Print
CR16010-F Static Address Allocation Failure Case
2020-03-04 发表
组网及说明
NULL
问题描述
There is a specific user who needs to be assigned a fixed static address(1.1.1.1). Under the DHCP address pool, we bind a fixed   address to the terminal of the MAC through this command “static bind ip address”. After configuration, we find that the user is online but get a random IP.
static-bind ip-address 1.1.1.1 mask 255.0.0.0 hardware-address aaaa-bbbb-cccc
过程分析
Instead of getting the specified 1.1.1.1 address, the terminal gets a 1.1.1.5 address.Check the corresponding address allocation of DHCP address pool on bras as follows.
[H3C]dis dhcp server ip-in-use ip 1.1.1.5
IP address: 1.1.1.5
Client identifier/Hardware address: 0061-6161-6162-6262-6263-6363-6363-XXXX-XXXX-XXXX-XXXX-XXXX
Lease expiration: Unlimited
Type: Auto(C)
Client access interface: Bas-interface32
Outer VLAN: 1000
Inner VLAN: 2000
PPP index: 7000
The corresponding terminal client id/hardware address for this IP is not a MAC address, but a string of ASCII code converted from the MAC address (the last few sections here are replaced by X).We also need to bind the string when binding the address under the DHCP address pool.
解决方法
When assigning a static address to a specific client in the DHCP address pool, replace the MAC address with the client ID string displayed by the dis DHCP server IP X.X.X.X to realize the assignment of fixed address.
static-bind ip-address 1.1.1.1 mask 255.255.192.0 client-identifier 0061-6161-6162-6262-6263-6363-6363-XXXX-XXXX-XXXX-XXXX-XXXX
