用真机创建一条Mpls L2VPN 线路,dis mpls l2vpn con 显示线路down,dis mpls l2vpn con in vlan *** 提示Local vc state : down,对端设备是个5800,相同配置,只是CE的ID和名字不同,Local vc state : UP 查了半天资料,都找不到类似的故障,求大神帮忙
两端配置:
S10508侧:
# mpls l2vpn hwcloudvlan encapsulation vlan
route-distinguisher 100:11
vpn-target 100:11 import-extcommunity
vpn-target 100:11 export-extcommunity
ce server id 2 range 30 default-offset 0
connection ce-offset 1 interface Vlan-interface3200
S5800-SW3:
ce ce1 id 1 range 30 default-offset 0
connection ce-offset 2 interface Vlan-interface3200
在10508上dis mpls l2vpn con:
1 total connections, connections: 0 up, 1 down, 0 local, 1 remote, 0 unknown
VPN name: hwcloudvlan,
CE name: server, id: 2,
Rid type status peer-id route-distinguisher intf
1 rmt down S5800-SW3 100:11 Vlan3200
dis mpls l2vpn connection interface vl 3200
***Conn-type : remote
Remote vc state : up Local ce-id : 2
Local ce name : server
Remote ce-id : 1
Intf(state,encap) : Vlan-interface3200(up,vlan)
Peer id : S5800-SW3
Route-distinguisher : 100:11
Local vc label : 123211
Remote vc label : 122882
Tunnel policy : -
组网:S10508---Vlan----S5800-SW1----三层接口----S5800-SW2----Vlan----S5800-SW3
(0)
之前是按着http://www.h3c.com/cn/d_201312/807760_30005_0.htm这个教程做的配置,但是一直没成功过,配置的是Kompella
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
看了下,这个应该是V7版本的配置方法,我的设备还是V5版本,Comware Software, Version 5.20, Release 1210P03 Copyright (c) 2004-2017 Hangzhou H3C Tech. Co., Ltd. All rights reserved. H3C S10508-V uptime is 0 week, 5 days, 12 hours, 53 minutes
https://www.h3c.com/cn/d_201505/868918_30005_0.htm#_Toc419107420可以到官网上找一下具体型号配置
