为啥BFD DOWN?
2020-09-21提问
  • 1收藏,2189浏览
现场配置BFD与静态路由联动,由于BFD session down导致静态路由无法加表,配置如下:
 bfd echo-source-ip 10.0.112.249
interface Ten-GigabitEthernet1/1/0/22.10
 description connect-to-ZJ-9006
 ip binding vpn-instance 530
 ip address 10.0.112.249 255.255.255.252
 ospf network-type p2p
 bfd echo enable
 track 1 bfd echo interface Ten-GigabitEthernet1/1/0/22.10 remote ip 10.0.112.250 local ip 10.0.112.249
 ip route-static vpn-instance 530 0.0.0.0 0 10.0.112.250 track 1
[530shibocunlu_DC_S9804-1]dis bfd session
 Total Session Num: 1     Up Session Num: 0     Init Mode: Active
 IPv4 Session Working Under Echo Mode:
 LD    SourceAddr      DestAddr    State    Holdtime    Interface
 3001  10.0.112.249    10.0.112.250   Down      /        XGE1/1/0/22.10
粉丝:4人 关注:0人
是不是检测地址不可达
ping -a 10.0.0.1 10.0.0.2 Ping 10.0.0.2 (10.0.0.2) from 10.0.0.1: 56 data bytes, press CTRL_C to break 56 bytes from 10.0.0.2: icmp_seq=0 ttl=255 time=2.000 ms 56 bytes from 10.0.0.2: icmp_seq=1 ttl=255 time=1.000 ms 56 bytes from 10.0.0.2: icmp_seq=2 ttl=255 time=1.000 ms 56 bytes from 10.0.0.2: icmp_seq=3 ttl=255 time=1.000 ms 56 bytes from 10.0.0.2: icmp_seq=4 ttl=255 time=1.000 ms --- Ping statistics for 10.0.0.2 --- 5 packet(s) transmitted, 5 packet(s) received, 0.0% packet loss round-trip min/avg/max/std-dev = 1.000/1.200/2.000/0.400 ms
zhiliao_bl2sS4 发表时间:2020-09-21
可达
249和250的地址测试
zhiliao_xUyMV 发表时间:2020-09-21
