组网说明:
本案例采用H3C HCL模拟器来模拟WRED典型组网。R1的GI 0/1端口连接服务器。其中172.16.10.2是IP电话。要求在拥塞发生时,172.16.10.3和172.16.10.2要有不同的丢弃行为,从而保证语音流能有更好的服务。
1、要将语音报文标记为IP Prencedence 5,数据流为IP Prencedence 0.
2、采用CAR的重标记方式对报文进行分类,将来自IP电话和数据报文的优先级分别设置为5和0,在做CAR时,CIR的值全部保持一致,确保所匹配的报文都能全部被重标记
3、启用WFQ功能,与WRED同时使用
第一阶段调试(基础网络配置):
SW1:
<H3C>sys
[H3C]sysname SW1
[SW1]vlan 10
[SW1-vlan10]quit
[SW1]int gi 1/0/1
[SW1-GigabitEthernet1/0/1]port link-type trunk
[SW1-GigabitEthernet1/0/1]undo port trunk permit vlan 1
[SW1-GigabitEthernet1/0/1]port trunk permit vlan 10
[SW1-GigabitEthernet1/0/1]quit
[SW1]int range gi 1/0/2 to gi 1/0/3
[SW1-if-range]port link-type access
[SW1-if-range]port access vlan 10
[SW1-if-range]quit
[SW1]
R1:
<H3C>sys
[H3C]sysname R1
[R1]vlan 10
[R1-vlan10]quit
[R1]int vlan 10
[R1-Vlan-interface10]ip address 172.16.10.1 24
[R1-Vlan-interface10]quit
[R1]int gi 0/0
[R1-GigabitEthernet0/0]port link-mode bridge
[R1-GigabitEthernet0/0]port link-type trunk
[R1-GigabitEthernet0/0]undo port trunk permit vlan 1
[R1-GigabitEthernet0/0]port trunk permit vlan 10
[R1-GigabitEthernet0/0]quit
[R1]int gi 0/1
[R1-GigabitEthernet0/1]ip address 192.168.1.1 24
[R1-GigabitEthernet0/1]quit
第二阶段调试(WRED+WFQ关键配置):
R1:
[R1]acl basic 2000
[R1-acl-ipv4-basic-2000]rule 0 permit source 172.16.10.2 0
[R1-acl-ipv4-basic-2000]quit
[R1]acl basic 2001
[R1-acl-ipv4-basic-2001]rule 0 permit source 172.16.10.3 0
[R1-acl-ipv4-basic-2001]quit
[R1]int gi 0/0
[R1-GigabitEthernet0/0]qos car inbound acl 2000 cir 100000 green remark-prec-pass 5 red pass
[R1-GigabitEthernet0/0]qos car inbound acl 2001 cir 100000 green remark-prec-pass 0 red pass
[R1]int gi 0/1
[R1-GigabitEthernet0/1]qos wfq
[R1-GigabitEthernet0/1]qos wred enable
[R1-GigabitEthernet0/1]qos wred ip-precedence 5 low-limit 10 high-limit 250 discard-probability 10
[R1-GigabitEthernet0/1]qos wred ip-precedence 0 low-limit 10 high-limit 180 discard-probability 11
查看QOS的显示信息:
至此,QOS之WRED典型组网配置案例已完成!
