在设置msr路由器ppoe拨号,不行。
2020-09-20提问
  • 1收藏,2131浏览
<H3C>%Sep 20 14:48:13:031 2020 H3C IFNET/3/PHY_UPDOWN: Physical state on the interface Virtual-Access0 changed to up. %Sep 20 14:48:13:066 2020 H3C IFNET/5/LINK_UPDOWN: Line protocol state on the interface Virtual-Access0 changed to up. %Sep 20 14:48:14:138 2020 H3C IFNET/5/LINK_UPDOWN: Line protocol state on the interface Virtual-Access0 changed to down. %Sep 20 14:48:14:173 2020 H3C IFNET/3/PHY_UPDOWN: Physical state on the interface Virtual-Access0 changed to down. %Sep 20 14:48:19:531 2020 H3C IFNET/3/PHY_UPDOWN: Physical state on the interface Virtual-Access0 changed to up. %Sep 20 14:48:19:566 2020 H3C IFNET/5/LINK_UPDOWN: Line protocol state on the interface Virtual-Access0 changed to up. %Sep 20 14:48:20:638 2020 H3C IFNET/5/LINK_UPDOWN: Line protocol state on the interface Virtual-Access0 changed to down. %Sep 20 14:48:20:680 2020 H3C IFNET/3/PHY_UPDOWN: Physical state on the interface Virtual-Access0 changed to down. %Sep 20 14:48:26:031 2020 H3C IFNET/3/PHY_UPDOWN: Physical state on the interface Virtual-Access0 changed to up. %Sep 20 14:48:26:066 2020 H3C IFNET/5/LINK_UPDOWN: Line protocol state on the interface Virtual-Access0 changed to up. %Sep 20 14:48:27:136 2020 H3C IFNET/5/LINK_UPDOWN: Line protocol state on the interface Virtual-Access0 changed to down. %Sep 20 14:48:27:177 2020 H3C IFNET/3/PHY_UPDOWN: Physical state on the interface Virtual-Access0 changed to down.
,设置完了发现上不了网,而且还反复出现这些提示,看web也没获取到ip。
粉丝:15人 关注:0人
本电子书由CyberArticle制作。点击这里下载CyberArticle。注册版本不会显示该信息。  删除广告
MSR830-WiNet系列路由器基本上网(PPPOE)命令行配置V7
MSR830-WiNet系列路由器基本上网(PPPOE)命令行配置(V7 1
1 配置需求或说明 1
1.1 适用产品系列 1
1.2 配置需求及实现的效果 1
2 组网图 2
3 配置步骤 2
3.1 配置WAN接口地址 2
3.2 配置内网网关 2
3.3 设置DHCP 2
3.4 在拨号口配置NAT,实现内网地址上网进行源地址转换 3
3.5 配置默认路由 3
3.6 保存配置 3
1 配置需求或说明
1.1 适用产品系列
本案例适用于Comware V7平台的MSR830-WiNet系列路由器,如MSR830-10BEI-WiNet MSR830-6EI-WiNet MSR830-5BEI-WiNet MSR830-6BHI-WiNet MSR830-10BHI-WiNet
1.2 配置需求及实现效果
路由器作为企业网络的出口路由器,要实现WAN口配置PPPOE上网。此案例中,运营商给的PPPOE账户为abc,密码为123456内网地址段192.168.0.1/23运营商的DNS地址5.5.5.56.6.6.6,内网电脑要自动获取地址访问互联网
2 组网图
3 配置步骤
3.1 配置WAN接口地址
#配置拨号口,拨号的用户名为abc,密码为123456
<H3C>system-view
[H3C] dialer-group 1 rule ip permit
[H3C] interface dialer 1
[H3C-Dialer1] dialer bundle enable
[H3C-Dialer1] dialer-group 1
[H3C-Dialer1] ip address ppp-negotiate
[H3C-Dialer1] dialer timer idle 0
[H3C-Dialer1] ppp chap user abc
[H3C-Dialer1] ppp chap password simple 123456
[H3C-Dialer1] ppp pap local-user abc password simple 123456
[H3C-Dialer1] ppp ipcp dns admit-any
[H3C-Dialer1] ppp ipcp dns request
[H3C-Dialer1] quit
#拨号口绑定实际的物理接口
[H3C]interface GigabitEthernet 0/0
[H3C-GigabitEthernet0/0] pppoe-client dial-bundle-number 1
3.2 配置内网网关
#一般情况下Comware V7平台MSR830-WiNet系列路由器设备默认已经配置内网网关Vlan1地址为192.168.0.1/23,DHCP服务器已经默认开启,如果内网192.168.0.1/23网段,则不需配置这一步
<H3C>interface Vlan-interface1
[H3C-Vlan-interface1]ip address 192.168.0.1 255.255.254.0
[H3C-Vlan-interface1]quit
3.3 设置DHCP
#缺省情况下,DHCP服务器已经默认开启设备默认DHCP分配网段192.168.0.0/23,默认分配的DNS地址是网关地址192.168.0.1,如果局域网电脑需要自动获取IP地址和DNS地址上网,那就需要根据实际情况设置对应DHCP地址池的参数
<H3C>system-view
#进入系统缺省VLAN1DHCP地址池
[H3C]dhcp server ip-pool lan1
#配置要分配的地址网段
[H3C-dhcp-pool-lan1] network 192.168.0.0 mask 255.255.254.0
#配置客户端网关地址
[H3C-dhcp-pool-lan1]gateway-list 192.168.0.1
#修改下发的dns地址,此处填写运营商实际提供的DNS地址,可以设置一个,也可以设置多个
[H3C-dhcp-pool-lan1] dns-list 5.5.5.5 6.6.6.6
[H3C-dhcp-pool-lan1]quit
3.4 拨号口配置NAT,实现内网地址上网进行源地址转换
[H3C]interface Dialer 1
[H3C-Dialer1]nat outbound
[H3C]quit
3.5 配置默认路由
#默认路由下一跳地址配置运营商分配的网关地址
[H3C]ip route-static 0.0.0.0 0.0.0.0 Dialer 1
3.6 保存配置
[H3C]save force
注意电脑直连外网测试外网没问题
zhiliao_pdGY6 发表时间:2020-09-20
粉丝:124人 关注:6人
关于PPPOE拨号无法连接上的问题,以下是排查要点,请参考:
1、可尝试跳过路由器,电脑直接拨号看是否能上网,如果能上网,说明宽带的线路没有问题。
2、检查路由器上的PPPOE客户端的配置,以下是配置举例,请参考:
2.4  PPPoE Client典型配置举例
2.4.1  PPPoE Client典型举例
Router A和Router B之间通过各自的Ethernet1/1接口相连,其中Router A作为PPPoE Server,Router B作为PPPoE Client。
图2-4 PPPoE Client典型配置组网图
配置Router B作为PPPoE Client。
配置拨号访问组1以及对应的拨号访问控制条件。
<RouterB> system-view
[RouterB] dialer-group 1 rule ip permit
在Dialer1接口上使能共享DDR。
[RouterB] interface dialer 1
[RouterB-Dialer1] dialer bundle enable
将Dialer1接口与拨号访问组1关联。
[RouterB-Dialer1] dialer-group 1
[RouterB-Dialer1] quit
配置一个PPPoE会话,该会话对应Dialer bundle 1(Dialer bundle 1对应Dialer1接口)。
[RouterB] interface ethernet 1/1
[RouterB-Ethernet1/1] pppoe-client dial-bundle-number 1
[RouterB-Ethernet1/1] quit
配置PPPoE Client工作在永久在线模式。
[RouterB-Dialer1] dialer timer idle 0
配置DDR自动拨号的间隔时间为60秒。
[RouterB-Dialer1] dialer timer autodial 60
配置完成后,Router B就可以与远端的PPPoE Server建立PPPoE会话。
[RouterB-Dialer1] display pppoe-client session summary
Bundle ID    Interface    VA          RemoteMAC      LocalMAC       State
1      1     Eth1/1       VA0         00e0-1400-4300 00e0-1500-4100 SESSION
3、以下是PPPOE的用户手册连接,请参考:
https://www.h3c.com/cn/d_201405/829949_30005_0.htm#_Toc381197349
解决了吗解决了吗
