Print
Cannot enter system mode after logging in S75E via Telnet
2020-08-21 Published
Network Topology
Null
Problem Description
A customer reported that after logging in S75E via Telnet, the user obtained the highest permission, but could not enter the system mode after logging in the device.
Process Analysis
1. Log in S75E via Telnet, and find that the reboot command can be input normally, which means that the logged role has indeed obtained the highest privilege, and the debug information of 7506E can also be seen that the role has obtained the highest privilege, as follows:
*Aug 17 15:08:57:425 2017 XYKZC-KS-CORE-7506E-01 RADIUS/7/PACKET: -MDC=1;
    Service-Type=Callback-Administrative
    Session-Timeout=86400
    Login-Service=Telnet
H3c-Exec-Privilege=15
The authentication server is IMC, and role levels can also be seen on IMC:
CODE = 1.
ID = 71.
ATTRIBUTES:
         User-Name(1) = "test@hxks".
         Password(2) = "$$$".
         Service-Type(6) = 1.
         NAS-Identifier(32) = "XYKZC-KS-CORE-7506E-01".
         Framed-IP-Address(8) = 1781483207.
         NAS-IP-Address(4) = 1781530371.
%% 2017-08-17 13:01:53.499 ; [LDBG] ; [3932] ; radDispatcher ; prsRawPkt: chk-sum 3465568905.
%% 2017-08-17 13:01:53.499 ; [LDBG] ; [3932] ; LAN ; prsMixedUsr: in [test@hxks], out [test@hxks].
%% 2017-08-17 13:01:53.499 ; [LDBG] ; [3932] ; radEnt ; setPxyType: Needn&39;t proxy. domainname=hxks, Code=1.
%% 2017-08-17 13:01:53.499 ; [LDBG] ; [3932] ; LAN ; getIpMacFromItem: no attribute of Calling-Station-Id.
%% 2017-08-17 13:01:53.530 ; [LDBG] ; [2264] ; MNG ; Send message attribut list:
Code = 2
ID = 71
ATTRIBUTES:
Service_Type(6) = 1
Session-Timeout(27) = 86400
Login_Service(15) = 0
hw_Exec_Privilege(29) = 15
No command entered into the system view was found when entering the question mark, which is suspected to be a command line authorization problem.
2. Check the authentication, authorization, accounting, etc. of different applications in the Domain:
<XYKZC-KS-CORE-7506E-01>display domain
Total 2 domain(s)
Domain:system
 State: Active
 default Authentication Scheme:  local
 default Authorization  Scheme:  local
 default Accounting     Scheme:  local
 Authorization attributes :
  Idle-cut : Disable
Domain:hxks
 State: Active
 login   Authentication Scheme:  radius: hxks, local
 login   Authorization  Scheme:  radius: hxks, local
 login   Accounting     Scheme:  radius: hxks, none
Under Domain HXKS, everything is local except for login authentication, authorization, billing, and radius HXKS.
3. Once again display the information of the local server. Through debug, it can be found that there will be printing authorization failure and log that the user does not exist:
<XYKZC-KS-CORE-7506E-01>debugging local-server all
<XYKZC-KS-CORE-7506E-01>t m
<XYKZC-KS-CORE-7506E-01>t  d
The current terminal is enabled to display debugging logs.
<XYKZC-KS-CORE-7506E-01>*Aug 18 14:29:14:043 2017 XYKZC-KS-CORE-7506E-01 LOCALSER/7/EVENT: -MDC=1;
 Received authorization request message.
 Authorization failed, user "hxks" doesn&39;t exist.
Telnet logins are all authenticated with remote 3A. Generally, there is no need to configure the user name locally, because the command line authorization is also implemented through HwTACacs, and there is no need for local authorization.
4. Check the configuration under VTY and find that command authorization does exist:
line vty 0 4
 authentication-mode scheme
 user-role network-operator
 command accounting
Combined with point 2, command line authorization is the default mode, namely local authorization, because the local user name does not exist, so the command line authorization cannot be completed, resulting in the failure of command line authorization.
Solution
Since the RADIUS server is used as the 3A authentication server, it is not recommended to configure command line authorization; simply delete command line authorization.Of course, the on-site problem could be to add a user name to the device and reconfigure the user name with a role that would make command line authorization safe, but that would be unnecessary.
