交换机BGP对等体组路由策略和对等体策略发布机制
2020-02-27 发表
  • 3收藏 1604浏览
粉丝:10人 关注:1人
组网及说明
不涉及
问题描述
BGP视图下可以同时对对等体组和对等体发布路由策略,这两个策略是如何相互影响的
过程分析
AB直连建立EBGP邻居关系,配置如下
[A]dis cu c bgp
bgp 100
router-id 1.1.1.1
group vpna external
peer vpna as-number 200
peer 11.1.1.2 group vpna
peer 12.1.1.2 group vpna
peer 13.1.1.2 group vpna
address-family ipv4 unicast
 network 10.0.0.1 255.255.255.255//引入路由
  peer vpna enable
return
[B]dis cu  c bgp
bgp 200
router-id 2.2.2.2
ip vpn-instance vpna
  peer 11.1.1.1 as-number 100
   peer 11.1.1.1 enable
ip vpn-instance vpnb
  peer 12.1.1.1 as-number 100
   peer 12.1.1.1 enable
ip vpn-instance vpnc
  peer 13.1.1.1 as-number 100
   peer 13.1.1.1 enable
return
B上看所有路由med0
[B]dis bgp routing-table ipv4 vpn-instance vpna
* >e 10.0.0.1/32        11.1.1.1        0                     0       100i
[B]dis bgp routing-table ipv4 vpn-instance vpnb
* >e 10.0.0.1/32        12.1.1.1        0                     0       100i
[B]dis bgp routing-table ipv4 vpn-instance vpnc
* >e 10.0.0.1/32        13.1.1.1        0                     0       100i
A建两个策略,设cost值为200400
[A]dis route-policy
Route-policy: 123
  Permit : 10
         if-match ip address acl 3001
         apply cost 200
Route-policy: 234
  Permit : 10
         apply cost 400
A上对对等体组发布策略
[A-bgp-default-ipv4]peer vpna route-policy 123 export
B上看med均为200
<B>dis bgp rou ipv4 vpn-instance vpnb
* >e 10.0.0.1/32        12.1.1.1        200                   0       100i
<B>dis bgp rou ipv4 vpn-instance vpnc
* >e 10.0.0.1/32        13.1.1.1        200                   0       100i
<B>dis bgp rou ipv4 vpn-instance vpna
* >e 10.0.0.1/32        11.1.1.1        200                   0       100i
A上继续对13.1.1.1对等体发布路由策略
[A-bgp-default-ipv4]peer 13.1.1.2 route-policy 234 export
B上看VPNCmed变为400,精细控制生效
* >e 10.0.0.1/32        13.1.1.1        400                   0       100i
对等体组策略增删会导致单一对等体策略被删除
[spine-bgp-default-ipv4]dis th
  network 1.1.1.1 255.255.255.255
  peer ebgp enable
  peer ebgp route-policy 123 export
  peer 11.1.1.2 route-policy 234 export
return
[spine-bgp-default-ipv4]undo peer ebgp route-policy 123 export//删除组策略
 address-family ipv4 unicast//对等体策略被删除
  peer ebgp enable
return
[spine-bgp-default-ipv4]peer 11.1.1.2 route-policy 234 export//添加对等体策略
  peer ebgp enable
  peer 11.1.1.2 route-policy 234 export//已添加
return
[spine-bgp-default-ipv4]peer ebgp route-policy 123 export//添加对等体组策略
  peer ebgp enable
  peer ebgp route-policy 123 export//对等体策略添加成功,对等体策略被删除
return
1)经实验验证,对单一对等体邻居发布的策略优于对对等体组发布的策略
2)对等体组增删策略会导致对单一对等体策略被删除
解决方法
上述实验的得出的结论本质是由于交换价实现方式决定的:
1)后发布的策略生效
2)对对等体组发布策略时,底层会对每个对等体发布一次相同的策略
先发布对等体组(对等体ABC)发布策略1,底层对每个对等体发布了策略1,然后对对等体A发布策略2,此时对等体A的策略刷新为策略2,BC仍为侧略1,最后删除对等体组策略1,此时ABC的全部策略都被删除;
先发布对等体A发布策略2,此时底层对A发布了策略2,然后对等体组发布策略1,此时,ABC全部刷新为策略1。
该案例对您是否有帮助:
您的评价:1
若您有关于案例的建议,请反馈:
0 个评论
该案例暂时没有网友评论
编辑评论
对根叔知了社区有害的内容 >
对根叔知了社区有害的内容
