Print
Announcement on abnormal restart of H3C S5560-EI&S5560-EI-D&S5130-HI series switch products
2021-03-12 Published
Problem Description
Announcement category
Mandatory rectification
Operational requirements
Patch upgrade, version upgrade
Product Model
H3C S5560-EI series
H3C S5560-EI-D series
H3C S5130-HI series
Involved Version
R3506P07R3506P10
Problem Description
When the above-mentioned device loads the above-mentioned software version, there is a small probability that the device restarts abnormally during operation, and the reason for the restart cannot be recorded correctly. Devices with POE function have a higher probability of triggering this problem.
Cause Analysis
Cause Analysis
The above-mentioned software version bus access mechanism is ill-considered, which may cause abnormal data processing in the device"s CPU.
Circumvention measures/solutions
Workaround/Solutions
1. For R3506P10 version, please deploy the R3506P10H01 patch as soon as possible.
2. It is recommended to upgrade to R3506P12 (expected to be released before April 30, 2021) and later versions.
