183.60.50.23 183.60.50.25 range exclude 183.60.50.24 object network range qq_183.60.56.14 range 183.60.56.14 183.60.56.23 range exclude 183.60.56.16 range exclude 183.60.56.20 object network range qq_183.60.56.92 range 183.60.56.92 183.60.56.102 range exclude 183.60.56.94 range exclude 183.60.56.96 range exclude 183.60.56.100 object network range qq_220.249.245.150 range 220.249.245.150 220.249.245.156 object network host tv host address 63.80.4.163 host address 63.80.4.187 host address 63.80.4.208 host address 63.80.4.216 host address 63.80.4.217 host address 101.96.10.71 host address 106.38.190.245 host address 218.6.23.37 host address 222.73.145.34 object service msawebport service tcp source-port 0 destination-port 9080 object service qqtcp443 service tcp destination-port 443 object service qqtcp80 service tcp destination-port 80 object service qqudp service udp destination-port 8000 object service tcp_from_445 service tcp source-port 445 object service tcp_to_445 service tcp destination-port 445 object service udp_from_445 service udp source-port 445 object service udp_to_445 service udp destination-port 445 object-group network qq object-group network qq network-object qq_111.161.52.151 network-object qq_111.161.52.18 network-object qq_111.161.88.16 network-object qq_111.161.88.42 network-object qq_111.161.88.75 network-object qq_111.30.131.159 network-object qq_111.30.131.179 network-object qq_112.95.240.10 network-object qq_112.95.240.120 network-object qq_112.95.240.22 network-object qq_112.95.240.38 network-object qq_111.30.131.168 network-object qq_112.95.240.185 network-object qq_112.95.240.61 network-object qq_112.95.240.69 network-object qq_112.95.240.89 network-object qq_112.95.242.102 network-object qq_119.147.32.203 network-object qq_119.147.32.233 network-object qq_112.95.240.47 network-object qq_120.196.212.74 network-object qq_120.196.212.94 network-object qq_123.151.13.111 network-object qq_120.196.212.87 network-object qq_123.151.13.78 network-object qq_123.151.13.160 network-object qq_123.151.13.45 network-object qq_123.151.40.105 network-object qq_220.249.245.150 network-object qq_183.60.48.250 network-object qq_183.60.19.40 network-object qq_183.60.19.35 network-object qq_183.60.19.166 network-object qq_183.57.50.108 network-object qq_183.232.94.212 network-object qq_183.232.127.241 network-object qq_183.232.127.124 network-object qq_163.177.90.222 network-object qq_163.177.87.198 network-object qq_125.39.205.42 network-object qq_125.39.205.32 network-object qq_183.232.93.22 network-object qq_123.151.47.91 network-object qq_123.151.47.81 network-object qq_125.39.205.25 network-object qq_123.151.47.49 network-object qq_123.151.40.180 network-object qq_123.151.40.161 network-object qq_183.60.56.92 network-object qq_183.60.19.50 network-object qq_183.60.19.148 network-object qq_183.60.19.20 network-object qq_123.151.40.24 network-object qq_183.60.49.182 network-object qq_183.60.19.76 network-object qq_183.60.56.14 network-object qq_183.60.50.23 zone name Management id 0 ip virtual-reassembly zone name Local id 1 ip virtual-reassembly zone name Trust id 2 flow-statistics enable source-ip flow-statistics enable destination-ip flow-statistics enable inbound flow-statistics enable outbound ip virtual-reassembly zone name DMZ id 3 ip virtual-reassembly zone name Untrust id 4 flow-statistics enable source-ip flow-statistics enable destination-ip flow-statistics enable inbound flow-statistics enable outbound ip virtual-reassembly zone name DMZ2 id 5 ip virtual-reassembly interzone source Trust destination DMZ firewall aspf enable interzone source Trust destination Untrust firewall aspf enable rule 16 deny logging source-ip any_address destination-ip any_address service tcp_to_445 service udp_to_445 rule enable rule 14 permit source-ip pass81 destination-ip any_address service any_service rule 13 permit source-ip 192.168.78.119/0.0.0.0 destination-ip any_address service any_service rule 12 deny source-ip 192.168.182.0/0.0.0.127 destination-ip any_address service any_service rule 11 deny source-ip 192.168.80.72/0.0.0.7 destination-ip any_address service any_service rule 10 deny source-ip 192.168.88.0/0.0.0.127 destination-ip any_address service any_service rule 9 deny source-ip 192.168.91.0/0.0.0.127 destination-ip any_address service any_service rule 18 permit source-ip 192.168.78.64/0.0.0.63 destination-ip msaweb service any_service rule 8 deny source-ip 192.168.78.64/0.0.0.63 destination-ip any_address service any_service rule 4 deny source-ip 192.168.81.64/0.0.0.31 destination-ip any_address service any_service rule 17 permit source-ip 192.168.83.66/0.0.0.0 destination-ip msaweb service any_service rule enable rule 7 permit source-ip 192.168.83.73/0.0.0.0 destination-ip any_address service any_service rule enable rule 3 permit source-ip 192.168.83.65/0.0.0.0 destination-ip any_address service any_service rule enable rule 2 deny source-ip 192.168.83.64/0.0.0.31 destination-ip any_address service any_service rule enable rule 0 permit source-ip any_address destination-ip any_address service any_service rule enable interzone source DMZ destination Trust rule 0 permit source-ip 192.168.76.73/0.0.0.7 destination-ip 192.168.75.4/0.0.0.15 service any_service rule enable rule 2 permit source-ip any_address destination-ip any_address service any_service rule enable interzone source DMZ destination Untrust rule 4 deny source-ip any_address destination-ip any_address service tcp_to_445 service udp_to_445 rule enable rule 3 permit source-ip 192.168.85.100/0.0.0.0 destination-ip any_address service any_service rule 2 deny source-ip dmzvideo destination-ip any_address service any_service rule enable rule 0 permit source-ip any_address destination-ip any_address service any_service rule enable interzone source Untrust destination Trust rule 0 permit logging source-ip any_address destination-ip any_address service any_service rule enable interzone source Untrust destination DMZ rule 0 permit source-ip any_address destination-ip any_address service any_service rule enable interzone source DMZ2 destination Trust rule 0 permit source-ip any_address destination-ip 192.168.75.1/0.0.0.0 service dns-tcp service dns-udp rule enable interzone source DMZ2 destination Untrust rule 0 permit source-ip any_address destination-ip any_address service any_service rule enable interzone source Any destination Any content-filtering keyword-entry 影视过滤 keyword fix-string 优酷 keyword fix-string 百度影音 content-filtering url-hostname-entry youku url-hostname fix-string www.youku.com content-filtering http-policy HTTP url-filtering url-hostname-entry youku head-filtering keyword-entry 影视过滤 body-filtering keyword-entry 影视过滤 url-ip-blocking enable url-parameter-filtering enable activex-blocking enable java-applet-blocking enable logging enable content-filtering policy-template http http-policy HTTP # connection-limit apply policy 0 # ssl-vpn server-policy access-policy # ip route-static 0.0.0.0 0.0.0.0 GigabitEthernet0/1 192.168.90.73 ip route-static 0.0.0.0 0.0.0.0 GigabitEthernet0/0 192.168.90.33 preference 61 # dhcp server forbidden-ip 192.168.75.1 192.168.75.7 dhcp server forbidden-ip 192.168.75.14 dhcp server forbidden-ip 192.168.77.94 dhcp server forbidden-ip 192.168.80.78 dhcp server forbidden-ip 192.168.81.78 dhcp server forbidden-ip 192.168.82.78 dhcp server forbidden-ip 192.168.83.78 dhcp server forbidden-ip 192.168.84.78 dhcp server forbidden-ip 192.168.76.78 dhcp server forbidden-ip 192.168.76.73 192.168.76.74 dhcp server forbidden-ip 192.168.85.65 192.168.85.66 dhcp server forbidden-ip 192.168.85.78 dhcp server forbidden-ip 192.168.87.77 192.168.87.78 dhcp server forbidden-ip 192.168.79.125 192.168.79.126 dhcp server detect # dhcp enable # ntp-service source-interface GigabitEthernet0/1 ntp-service unicast-server 210.75.145.44 # ip https ssl-server-policy access-policy ip https enable # load xml-configuration # load tr069-configuration # user-interface con 0 user-interface vty 0 4 authentication-mode scheme # return
ryoue 发表时间:2017-07-13
因为在Video这个接口上应用了策略路由,导致符合acl3901的所有报文都送到192.168.90.33这个下一跳了。建议修改一下3901这个ACL,改成:
 acl number 3901
rule 0 deny ip  source 192.168.81.64 0.0.0.31 destination 192.168.0.0 0.0.255.255
 rule 10 deny ip
增加的rule0是把访问内网网段(我看都是192.168.X.X)的deny掉,这样Video子网访问其他内部的子网时,就不会匹配策略路由,而是直接查路由表转,就可以直接通了。
这里还有两个问题,需要补充解释一下:
1、为什么走策略路由后不通?这是因为防火墙外部设备收到这个报文后,发现报文的目的地址是内部某个子网的,是私网地址,查路由表发现没有路由,只能丢掉了。
2、为什么其他子网能访问Video子网?
因为其他子网访问Video子网时,是通过查路由来实现的,所有从其他子网到Video子网是OK的。而Video子网的回包到了防火墙后,匹配了session,就直接查session转发了。
你这问题很麻烦,因为走两个不同的链路所以内部子网肯定不同,在原有策略路由的ACL上写上内网互相访问的规则,然后匹配的时候先匹配内网互访的策略,再匹配走不同出口的策略。
FY命运7 知了小白
策略路由的使用时调用的ACL需要先写优先级高的deny内网互访的网段,不然内网互访时候匹配到策略路由,重另一个接口扔出去了
