Customer install DR2000 target version is E0508H14, base install is E0508
When installing DR2000 E0508, enter the password of SA user in database, it fails to pass the test, and the error is: Connecting to the database failed. Make sure the database is running normally and you have input correct login information.
1.Check that you log in to the database using an SA account and check the TCP/IP configuration in the database.
2.check C:\Windows\iMC-Reserved\log\install_xxxxxx.log, and this log will record the information and tips during the iMC installation.
2021-06-11 22:15:19 [ERROR] [SwingWorker-pool-1-thread-2] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor$DbConnectCheckingWorkingDialog::doWork(1839)] Connect to database error
com.microsoft.sqlserver.jdbc.SQLServerException: The driver could not establish a secure connection to SQL Server by using Secure Sockets Layer (SSL) encryption. Error: "java.lang.RuntimeException: Could not generate DH keypair". ClientConnectionId:43ae1232-b418-4dc9-bc59-9d63798043e8
