S10508 Mpls L2VPN KOMPELLA 不能UP
2020-09-22提问
  • 1收藏,194浏览
用真机创建一条Mpls L2VPN 线路,dis mpls l2vpn con 显示线路down,dis mpls l2vpn con in vlan *** 提示Local vc state : down,对端设备是个5800,相同配置,只是CE的ID和名字不同,Local vc state : UP  查了半天资料,都找不到类似的故障,求大神帮忙
两端配置:
S10508侧:
# mpls l2vpn hwcloudvlan encapsulation vlan
 route-distinguisher 100:11
 vpn-target 100:11 import-extcommunity
 vpn-target 100:11 export-extcommunity
 ce server id 2 range 30 default-offset 0
 connection ce-offset 1 interface Vlan-interface3200
S5800-SW3:
 ce ce1 id 1 range 30 default-offset 0
 connection ce-offset 2 interface Vlan-interface3200
在10508上dis mpls l2vpn con:
 1 total connections, connections: 0 up, 1 down, 0 local, 1 remote, 0 unknown
VPN name: hwcloudvlan,
 CE name: server, id: 2,
 Rid type status peer-id route-distinguisher intf
 1 rmt down S5800-SW3 100:11 Vlan3200
dis mpls l2vpn connection interface vl 3200
 ***Conn-type : remote
 Remote vc state : up Local ce-id : 2
 Local ce name : server
 Remote ce-id : 1
 Intf(state,encap) : Vlan-interface3200(up,vlan)
 Peer id : S5800-SW3
 Route-distinguisher : 100:11
 Local vc label : 123211
 Remote vc label : 122882
 Tunnel policy : -
组网:S10508---Vlan----S5800-SW1----三层接口----S5800-SW2----Vlan----S5800-SW3
https://www.h3c.com/cn/d_201505/868432_30005_0.htm
检查下配置
看了下,这个应该是V7版本的配置方法,我的设备还是V5版本,Comware Software, Version 5.20, Release 1210P03 Copyright (c) 2004-2017 Hangzhou H3C Tech. Co., Ltd. All rights reserved. H3C S10508-V uptime is 0 week, 5 days, 12 hours, 53 minutes
篠崎Shinozaki 发表时间:2020-09-22
https://www.h3c.com/cn/d_201505/868918_30005_0.htm#_Toc419107420可以到官网上找一下具体型号配置
zhiliao_z5rqq 发表时间:2020-09-22
篠崎Shinozaki 知了小白
之前是按着http://www.h3c.com/cn/d_201312/807760_30005_0.htm这个教程做的配置,但是一直没成功过,配置的是Kompella
