总部:
sysname Headquarters
interface LoopBack0
interface GigabitEthernet0/0
port link-mode route
combo enable copper
ip address 1.1.1.2 255.255.255.252
//GRE报文不会做NAT,所以此处NAT处不用deny ipsec感兴趣流
nat outbound
ipsec apply policy test
interface Tunnel0 mode gre
description toBrabchA
ip address 172.16.1.1 255.255.255.0
source 1.1.1.2
destination 2.2.2.2
interface Tunnel1 mode gre
description toBrabchB
ip address 172.16.2.11 255.255.255.0
source 1.1.1.2
destination 3.3.3.2
ip route-static 0.0.0.0 0 1.1.1.1
ip route-static 192.168.2.0 24 tunnel0
ip route-static 192.168.3.0 24 tunnel1
acl advanced 3000
description toBranchA
rule 0 permit ip source 1.1.1.2 0.0.0.0 destination 2.2.2.2 0.0.0.0
acl advanced 3001
description toBranchB
rule 0 permit ip source 1.1.1.2 0.0.0.0 destination 3.3.3.2 0.0.0.0
ipsec transform-set 1
esp encryption-algorithm 3des-cbc
esp authentication-algorithm md5
ipsec policy-template branchA 1
transform-set 1
security acl 3000
ike-profile branchA
ipsec policy-template branchB 1
transform-set 1
security acl 3001
ike-profile branchB
ipsec policy test 1 isakmp template branchA
ipsec policy test 2 isakmp template branchB
ike profile branchA
keychain branchA
exchange-mode aggressive
local-identity fqdn headquarters
match remote identity fqdn branchA
ike profile branchB
keychain branchB
match remote identity fqdn branchB
ike proposal 1
ike keychain branchA
match local address 1.1.1.2
pre-shared-key hostname branchA key cipher $c$3$nng95cm/zlG3ghvIRim5saZ3bMEhoJD+Ow==
ike keychain branchB
pre-shared-key hostname branchB key cipher $c$3$Rl2okdkTYNBEYWd32X25LOWYkYo5YCcrgw==
分支A
sysname branchA
nqa entry admin test
type icmp-echo
destination ip 1.1.1.2
frequency 5000
history-record enable
history-record number 10
probe count 10
probe timeout 500
source ip 2.2.2.2
nqa schedule admin test start-time now lifetime forever
interface LoopBack0
ip address 192.168.2.1 255.255.255.0
combo enable copper
ip address 2.2.2.2 255.255.255.252
nat outbound
ipsec apply policy 1
ip address 172.16.1.2 255.255.255.0
source 2.2.2.2
destination 1.1.1.2
ip route-static 0.0.0.0 0 2.2.2.1
ip route-static 192.168.1.0 24 Tunnel0
ip route-static 192.168.3.0 24 Tunnel0
acl advanced 3000
rule 0 permit ip source 2.2.2.2 0.0.0.0 destination 1.1.1.2 0.0.0.0
ipsec policy 1 1 isakmp
transform-set 1
security acl 3000
remote-address 1.1.1.2
ike-profile 1
ike dpd interval 10 on-demand
ike profile 1
keychain 1
local-identity fqdn branchA
match remote identity fqdn headquarters
ike proposal 1
ike keychain 1
pre-shared-key address 1.1.1.2 255.255.255.0 key cipher $c$3$5QlYyBFEZTju/oTPut9zgP5JNpmVleBIbA==
sysname branchB
type icmp-echo
frequency 5000
probe count 10
probe timeout 500
source ip 3.3.3.2
interface LoopBack0
ip address 192.168.3.1 255.255.255.0
combo enable copper
ip address 3.3.3.2 255.255.255.252
nat outbound
ip address 172.16.1.3 255.255.255.0
source 3.3.3.2
destination 1.1.1.2
ip route-static 0.0.0.0 0 3.3.3.1
ip route-static 192.168.2.0 24 Tunnel0
acl advanced 3000
rule 0 permit ip source 3.3.3.2 0.0.0.0 destination 1.1.1.2 0.0.0.0
transform-set 1
security acl 3000
ike-profile 1
ike profile 1
keychain 1
local-identity fqdn branchB
ike proposal 1
ike keychain 1
分支B侧可以ping
<Headquarters>dis ike sa
Connection-ID Remote Flag DOI
1 2.2.2.2 RD IPsec
2 3.3.3.2 RD IPsec
Flags:
RD--READY RL--REPLACED FD-FADING RK-REKEY
<Headquarters>dis ipsec sa
Interface: GigabitEthernet0/0
IPsec policy: test
Sequence number: 1
Mode: Template
Tunnel id: 0
Encapsulation mode: tunnel
Perfect Forward Secrecy:
Inside VPN:
Extended Sequence Numbers enable: N
Traffic Flow Confidentiality enable: N
Path MTU: 1444
Tunnel:
local address: 1.1.1.2
remote address: 2.2.2.2
Flow:
sour addr: 1.1.1.2/255.255.255.255 port: 0 protocol: ip
dest addr: 2.2.2.2/255.255.255.255 port: 0 protocol: ip
[Inbound ESP SAs]
SPI: 3870699250 (0xe6b62ef2)
Connection ID: 4294967296
Transform set: ESP-ENCRYPT-3DES-CBC ESP-AUTH-MD5
SA duration (kilobytes/sec): 1843200/3600
SA remaining duration (kilobytes/sec): 1843142/3365
Max received sequence-number: 430
Anti-replay check enable: Y
Anti-replay window size: 64
UDP encapsulation used for NAT traversal: N
Status: Active
[Outbound ESP SAs]
SPI: 3823032807 (0xe3ded9e7)
Connection ID: 4294967297
Max sent sequence-number: 430
Status: Active
IPsec policy: test
Sequence number: 2
Mode: Template
Tunnel id: 1
Inside VPN:
Path MTU: 1444
Tunnel:
remote address: 3.3.3.2
Flow:
dest addr: 3.3.3.2/255.255.255.255 port: 0 protocol: ip
[Inbound ESP SAs]
SPI: 3360931740 (0xc853bf9c)
Connection ID: 4294967298
SA remaining duration (kilobytes/sec): 1843138/3366
Max received sequence-number: 460
Status: Active
[Outbound ESP SAs]
SPI: 1888065202 (0x708996b2)
Connection ID: 4294967299
Max sent sequence-number: 460
Status: Active
<branchA>dis ike sa
1 1.1.1.2 RD IPsec
Flags:
<branchA>dis ipsec sa
IPsec policy: 1
Sequence number: 1
Mode: ISAKMP
Tunnel id: 0
Inside VPN:
Path MTU: 1444
Tunnel:
local address: 2.2.2.2
remote address: 1.1.1.2
Flow:
sour addr: 2.2.2.2/255.255.255.255 port: 0 protocol: ip
dest addr: 1.1.1.2/255.255.255.255 port: 0 protocol: ip
[Inbound ESP SAs]
SA remaining duration (kilobytes/sec): 1843081/3156
Max received sequence-number: 895
Status: Active
[Outbound ESP SAs]
Max sent sequence-number: 895
Status: Active
<branchB>dis ike sa
1 1.1.1.2 RD IPsec
Flags:
<branchB>dis ipsec sa
IPsec policy: 1
Sequence number: 1
Mode: ISAKMP
Tunnel id: 0
Inside VPN:
Path MTU: 1444
Tunnel:
local address: 3.3.3.2
Flow:
sour addr: 3.3.3.2/255.255.255.255 port: 0 protocol: ip
[Inbound ESP SAs]
SA remaining duration (kilobytes/sec): 1843029/2961
Max received sequence-number: 1285
Status: Active
[Outbound ESP SAs]
Max sent sequence-number: 1285
Status: Active
在总部开启debug GRE all和debug ip packet,然后在分支A分别访问总部和分支B,收集debug信息分析一下报文在总部的解封装然后又封装的过程。
[branchA]ping -c 1 -a 192.168.2.1 192.168.1.1
//收到ESP
<Headquarters>*Jun 15 12:42:35:746 2020 Headquarters IPFW/7/IPFW_PACKET:
Receiving, interface = GigabitEthernet0/0, version = 4, headlen = 20, tos = 0,
pktlen = 160, pktid = 10759, offset = 0, ttl = 254, protocol = 50,
checksum = 35870, s = 2.2.2.2, d = 1.1.1.2
prompt: Receiving IP packet.
//进行ipsec
pktlen = 108, pktid = 10758, offset = 0, ttl = 255, protocol = 47,
checksum = 35670, s = 2.2.2.2, d = 1.1.1.2
//送到GRE tunnel0接口进行GRE
Delivering, interface = GigabitEthernet0/0, version = 4, headlen = 20, tos = 0,
prompt: IP packet is delivering up.
*Jun 15 12:42:35:746 2020 Headquarters GRE/7/packet:
Tunnel0 packet: Before de-encapsulation,
2.2.2.2->1.1.1.2 (length = 108)
Tunnel0 packet: After de-encapsulation,
192.168.2.1->192.168.1.1 (length = 84)
Receiving, interface = Tunnel0, version = 4, headlen = 20, tos = 0,
pktlen = 84, pktid = 10757, offset = 0, ttl = 255, protocol = 1,
checksum = 3409, s = 192.168.2.1, d = 192.168.1.1
Delivering, interface = Tunnel0, version = 4, headlen = 20, tos = 0,
//对设备回应的报文继续进行GRE
Sending, interface = Tunnel0, version = 4, headlen = 20, tos = 0,
checksum = 3409, s = 192.168.1.1, d = 192.168.2.1
prompt: Sending the packet from local at Tunnel0.
Tunnel0 packet: Before encapsulation according to adjacency table,
192.168.1.1->192.168.2.1 (length = 84)
Tunnel0 packet: After encapsulation,
1.1.1.2->2.2.2.2 (length = 108)
//GRE封装完成之后从外网接口从ipsec
Sending, interface = GigabitEthernet0/0, version = 4, headlen = 20, tos = 0,
pktlen = 160, pktid = 10715, offset = 0, ttl = 255, protocol = 50,
checksum = 35658, s = 1.1.1.2, d = 2.2.2.2
prompt: Sending the packet from local at GigabitEthernet0/0.
[branchA]ping -c 1 -a 192.168.2.1 192.168.3.1
//如下的解封装、封装过程与上面类似,不在赘述。
<Headquarters>
//收到ESP
*Jun 15 14:49:10:944 2020 Headquarters IPFW/7/IPFW_PACKET:
pktlen = 160, pktid = 8947, offset = 0, ttl = 254, protocol = 50,
checksum = 37682, s = 2.2.2.2, d = 1.1.1.2
//进行ipsec
pktlen = 108, pktid = 8946, offset = 0, ttl = 255, protocol = 47,
checksum = 37482, s = 2.2.2.2, d = 1.1.1.2
*Jun 15 14:49:10:944 2020 Headquarters GRE/7/packet:
192.168.2.1->192.168.3.1 (length = 84)
pktlen = 84, pktid = 8945, offset = 0, ttl = 255, protocol = 1,
checksum = 4709, s = 192.168.2.1, d = 192.168.3.1
//根据静态路由将分支A
Sending, interface = Tunnel1, version = 4, headlen = 20, tos = 0,
pktlen = 84, pktid = 8945, offset = 0, ttl = 254, protocol = 1,
checksum = 4965, s = 192.168.2.1, d = 192.168.3.1
prompt: Sending the packet from Tunnel0 at Tunnel1.
Tunnel1 packet: Before encapsulation according to adjacency table,
Tunnel1 packet: After encapsulation,
1.1.1.2->3.3.3.2 (length = 108)
*Jun 15 14:49:10:945 2020 Headquarters IPFW/7/IPFW_PACKET:
pktlen = 160, pktid = 9356, offset = 0, ttl = 255, protocol = 50,
checksum = 36504, s = 1.1.1.2, d = 3.3.3.2
//收到从分支B
*Jun 15 14:49:10:946 2020 Headquarters IPFW/7/IPFW_PACKET:
pktlen = 160, pktid = 9816, offset = 0, ttl = 254, protocol = 50,
checksum = 36300, s = 3.3.3.2, d = 1.1.1.2
//进行ipsec
pktlen = 108, pktid = 9815, offset = 0, ttl = 255, protocol = 47,
checksum = 36100, s = 3.3.3.2, d = 1.1.1.2
//送到GRE tunnel1接口进行GRE
*Jun 15 14:49:10:946 2020 Headquarters GRE/7/packet:
Tunnel1 packet: Before de-encapsulation,
3.3.3.2->1.1.1.2 (length = 108)
Tunnel1 packet: After de-encapsulation,
192.168.3.1->192.168.2.1 (length = 84)
Receiving, interface = Tunnel1, version = 4, headlen = 20, tos = 0,
checksum = 4709, s = 192.168.3.1, d = 192.168.2.1
//tunnel1解封装完成根据静态路由又送到tunnel0接口进行GRE
checksum = 4965, s = 192.168.3.1, d = 192.168.2.1
prompt: Sending the packet from Tunnel1 at Tunnel0.
pktlen = 160, pktid = 9359, offset = 0, ttl = 255, protocol = 50,
checksum = 37014, s = 1.1.1.2, d = 2.2.2.2
