S7606远程管理ONU地址不通
2020-09-21提问
  • 1收藏,986浏览
[S7606-Vlan-interface221]quit
[S7606] [S7606]dis ve
[S7606]dis version
H3C Comware Software, Version 7.1.045, Release 7184 Copyright (c) 2004-2016 Hangzhou H3C Tech. Co., Ltd. All rights reserved. H3C S7606 uptime is 184 weeks, 6 days, 15 hours, 46 minutes Last reboot reason : Cold reboot Boot image: flash:/S7600-CMW710-BOOT-R7184.bin Boot image version: 7.1.045, Release 7184 Compiled Sep 09 2016 16:00:00 System image: flash:/S7600-CMW710-SYSTEM-R7184.bin System image version: 7.1.045, Release 7184 Compiled Sep 09 2016 16:00:00 MPU(M) 0: Uptime is 184 weeks,6 days,15 hours,46 minutes BOARD TYPE: LSQM3MPUB4 DRAM: 2048M bytes FLASH: 1024M bytes NVRAM: 1M bytes PCB 1 Version: VER.C Bootrom Version: 114 CPLD 1 Version: 002 PowChip Version: NONE Release Version: H3C S7606-7184 Patch Version : None Reboot Cause : ColdReboot MPU(S) 1: Uptime is 184 weeks,6 days,15 hours,53 minutes BOARD TYPE: LSQM3MPUB4 DRAM: 2048M bytes FLASH: 1024M bytes NVRAM: 1M bytes PCB 1 Version: VER.C Bootrom Version: 114 CPLD 1 Version: 002 PowChip Version: NONE Release Version: H3C S7606-7184 Patch Version : None Reboot Cause : ColdReboot LPU 2: Uptime is 183 weeks,5 days,21 hours,36 minutes BOARD TYPE: LSQM1PT24TSSC0 DRAM: 1024M bytes FLASH: 0M bytes NVRAM: 0K bytes PCB 1 Version: VER.A Bootrom Version: 106 CPLD 1 Version: 001 PowChip Version: NONE Release Version: H3C S7606-7184 Patch Version : None Reboot Cause : ColdReboot LPU 7: Uptime is 184 weeks,6 days,16 hours,35 minutes BOARD TYPE: LSQM2GT24PTSSC3 DRAM: 1024M bytes FLASH: 0M bytes NVRAM: 0K bytes PCB 1 Version: VER.A Bootrom Version: 106 CPLD 1 Version: 005 PowChip Version: NONE Release Version: H3C S7606-7184 Patch Version : None Reboot Cause : ColdReboot
 [S7606]int vlan 221
 [S7606-Vlan-interface221]dis th
# interface Vlan-interface221
 description onu管理
 ip address 172.172.121.1 255.255.255.0
# return
 [S7606-Vlan-interface221]int olt 2/0/14
 [S7606-Olt2/0/14]dis th
 # interface Olt2/0/14 description
上交岭地台
 using onu 1 to 13
 port link-type hybrid port hybrid vlan 1 100 to 103 105 to 106 108 112 116 to 125 128 201 to 202 204 to 205 207 to 208 tagged
 port hybrid vlan 213 216 221 2020 2878 tagged
# return
[S7606-Olt2/0/14]int onu 2/0/14:5
[S7606-Onu2/0/14:5]dis th
 description
 bind onu-id 9428-2ec3-e4ae
 management-vlan 221
 upstream-sla maximum-bandwidth 15625
 ip address 172.172.121.2 255.255.255.0 gateway 172.172.121.1
 uni 1 vlan-mode tag pvid 124
 uni 2 vlan-mode tag pvid 124
 uni 3 vlan-mode tag pvid 124
 uni 4 vlan-mode tag pvid 124
 port link-type trunk undo port trunk permit vlan 1
 port trunk permit vlan 2 to 4094
 port trunk pvid vlan 221
# return
 [S7606-Onu2/0/14:5]dis onu int
[S7606-Onu2/0/14:5]dis onu interface olt 2/0/14
 MAC LLID Dist(M)     Port Model/Version Sft/Epm State Aging
9428-2ec3-e4ae   Onu2/0/14:5          ET254-G-S/A 112/ Up N/A
[S7606-Vlan-interface221]ping 172.172.121.2
 Ping 172.172.121.2 (172.172.121.2): 56 data bytes, press CTRL_C to break Request time out Request time out Request time out Request time out Request time out --- Ping statistics for 172.172.121.2 --- 5 packet(s) transmitted, 0 packet(s) received, 100.0% packet loss
[S7606]dis version
 [S7606]int vlan 221
 description onu管理
# return
上交岭地台
 using onu 1 to 13
# return
 description
 management-vlan 221
# return
粉丝:111人 关注:1人
带源地址去ping了吗
9428-2ec3-e4ae 这个MAC配置是否正确?
带源用网关地址也是ping不通的,MAC怎么配置?olt下绑定的onu mac是正确的,onu都上线了
