Print
S3110高危端口封堵配置案例
2020-09-18 发表
组网及说明
为了进一步保证设备安全,需配置ACL对高危端口进行拦截。
S3110的版本信息如下:
H3C Comware Platform Software
Comware Software, Version 5.20.99, Release 1106
Copyright (c) 2004-2015 Hangzhou H3C Tech. Co., Ltd. All rights reserved.
H3C S3110-26TP uptime is 0 week, 0 day, 1 hour, 3 minutes
H3C S3110-26TP
128M    bytes DRAM
32M     bytes Flash Memory
Config Register points to Flash
Hardware Version is REV.A
Bootrom Version is 110
[SubSlot 0] 24FE+2GE Combo Hardware Version is REV.A
配置步骤
1、创建ACL,对高危端口进行拦截:
acl number 3210
 rule 0 deny tcp destination-port eq 135
 rule 1 deny udp destination-port eq 135
 rule 2 deny tcp destination-port eq 137
 rule 3 deny udp destination-port eq netbios-ns
 rule 4 deny tcp destination-port eq 138
 rule 5 deny udp destination-port eq netbios-dgm
 rule 6 deny udp destination-port eq netbios-ssn
 rule 7 deny tcp destination-port eq 139
 rule 8 deny tcp destination-port eq 445
 rule 9 deny udp destination-port eq 445
 rule 10 deny tcp destination-port eq 3389
 rule 11 deny udp destination-port eq 3389
 rule 20 deny tcp source-port eq 135
 rule 21 deny udp source-port eq 135
 rule 22 deny tcp source-port eq 137
 rule 23 deny udp source-port eq netbios-ns
 rule 24 deny tcp source-port eq 138
 rule 25 deny udp source-port eq netbios-dgm
 rule 26 deny udp source-port eq netbios-ssn
 rule 27 deny tcp source-port eq 139
 rule 28 deny tcp source-port eq 445
 rule 29 deny udp source-port eq 445
 rule 30 deny tcp source-port eq 3389
 rule 31 deny udp source-port eq 3389
 rule 1500 permit ip
2、将ACL下发到端口:
int  Ethernet 1/0/1
packet-filter 3210 inbound
packet-filter 3210 outbound
配置关键点
