Print
The server failed to expand into UIS cluster after replacing the motherboard
2021-05-30 Published
Network Topology
irrelevant
Problem Description
After replacing the UIS-Cell-3030 motherboard, I found that reinstalling the UIS could not join the original cluster.
 Scaling cannot see the disk for the new node
Process analysis
It is found that the product name layer of this node is UIS-Cell-3000. This is because the UIS-Cell-3000 G3 servers are all modified from R4900 G3. Therefore, after replacing the motherboard, new information needs to be burned to the motherboard
Solution
To burn UIS-Cell-3030 to a new motherboard, find the "Server Modifying Device Name Guide" in the UIS Version Guide and use the tool ipmitool. exe to burn the server name.
