在810上做了双出口线路,并做了NQA和track联动,发现无法主动触发联动,只能在手动断开主线路才能切换到备线路!
配置如下:
track 1 nqa entry vpn to_suguo reaction 1
type icmp-echo
destination ip 129.100.253.48
frequency 100
reaction 1 checked-element probe-fail threshold-type consecutive 5 action-type trap-only
source ip 123.100.5.254
nqa schedule vpn to_suguo start-time now lifetime forever
ip route-static 0.0.0.0 0 GigabitEthernet0/4 dhcp preference 65
ip route-static 0.0.0.0 0 GigabitEthernet0/0 192.168.137.1 track 1
(0)
以下是NQA的配置脚本,请参考:
[SW2]nqa agent enable
[SW2]nqa entry weijianing ninglihua
[SW2-nqa-weijianing-ninglihua]type icmp-echo
[SW2-nqa-weijianing-ninglihua-icmp-echo]source int GigabitEthernet 1/0/1
[SW2-nqa-weijianing-ninglihua-icmp-echo]destination ip 10.0.0.2
[SW2-nqa-weijianing-ninglihua-icmp-echo]frequency 100000
[SW2-nqa-weijianing-ninglihua-icmp-echo]probe timeout 30
[SW2-nqa-weijianing-ninglihua-icmp-echo]next-hop 10.0.0.2
[SW2-nqa-weijianing-ninglihua-icmp-echo] history-record enable
[SW2-nqa-weijianing-ninglihua-icmp-echo]history-record number 50
[SW2-nqa-weijianing-ninglihua-icmp-echo]probe count 10
[SW2-nqa-weijianing-ninglihua-icmp-echo]reaction 1 checked-element probe-fail threshold-type consecutive 1 action-type trigger-only
[SW2-nqa-weijianing-ninglihua-icmp-echo]route-option bypass-route
[SW2]track 1 nqa entry weijianing ninglihua reaction 1
[SW2]nqa schedule weijianing ninglihua start-time now lifetime forever
关于NQA不生效,以下是排查要点,请参考:
1、确保目的监控的IP路由可达,且可以PING通。
2、设置下源IP看下。
3、将 action-type 的trap-only 修改成trigger-only
(1)
在NAQ定义你的下一跳(next-hop xxx.xxx.x.x)和超时判定(probe timeout ***),reaction 1最后的trap-only改成trigger-only
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
为什么msr810不能配置trigger-only? 只有trap-only 和none两种状态。
