H3C 模拟器 做IRF堆叠起不来,配置跟拓扑如下,请问问题出在哪里
2017-07-17提问
  • 2关注
  • 1收藏,9423浏览
堆叠做不起来
拓扑如下
switch1 通过XGE 1/0/49 链接 switch2 XGE 1/0/52
switch1 通过XGE 1/0/50 链接 switch2 XGE 1/0/51
switch1 配置
sys
irf member 1 priority 31
interface range  Ten-GigabitEthernet 1/0/49 to Ten-GigabitEthernet 1/0/50
shutdwon
exit
irf-port 1/1
port group interface Ten-GigabitEthernet 1/0/49
port group interface Ten-GigabitEthernet 1/0/50
exit
exit
irf-port-configuration active
switch2配置
sys
irf member 1 renumber 2
exit save
reboot
sys
interface range  Ten-GigabitEthernet 2/0/51 to Ten-GigabitEthernet 2/0/52
shutdwon
exit
irf-port 2/2
port group interface Ten-GigabitEthernet 2/0/51
port group interface Ten-GigabitEthernet 2/0/52
exit
undo shutdwon
exit
-5861 四段
粉丝:3人 关注:0人
slave 设备在激活之前需要保存。否则激活后,设备重启,irf-port配置丢失,导致堆叠失败。
我先保存了下然后在激活,还是不行。
zhiliao_30921 发表时间:2017-07-17
我按照您的方法试了一下,可以了。但是只有一个链路是起来,2个口只有一个起来了。另一个是DOWN的请问怎么破?
回复zhiliao_30921:
确认堆叠口是up的吗?
-5861 发表时间:2017-07-18
5 个回答
粉丝:20人 关注:3人
激活之前保存了吗?堆叠口是up的吗
堆叠起来了,一个跟线是通的一根是DOWN的。
shutdwon   //shutdown不对啊,你可以试一试把irf-port改成1/2和2/1试一试
zhiliao_29323 知了小白
(2台S5820V2-54QS)堆叠成功以下供参考
<sw01>dis cu
 version 7.1.075, Alpha 7571
 sysname sw01
 irf mac-address persistent timer
 irf auto-update enable
 undo irf link-delay
 irf member 1 priority 32
 irf member 2 priority 1
 lldp global enable
 system-working-mode standard
 xbar load-single
 password-recovery enable
 lpu-type f-series
vlan 1
vlan 3
vlan 10 to 11
irf-port 1/1
 port group interface Ten-GigabitEthernet1/0/49
 port group interface Ten-GigabitEthernet1/0/50
irf-port 2/2
 port group interface Ten-GigabitEthernet2/0/49
 port group interface Ten-GigabitEthernet2/0/50
interface Bridge-Aggregation1
 port link-type trunk
 undo port trunk permit vlan 1
 port trunk permit vlan 2 to 4094
interface Bridge-Aggregation2
interface NULL0
interface Vlan-interface3
 mad bfd enable
 mad ip address 10.100.10.1 255.255.255.0 member 1
 mad ip address 10.100.10.2 255.255.255.0 member 2
interface Vlan-interface10
 ip address 10.220.10.1 255.255.255.0
interface Vlan-interface11
 ip address 10.220.11.1 255.255.255.0
interface FortyGigE1/0/53
 port link-mode bridge
interface FortyGigE1/0/54
interface FortyGigE2/0/53
interface FortyGigE2/0/54
 port access vlan 3
 combo enable copper
 undo stp enable
 combo enable copper
 port link-aggregation group 2
 combo enable copper
 port link-aggregation group 1
interface GigabitEthernet1/0/4
 combo enable copper
interface GigabitEthernet1/0/5
 combo enable copper
interface GigabitEthernet1/0/6
 combo enable copper
interface GigabitEthernet1/0/7
 combo enable copper
interface GigabitEthernet1/0/8
 combo enable copper
interface GigabitEthernet1/0/9
---- More ----
400 知了小白
第一台
配置成员优先级(irf member 1 priority x)
关闭irf物理端口(shutdown)
创建irf端口并绑定irf物理端口(port group interface Ten-GigabitEthernet x/x/x)
开启irf物理端口(undo shutdown)
保存(save)
重启(reboot)
激活irf(irf-port-configuration active)
第二台
配置成员编号(irf member 1 renumber x)
重启后生效(reboot)
关闭irf物理端口(shutdown)
保存(save)
重启(reboot)
接线
irf开始合并选举失败一方将自动重启
模拟器先接线再配置合并时会报错irf端口故障,而且irf物理端口会一直down
配置完成后端口不UP,需要保存后重启模拟器才可以堆叠成功。
zhiliao_eDNVb 发表时间:2019-11-24
BAD 知了小白
我配置的irf经常端口是超时
