现场VPN1与VPN2建立IPSEC,VPN1与VPN2分别做NAT穿越,对应的NAT设备为NAT1与NAT2,VPN1与VPN2以loopback地址作为感兴趣流
同时NAT1与VPN3也以NAT1接口的地址与VPN3建立IPSEC
此时VPN1与VPN2的IPSEC已经建立,但是内网不通
<H3C>display ike sa
Connection-ID Remote Flag DOI
2 59.60.50.182 RD IPsec
Flags:
RD--READY RL--REPLACED FD-FADING RK-REKEY
<H3C>dis
<H3C>display ips
<H3C>display ipsec sa
Interface: GigabitEthernet1/0/0
IPsec policy: GE1/0/5
Sequence number: 1
Mode: ISAKMP
Tunnel id: 0
Encapsulation mode: tunnel
Perfect Forward Secrecy:
Inside VPN:
Extended Sequence Numbers enable: N
Traffic Flow Confidentiality enable: N
Path MTU: 1420
Tunnel:
local address: 59.79.225.37
remote address: 59.60.50.182
Flow:
sour addr: 210.34.0.0/255.255.0.0 port: 0 protocol: ip
dest addr: 172.24.1.0/255.255.255.0 port: 0 protocol: ip
[Inbound ESP SAs]
SPI: 1658787368 (0x62df1628)
Connection ID: 12884901888
Transform set: ESP-ENCRYPT-AES-CBC-128 ESP-AUTH-SHA1
SA duration (kilobytes/sec): 1843200/3600
SA remaining duration (kilobytes/sec): 1843200/3582
Max received sequence-number: 0
Anti-replay check enable: Y
Anti-replay window size: 64
UDP encapsulation used for NAT traversal: Y
Status: Active
[Outbound ESP SAs]
SPI: 1855698879 (0x6e9bb7bf)
Connection ID: 4294967297
SA remaining duration (kilobytes/sec): 1843199/3582
Max sent sequence-number: 4
Status: Active
<H3C>
在NAT1设备上,Debug查看,有ISPEC丢包
*Jan 10 14:21:35:111 2022 H3C IPFW/7/IPFW_INFO:
MBUF was intercepted! Phase Num is 1(pre routing), Service ID is 7(ipsec), Bitmap is 1a00080, return 1(0:continue, 1:dropped, 2:consumed, 3:enqueued, 4:relay)! Interface is GigabitEthernet0/2,
s= 59.60.50.182, d= 59.60.50.181, protocol= 17, pktid = 46.
经分析,NAT1设备将VPN1设备建立IPSEC的地址做了NAT,但是使用的是接口地址,同时NAT1设备又以1.1.1.1的sub地址与VPN3的1.1.1.2地址建立IPSEC,当前设备处理的流程是,如果设备收到一个IPSEC报文的目的地址是本地接口地址,就会走本设备接口下的IPSEC解密流程,由于VPN1访问VPN2的时候,使用的是VPN1与VPN2的IPSEC隧道,这个回程报文走到NAT1设备上,当然走不了解密流程。
interface GigabitEthernet0/2
port link-mode route
combo enable copper
ip address 59.60.50.181 255.255.255.0
ip address 1.1.1.1 255.255.255.0 sub
nat outbound 3001 port-preserved
nat server global 59.60.50.181 inside 59.79.225.37 reversible
ipsec apply policy test
combo enable copper
ip address 59.60.50.183 255.255.255.0
在NAT1设备上配置NAT SERVER映射VPN1设备的地址的时候,使用的地址和接口同一个网段,但是改地址又不是设备地址
改过之后,VPN1设备可以以loopback地址访问VPN2设备的loopback地址
<H3C>
<H3C> ping -a 210.34.0.1 172.24.1.1
Ping 172.24.1.1 (172.24.1.1) from 210.34.0.1: 56 data bytes, press CTRL_C to break
Request time out
56 bytes from 172.24.1.1: icmp_seq=1 ttl=255 time=1.000 ms
56 bytes from 172.24.1.1: icmp_seq=2 ttl=255 time=2.000 ms
56 bytes from 172.24.1.1: icmp_seq=3 ttl=255 time=2.000 ms
56 bytes from 172.24.1.1: icmp_seq=4 ttl=255 time=2.000 ms
