Print
comwareV7平台中日志Phase Num is 4(local in beforedefrag)被丢的原因
2小时前 发表
问题描述
现场debug报:
  *Nov 26 09:30:32:779 2021 H3C ASPF/7/PACKET: -COntext=1; The first packet was dropped by packet filter or object-policy. Src-ZOne=Trust, Dst-ZOne=Local;If-In=Vlan-interface4091(156), If-Out=InLoopBack0(148); Packet Info:Src-IP=1.1.1.1, Dst-IP=2.2.2.2, VPN-Instance=none, Src-Port=1, Dst-Port=2048. Protocol=ICMP(1).
*Nov 26 09:30:32:779 2021 H3C IPFW/7/IPFW_INFO: -COntext=1;
MBUF was intercepted! Phase Num is 4(local in beforedefrag), Service ID is 1(interzone), Bitmap is 4400000000000000, return 1(0:continue, 1:dropped, 2:consumed, 3:enqueued, 4:relay)! Interface is Vlan-interface4091,
s= 1.1.1.1, d= 2.2.2.2, protocol= 1, pktid = 12656.
解决方法
现场配置了:
  info-center source FILTER monitor deny
开了这个,所以看不到debug策略的日志,所以看不到被哪个策略拒了 。
