Print
NQA链路探测失败,但是可以Ping通
3小时前 发表
组网及说明
设备的1口和3口均做了EASY IP
问题描述
现场配置了两个NQA探测,
nqa entry admin HHHH
type icmp-echo
destination ip 1.1.1.2
 frequency 100
 history-record enable
 next-hop ip 1.1.1.2
 reaction 1 checked-element probe-fail threshold-type consecutive 3 action-type trigger-only
 source interface GigabitEthernet1/0/1
nqa entry admin ZZZZ
 type icmp-echo
 destination ip 2.2.2.2
 frequency 100
 next-hop ip 2.2.2.2
 reaction 3 checked-element probe-fail threshold-type consecutive 3 action-type trigger-only
 source interface GigabitEthernet1/0/3
ip route-static 0.0.0.0 0 1.1.1.2 track 1 preference 2
ip route-static 0.0.0.0 0 2.2.2.2 track 2 preference 2
故障时候显示:
ping -a 1.1.1.1 1.1.1.2 可以通
但是
[F5010]dis nqa history
Index      Response      Status                    Time
 31             3000        Timeout            2021-02-02 18:09:16.0
过程分析
在设备上ping -a 1.1.1.1 1.1.1.2 发现会话:
[F5010-10.10.10.1]dis session table ipv4 protocol icmp source-ip 1.1.1.1 destination-ip 1.1.1.2 v
Slot 1:
Initiator:
  Source      IP/port: 1.1.1.1/17834
  Destination IP/port: 1.1.1.2/2048
  DS-Lite tunnel peer: -
  Protocol: ICMP(1)
  Inbound interface: InLoopBack0
  Source security zone: Local
Responder:
  Source      IP/port: 1.1.1.2/17834
  Destination IP/port: 1.1.1.1/0
  Protocol: ICMP(1)
  Inbound interface: GigabitEthernet1/0/1
  Source security zone: Untrust
State: ICMP_REPLY
Application: ICMP
Rule ID: 0
Rule name: any
Start time: 2021-02-02 19:03:57  TTL: 25s
Initiator->Responder:            5 packets        420 bytes
Responder->Initiator:            5 packets        420 bytes
Initiator:
  Source      IP/port: 1.1.1.1/533
  Protocol: ICMP(1)
Responder:
  Destination IP/port: 2.2.2.1/0
  Protocol: ICMP(1)
  Inbound interface: GigabitEthernet1/0/3
State: ICMP_REQUEST
Application: ICMP
Rule ID: 0
Rule name: any
Start time: 2021-01-29 07:53:30  TTL: 59s
Initiator->Responder:       123874 packets   15855872 bytes
Responder->Initiator:            0 packets          0 bytes
Total sessions found: 2
发现有一个建立连接很久的会话一直由1.1.1.1 到1.1.1.2,但是回包中,是由1.1.1.2 回到了3口2.2.2.1
从会话上来看,本地1.1到1.2一直有发包,但是一直没有回包
检查路由发现,有一条ip route-static 0.0.0.0 0 2.2.2.2 track 2 preference 2 路由,
由此断定,NQA HHHH在链路中断以后,本地HHHH的探测报文匹配路由表项外发,track 1 down以后,track 2让路由2.2.2.2生效
于是乎,NQA的1.1到1.2的探测报文要从3口发出,出3口以后,NAT实现转换,源地址转换成2.2.2.1访问1.1.1.2,但是由于网路不可达,外网无法回包。
NQA的1.1到1.2的探测报文在3口建立会话后,后续本地要发出的报文一直会匹配本会话,导致会话刷新,一直不会老化, 所以探测显示time out。
但是ping -a 1.1.1.1 1.1.1.2可以通的原因是,设备学到1.2的ARP是从1口学到的,ping报文是从1口发出。
解决方法
1、在1链路正常的情况下,清除3口的会话,让NQA HHHH的探测报文从1口建立发出;
2、为了避免1链路出现down以后,上面的现象复现,建议现场把NQA探测报文中source interface GigabitEthernet1/0/1 改成out interface GigabitEthernet1/0/1 ,让探测的报文只能从1口出去,出不去就显示链路不可达。
out interface命令用来指定探测报文的出接口。
undo out interface命令用来恢复缺省情况。
out interface interface-type interface-number
undo out interface
未指定探测报文的出接口。
ICMP-echo测试类型视图
DHCP测试类型视图
UDP-tracert测试类型视图
UDP-jitter测试类型视图
DNS/ICMP/TCP Half Open类型的NQA模板视图
context-admin
interface-type interface-number:探测报文出接口的接口类型和接口编号。
该命令指定的接口必须处于UP状态,否则NQA探测过程将会失败。
对于TCP Half Open类型的NQA模板,该命令指定的接口不能为Dialer接口,否则NQA探测过程将会失败。
对于ICMP-echo测试类型和DNS/ICMP/TCP Half Open类型的NQA模板,如果配置next-hop命令,此配置不生效。
# ICMP-echo测试类型下配置接口GigabitEthernet1/0/1作为ICMP-echo探测报文出接口。
[Sysname] nqa entry admin test
[Sysname-nqa-admin-test] type icmp-echo
[Sysname-nqa-admin-test-icmp-echo] out interface gigabitethernet 1/0/1
