Print
S5120V2-52P-LI High memory utilisation
2021-06-30 Published
Network Topology
null
Problem Description
It have been noticed that memory usage is 64% which seems higher.
  ===============display memory===============
Memory statistics are measured in KB:
Slot 1:
                   Total        Used        Free        Shared   Buffers    Cached   FreeRatio
Mem:        506408    326768    179640         0         1376       122392       35.6%
-/+ Buffers/Cache:    203000    303408
Swap:            0         0         0
Process analysis
The cached memory utilisation is around 24% which is relatively high.
Cached memory is a mechanism used by Linux to speed up file read and write speed. It cannot be disabled and it would be automatically reclaimed by the system before memory thresholds are triggered. Recycled memory would be what no one is using and what is in use will not be released and will not affect other services.
Solution
If the memory utilisation don’t keep increasing, please don’t worry about it.
