3PAR with DL120 SP
3PAR DL120 没有物理串口,只能通过虚拟串口来进行配置,下面是详细步骤。
The DL120 does not have a physical serial port. Instead it has a virtual serial port. When you attempt to rebuild the SP at some point the display switches to the virtual serial port and stops outputting on the graphic head. The rebuild is still progressing and eventually will complete and give you a SP00000 Login> prompt on the graphics terminal.
To monitor the rebuild use the following process.
1.
2.
3. Connect network cable from laptop to the service port on the back of the DL120 (right hand port)
4. Browse to the IP of the ILO, 10.255.155.52. Login using Administrator and the password from the toe tag.
5.
6.
7.
8.
9.
10.
Execute all the following commands on the serial port
11.
Redundant ROM Detected - This system contains a valid backup system ROM
HP SmartMemory authenticated in all populated DIMM slots.
For access via BIOS Serial Console:
Press 'ESC+9' for System Utilities
Press 'ESC+0' for Intelligent Provisioning
Press 'ESC+!' for One-Time Boot Menu
Press 'ESC+@' for Network Boot
12.
One-Time Boot Menu > Legacy BIOS One-Time Boot Menu
13.
|Select ENTER to enter the Legacy BIOS One-Time Boot |
|Menu or ESC to cancel. |
|Enter (Exit) | ESC (Cancel) |
Booting in Legacy BIOS mode...
14.
Please Choose one of the Following Default Boot Override Options:
1) One Time Boot to CD-ROM
2) One Time Boot to USB DriveKey
3) One Time Boot to HDD
4) One Time Boot to Network (1st NIC in IPL)
5) One Time Boot to UEFI Boot Menu (after system reset)
7) One Time Boot to Intelligent Provisioning (after system reset)
8) Enter the System Utilities menu (after system reset)
0) Exit Boot Override Menu and Continue Default Boot Process
15.
16.
17.
18.
19.
20.
