Print
某局点S12504R VRRP虚地址32位主机路由学习在两个VPN中
2022-02-23 发表
组网及说明
设备:S12504R
涉及问题的版本:F3606 F3607 F3607P02
组网:两台12504R设备 VRRP组网,做下行设备的网关
问题描述
问题描述:设备为VRRP主设备,在三层口下绑定VPN 5GC_MGMN_in 然后配置VRRP相关配置,查看路由时发现在另一VPN 5GC_MGMN 中也能看到VRRP 虚地址的32位主机路由
相关配置:
interface Vlan-interface505
description to-S5552S-MGMN_IPMI
ip binding vpn-instance 5GC_MGMN_in
ip address 1.86.145.124 255.255.255.192
vrrp vrid 205 virtual-ip 1.86.145.126
vrrp vrid 205 priority 110
vrrp vrid 205 preempt-mode delay 5000
查看路由:
过程分析
梳理现场的操作记录发现,该接口原本绑定了VPN 5GC_MGMN 并配置了VRRP相关配置,重新规划组网后,现场直接将该VPN修改为5GC_MGMN_in 并配置上了相同的VRRP配置。
查看底层信息发现,在将VPN进行修改时,原本VPN下的VRRP虚地址32位主机路由没有删除的动作,因此在老VPN中依旧有路由。
[SNYL-GX5F-MEC_SPINE-S12504R-M-probe]display system internal route-direct event log reverse | inc f403
IPADDR_ADD Type=0x8000,vrfIdx=10,mtIdx=0,IfIdx=0xf403,1.86.145.126/32.                           //绑定新VPN时下发的路由
IPADDR_ADD Type=0x1,vrfIdx=10,mtIdx=0,IfIdx=0xf403,1.86.145.124/26.
DEBUG proc down->up State=0x8401,vrfIdx=0,mtIdx=0,IfIdx=0xf403,phyState=0x8480.
NET_UP State=0x8401,vrfIdx=0,mtIdx=0,IfIdx=0xf403.
VPN_BIND IfIdx=0xf403,VrfIdx=0xa.
IPADDR_DEL Type=0x1,vrfIdx=1,mtIdx=0,IfIdx=0xf403,1.86.145.124/26.
NET_DOWN State=0x4,vrfIdx=0,mtIdx=0,IfIdx=0xf403.
VPN_UNBIND IfIdx=0xf403,VrfIdx=0x1.
IPADDR_ADD Type=0x1,vrfIdx=1,mtIdx=0,IfIdx=0xf403,1.86.145.124/26.
IPADDR_DEL Type=0x1,vrfIdx=1,mtIdx=0,IfIdx=0xf403,1.86.145.125/26.
IPADDR_DEL Type=0x8000,vrfIdx=1,mtIdx=0,IfIdx=0xf403,1.86.145.1/32.
IPADDR_ADD Type=0x8000,vrfIdx=1,mtIdx=0,IfIdx=0xf403,1.86.145.126/32.                             //之前绑定老VPN时下发的路由,修改VPN后应该有个IPADDR_DEL 字段将这个老的路由删除
IPADDR_ADD Type=0x1,vrfIdx=1,mtIdx=0,IfIdx=0xf403,1.86.145.125/26.
IPADDR_DEL Type=0x1,vrfIdx=1,mtIdx=0,IfIdx=0xf403,1.86.145.30/27.
IPADDR_ADD Type=0x8000,vrfIdx=1,mtIdx=0,IfIdx=0xf403,1.86.145.1/32.
NET_UP State=0x8480,vrfIdx=0,mtIdx=0,IfIdx=0xf403.
DEBUG proc down->up State=0x8401,vrfIdx=0,mtIdx=0,IfIdx=0xf403,phyState=0x8400.
IPADDR_ADD Type=0x1,vrfIdx=1,mtIdx=0,IfIdx=0xf403,1.86.145.30/27.
VPN_BIND IfIdx=0xf403,VrfIdx=0x1.
IF_ACTIVE State=0x8400,vrfIdx=1,mtIdx=0,IfIdx=0xf403,Vlan-interface505.
IF_CREATE State=0x8400,vrfIdx=0,mtIdx=0,IfIdx=0xf403,Vlan-interface505.
问题触发原因:下发undo ip bind vpn时,vrrp响应l3vpn去绑定事件,会删除vrrp虚ip并通知地址管理,通知地址管理时填充参数的vrfIndex为当前的值(undo后为0),实际应该使用添加时候的值(配置vpn时的值为1)。Vrf填充错误因此地址管理没有发布删除事件,导致路由残留。
解决方法
规避恢复方法
1、先把绑定新VPN端口下的VRRP配置删除掉, 再把VPN修改为之前残留的VPN,然后配上VRRP配置,再把VRRP配置删除,最后再把VPN改为新VPN 再加上VRRP配置
2、设备重启
彻底解决方法
在新版本F3608中解决该问题。
