Print
S5500V2-24P-SI配置IRF2后出现报错,无法堆叠案例
2017-12-12 发表
问题描述
S5500V2-24P-SI配置IRF2后出现报错,无法堆叠案例:
%Jan 2 21:53:09:876 2013 H3C DRVPLAT/4/DrvDebug: The port Ten2/0/27 can't receive irf pkt, please check.
 %Jan 2 21:53:00:786 2013 H3C DRVPLAT/4/DrvDebug: The port Ten2/0/27 can't receive irf pkt, please check.
%Jan 2 21:52:51:696 2013 H3C DRVPLAT/4/DrvDebug: The port Ten2/0/27 can't receive irf pkt, please check.
%Jan 2 21:52:42:606 2013 H3C DRVPLAT/4/DrvDebug: The port Ten2/0/27 can't receive irf pkt, please check.
%Jan 2 21:52:33:516 2013 H3C DRVPLAT/4/DrvDebug: The port Ten2/0/27 can't receive irf pkt, please check.
%Jan 2 21:52:24:426 2013 H3C DRVPLAT/4/DrvDebug: The port Ten2/0/27 can't receive irf pkt, please check.
 %Jan 2 21:52:15:336 2013 H3C DRVPLAT/4/DrvDebug: The port Ten2/0/27 can't receive irf pkt, please check.
%Jan 2 21:52:06:246 2013 H3C DRVPLAT/4/DrvDebug: The port Ten2/0/27 can't receive irf pkt, please check.
%Jan 2 21:51:57:156 2013 H3C DRVPLAT/4/DrvDebug: The port Ten2/0/27 can't receive irf pkt, please check.
%Jan 2 21:51:48:067 2013 H3C DRVPLAT/4/DrvDebug: The port Ten2/0/27 can't receive irf pkt, please check.
 %Jan 2 21:51:38:977 2013 H3C DRVPLAT/4/DrvDebug: The port Ten2/0/27 can't receive irf pkt, please check.
%Jan 2 21:51:29:886 2013 H3C DRVPLAT/4/DrvDebug: The port Ten2/0/27 can't receive irf pkt, please check.
%Jan 2 21:51:20:798 2013 H3C DRVPLAT/4/DrvDebug: The port Ten2/0/27 can't receive irf pkt, please check.
解决方法
怀疑是堆叠口故障,导致IRF报文无法交互。经过替换测试,确定是堆叠口光模块异常导致,更换堆叠口对应光模块后解决。
答案来自于 Erosion
