Print
某局点AP反复下载版本无法稳定在线问题处理经验案例
2020-07-27 发表
组网及说明
传统组网,AP二层注册
问题描述
某局点AP反复下载版本无法稳定在线
过程分析
首先, 我们先明确下故障现象,通过AP的输出信息我们能看到,AP可以正常的从AC上下载版本并启动,可以进入命令行,但是几秒钟之后就会再次重复下载版本。
******************************************** * * * H3C WA4320i-ACN BootWare, Version 7.07 * * * ********************************************* Copyright (c) 2004-2016 Hangzhou H3C Technologies Co., Ltd
Compiled Date : Jun 20 2016
CPU Type : ATHEROS AR9550
CPU L1 Cache : 32KB
CPU Clock Speed : 720MHz
Memory Type : DDR2 SDRAM
Memory Size : 256MB
Memory Speed : 560MHz
BootWare Size : 512KB
Flash Size : 32MB
CPLD Version : 006
PCB Version : Ver.C
BootWare Validating...
Press Ctrl+B to access EXTENDED-BOOTWARE MENU...
Loading the main boot and system image files...
Loading file flash:/wa4300-system.bin....................................... Done.
Loading file flash:/wa4300-boot.bin......................................... ......................Done.
Image file flash:/wa4300-boot.bin is self-decompressing..................... ............................................................................ ............................................................................ .............................................Done.
System image is starting...
Startup configuration file does not exist.
Line con0 is available.
Press ENTER to get started.
<H3C>%Sep 27 17:25:58:435 2019 H3C SHELL/5/SHELL_LOGIN: Console logged in from con0.
<H3C>%Sep 27 17:26:04:649 2019 H3C CWC/6/CWC_IMG_DOWNLOAD_START: Started to download the image file wa4300.ipe through the CAPWAP tunnel to AC 192.168.100.xxx.
Decompressing file wa4300-boot.bin to flash:/wa4300-boot.bin................................Done.
Decompressing file wa4300-system.bin to flash:/wa4300-system.bin........................................................................................................Done.
%Sep 27 17:30:30:425 2019 H3C CWC/6/CWC_IMG_DOWNLOAD_COMPLETE: Downloading the image file wa4300.ipe from AC 192.168.100.xxx through the CAPWAP tunnel is complete.
%Sep 27 17:30:30:425 2019 H3C CWC/6/CWC_AP_REBOOT: AP in state Image Data is rebooting. Reason: Image was downloaded successfully.
%Sep 27 17:30:37:310 2019 H3C DEV/5/SYSTEM_REBOOT: System is rebooting now. System is starting...
在AP命令行里我们能看到AP的版本和AC的版本不匹配,同时在AC的debug wlan capwap信息中,有如下的打印信息:
*Jul 20 11:24:49:858 2020 vac CWS/7/FSM: Enter Image Download state.
*Jul 20 11:24:49:858 2020 vac CWS/7/ERROR: Failed to get image file 0.000000rom the ram path.
*Jul 20 11:24:49:858 2020 vac CWS/7/EVENT: Start get ap ipe offset in file /mnt/slot0#flash:/wa4300.ipe
*Jul 20 11:24:49:858 2020 vac CWS/7/EVENT: Get the ap ipe offset in file /mnt/slot0#flash:/wa4300.ipe, errCode=0x0 offset=0 ipeSize=0
AP的版本是从AC的flash中下载的,并不是从apimge中下载的。在版本说明书配套FIT AP列表中,有说明该类型的AP 的ipe文件不打包在AC中,需要单独将Ap的ipe文件导入AC根目录下。
因此怀疑AC根目录下的AP版本上传错误,与AC版本号不匹配不一致,导致AP下载版本之后,又由于AC的版本校验机制,AC会将AP的软件版本与AC上保存的该AP型号的软硬件版本对应关系进行比较。如果软件版本一致,则允许CAPWAP隧道建立;如果软件版本不一致,则将此情况告知AP。AP收到版本不一致的消息后,会向AC请求版本并进行版本升级后,再重新与AC建立CAPWAP隧道连接。
因此AP才会反复的下载版本,不能稳定在线。
解决方法
AC根目录下重新上传正确的Ap的ipe文件,AP稳定注册成功
