MSR810 上做NQA和track 联动,无法生效!
2020-09-17提问
  • 1收藏,1057浏览
在810上做了双出口线路,并做了NQA和track联动,发现无法主动触发联动,只能在手动断开主线路才能切换到备线路!
配置如下:
track 1 nqa entry vpn to_suguo reaction 1
  type icmp-echo
  destination ip 129.100.253.48
  frequency 100
  reaction 1 checked-element probe-fail threshold-type consecutive 5 action-type trap-only
  source ip 123.100.5.254
nqa schedule vpn to_suguo start-time now lifetime forever
 ip route-static 0.0.0.0 0 GigabitEthernet0/4 dhcp preference 65
 ip route-static 0.0.0.0 0 GigabitEthernet0/0 192.168.137.1 track 1
粉丝:15人 关注:0人
  reaction 1 checked-element probe-fail threshold-type consecutive 5 action-type trap-only  修改成trigger-only
为什么msr810不能配置trigger-only? 只有trap-only 和none两种状态。
zhiliao_PNIfQv 发表时间:2021-09-27
粉丝:124人 关注:6人
以下是NQA的配置脚本,请参考:
[SW2]nqa agent enable
[SW2]nqa entry weijianing ninglihua
[SW2-nqa-weijianing-ninglihua]type icmp-echo
[SW2-nqa-weijianing-ninglihua-icmp-echo]source int GigabitEthernet 1/0/1
[SW2-nqa-weijianing-ninglihua-icmp-echo]destination ip 10.0.0.2
[SW2-nqa-weijianing-ninglihua-icmp-echo]frequency 100000
[SW2-nqa-weijianing-ninglihua-icmp-echo]probe timeout 30
[SW2-nqa-weijianing-ninglihua-icmp-echo]next-hop 10.0.0.2
[SW2-nqa-weijianing-ninglihua-icmp-echo] history-record enable
[SW2-nqa-weijianing-ninglihua-icmp-echo]history-record number 50
[SW2-nqa-weijianing-ninglihua-icmp-echo]probe count 10
[SW2-nqa-weijianing-ninglihua-icmp-echo]reaction 1 checked-element probe-fail threshold-type consecutive 1 action-type trigger-only
[SW2-nqa-weijianing-ninglihua-icmp-echo]route-option bypass-route
[SW2]track 1 nqa entry weijianing ninglihua reaction 1
[SW2]nqa schedule weijianing ninglihua start-time now lifetime forever
关于NQA不生效,以下是排查要点,请参考:
1、确保目的监控的IP路由可达,且可以PING通。
2、设置下源IP看下。
3、将 action-type 的trap-only  修改成trigger-only
粉丝:3人 关注:1人
在NAQ定义你的下一跳(next-hop xxx.xxx.x.x)和超时判定(probe timeout ***),reaction 1最后的trap-only改成trigger-only
