None
For successful OS installation, you must use an OS image integrated with a storage controller driver if a storage controller has been installed on the server.
1.First prepare the storage controller driver,original VMware ESXI OS image and ESXI-Customizer-PS in the same directory.
6. Execute the #Get-EsxImageProfile command to obtain the name of the target configuration file
7. Execute the #Add-EsxSoftwarePackage-ImageProfile configuration_file_name SoftwarePackage driver_name command to integrate the OS image and the driver.
8. Execute the #Esxport-EsxImageProfile-ImageProfile configuration_file_name -ExportToIso -FilePath export_path and file name command to export the OS image integrated with the driver.
None
