Print
BFD for BGP configuration
2021-05-21 Published
Network Topology
Network requirements
As shown in Figure, configure OSPF as the IGP in AS 200.
·           Establish two IBGP connections between Switch A and Switch C. When both paths operate correctly, Switch C uses the path Switch A<—>Switch B<—>Switch C to exchange packets with network 1.1.1.0/24.
·           Configure BFD over the path. When the path fails, BFD can quickly detect the failure and notify it to BGP. Then, the path Switch A<—>Switch D<—>Switch C takes effect immediately.
Device
interface
IP
Device
interface
IP
Switch A
Vlan-int100
3.0.1.1/24
Switch C
Vlan-int101
3.0.2.2/24
Vlan-int200
2.0.1.1/24
Vlan-int201
2.0.2.2/24
Loopback0
1.1.1.1/24
Loopback0
5.5.5.5/24
Switch B
Vlan-int100
3.0.1.2/24
Switch D
Vlan-int200
2.0.1.2/24
Vlan-int101
3.0.2.1/24
Vlan-int201
2.0.2.1/24
Configuration Steps
Configuration procedure
1. Swithc A
ospf 1
 area 0.0.0.0
  network 2.0.1.0 0.0.0.255
  network 3.0.1.0 0.0.0.255
acl number 2000
 rule 0 permit source 1.1.1.0 0.0.0.255
route-policy apply_med_100 permit node 10
 if-match ip address acl 2000
 apply cost 100
route-policy apply_med_50 permit node 10
 apply cost 50
bgp 200
 peer 2.0.2.2 as-number 200
 peer 3.0.2.2 as-number 200
 peer 3.0.2.2 bfd
 address-family ipv4 unicast
  network 1.1.1.0 255.255.255.0
  peer 2.0.2.2 enable
  peer 2.0.2.2 route-policy apply_med_100 export
  peer 3.0.2.2 enable
  peer 3.0.2.2 route-policy apply_med_50 export
2. Swithc C
ospf 1
 area 0.0.0.0
  network 2.0.2.0 0.0.0.255
  network 3.0.2.0 0.0.0.255
acl number 2000
 rule 0 permit source 5.5.5.0 0.0.0.255
 apply cost 100
 apply cost 50
bgp 200
 peer 2.0.1.1 as-number 200
 peer 3.0.1.1 as-number 200
 peer 3.0.1.1 bfd
  network 5.5.5.0 255.255.255.0
  peer 2.0.1.1 enable
  peer 2.0.1.1 route-policy apply_med_100 export
  peer 3.0.1.1 enable
  peer 3.0.1.1 route-policy apply_med_50 export
3. Swithc B
ospf 1
 area 0.0.0.0
 ip route-static 1.1.1.0 24 3.0.1.1
 ip route-static 5.5.5.0 24 3.0.2.2
4. Swithc D
ospf 1
 area 0.0.0.0
ip route-static 1.1.1.0 24 2.0.1.1
 ip route-static 5.5.5.0 24 2.0.2.2
1. # Display detailed BFD session information on Switch C.
 [SwitchC]dis bfd session verbose
       Local Discr: 129                  Remote Discr: 129
         Source IP: 3.0.2.2            Destination IP: 3.0.1.1
     Session State: Up                      Interface: N/A
      Min Tx Inter: 400ms                Act Tx Inter: 400ms
      Min Rx Inter: 400ms                Detect Inter: 2000ms
          Rx Count: 2                        Tx Count: 6
      Connect Type: Indirect           Running Up for: 00:16:04
         Hold Time: 1600ms                  Auth mode: None
       Detect Mode: Async                        Slot: 1
          Protocol: BGP
           Version: 1
         Diag Info: No Diagnostic
The output shows that a BFD session has been established between Switch A and Switch C
[SwitchC]dis bgp peer ipv4
 BGP local router ID: 10.3.1.1
 Local AS number: 200
 Total number of peers: 2                 Peers in established state: 2
  * - Dynamically created peer
  ^ - Peer created through link-local address
  2.0.1.1                200      101      101    0       1 01:21:30 Established
  3.0.1.1                200       11       11    0       1 00:06:39 Established
The output shows that Switch C has established two BGP connections with Switch A, and both connections are in Established state
[SwitchC]ping -a 5.5.5.5 1.1.1.1
Ping 1.1.1.1 (1.1.1.1) from 5.5.5.5: 56 data bytes, press CTRL+C to break
56 bytes from 1.1.1.1: icmp_seq=0 ttl=254 time=2.180 ms
56 bytes from 1.1.1.1: icmp_seq=1 ttl=254 time=6.879 ms
56 bytes from 1.1.1.1: icmp_seq=2 ttl=254 time=1.904 ms
56 bytes from 1.1.1.1: icmp_seq=3 ttl=254 time=1.900 ms
56 bytes from 1.1.1.1: icmp_seq=4 ttl=254 time=1.904 ms
2. # Display route 1.1.1.0/24 on Switch C.
[SwitchC]dis ip routing-table 1.1.1.1 verbose
Summary count : 1
Destination: 1.1.1.0/24
   Protocol: BGP instance default
 Process ID: 0
  SubProtID: 0x1                    Age: 00h17m30s
       Cost: 50              Preference: 255
      IpPre: N/A             QosLocalID: N/A
        Tag: 0                    State: Active Adv
  OrigTblID: 0x0                OrigVrf: default-vrf
    TableID: 0x2                 OrigAs: 0
      NibID: 0x16000001          LastAs: 0
     AttrID: 0x1               Neighbor: 3.0.1.1
      Flags: 0x10060        OrigNextHop: 3.0.1.1
      Label: NULL           RealNextHop: 3.0.2.1
    BkLabel: NULL             BkNextHop: N/A
    SRLabel: NULL             BkSRLabel: NULL
   SIDIndex: NULL               InLabel: NULL
  Tunnel ID: Invalid          Interface: Vlan-interface101
BkTunnel ID: Invalid        BkInterface: N/A
   FtnIndex: 0x0           TrafficIndex: N/A
  Connector: N/A                 PathID: 0x0
   LinkCost: 0               MicroSegID: 0
The output shows that Switch C communicates with network 1.1.1.0/24 through the path Switch C<—>Switch B<—>Switch A.
3.  # Break down the path Switch C<—>Switch B<—>Switch A and then display route 1.1.1.0/24 on Switch C.
 [Swtich B]interface Ten-GigabitEthernet1/0/1
 [Swtich B-Ten-GigabitEthernet1/0/1]shutdown
Summary count : 1
 Process ID: 0
  SubProtID: 0x1                    Age: 00h00m49s
       Cost: 100             Preference: 255
      NibID: 0x16000002          LastAs: 0
     AttrID: 0x2               Neighbor: 2.0.1.1
      Flags: 0x10060        OrigNextHop: 2.0.1.1
      Label: NULL           RealNextHop: 2.0.2.1
  Tunnel ID: Invalid          Interface: Vlan-interface201
The output shows that Switch C communicates with network 1.1.1.0/24 through the path Switch C<—>Switch D<—>Switch A.
Key Configuration
