Print
12508X-AF ISSU升级操作步骤说明
4天前 发表
组网及说明
堆叠组网:
问题描述
12508X-AF 从2710到2713 ISSU升级
测试12504X-AF issu升级过程中,三层转发丢包情况,链路聚合情况等
过程分析
1、检查ISSU状态,初始状态如下:
<2012-125X-AF>DIS issu state
ISSU state: Init
Compatibility: Unknown
Work state: Normal
Upgrade method: Chassis by chassis
Upgraded chassis: None
Current upgrading chassis: None
Current version list:
  boot: 7.1.070P2285, Release 2710
  system: 7.1.070, Release 2710
Current software images:
  flash:/S12500X-CMW710-BOOT-R2710.bin
  flash:/S12500X-CMW710-SYSTEM-R2710.bin
<2012-125X-AF>dis dev
Slot   Type                State    Subslot  Soft Ver             Patch Ver
1/0    LSXM1TGS48HB1       Normal   0        S12504X-AF-2710      None
1/1    NONE                Absent   0        NONE                 None
1/2    NONE                Absent   0        NONE                 None
1/3    LSXM1TGS48HB1       Normal   0        S12504X-AF-2710      None
1/4    LSXM1SUP04H1        Master   0        S12504X-AF-2710      None
1/5    LSXM1SUP04H1        Standby  0        S12504X-AF-2710      None
1/6    LSXM1SFH04D1        Normal   0        S12504X-AF-2710      None
1/7    LSXM1SFH04D1        Normal   0        S12504X-AF-2710      None
1/8    LSXM1SFH04D1        Normal   0        S12504X-AF-2710      None
1/9    LSXM1SFH04D1        Normal   0        S12504X-AF-2710      None
1/10   LSXM1SFH04D1        Normal   0        S12504X-AF-2710      None
1/11   LSXM1SFH04D1        Normal   0        S12504X-AF-2710      None
2/0    NONE                Absent   0        NONE                 None
2/1    LSXM1TGS48HB1       Normal   0        S12504X-AF-2710      None
2/2    NONE                Absent   0        NONE                 None
2/3    LSXM1TGS48HB1       Normal   0        S12504X-AF-2710      None
2/4    LSXM1SUP04H1        Standby  0        S12504X-AF-2710      None
2/5    LSXM1SUP04H1        Standby  0        S12504X-AF-2710      None
2/6    LSXM1SFH04D1        Normal   0        S12504X-AF-2710      None
2/7    LSXM1SFH04D1        Normal   0        S12504X-AF-2710      None
2/8    LSXM1SFH04D1        Normal   0        S12504X-AF-2710      None
2/9    LSXM1SFH04D1        Normal   0        S12504X-AF-2710      None
2/10   LSXM1SFH04D1        Normal   0        S12504X-AF-2710      None
2/11   LSXM1SFH04D1        Normal   0        S12504X-AF-2710      None
2、查看兼容性及升级方式为reboot升级;
<2012-125X-AF>dis version comp-matrix file boot chassis1#slot4#flash:/S12500X-CM
W710-BOOT-R2713.bin system chassis1#slot4#flash:/S12500X-CMW710-SYSTEM-R2713.bin
Verifying the file flash:/S12500X-CMW710-BOOT-R2713.bin on chassis 1 slot 4............Done.
Verifying the file flash:/S12500X-CMW710-SYSTEM-R2713.bin on chassis 1 slot 4....................................................................................Done.
Identifying the upgrade methods...Done.
  Chassis   Slot              Upgrade Way
  1         0                 Reboot
  1         3                 Reboot
  1         4                 Reboot
  1         5                 Reboot
  1         6                 Reboot
  1         7                 Reboot
  1         8                 Reboot
  1         9                 Reboot
  1         10                Reboot
  1         11                Reboot
  2         1                 Reboot
  2         3                 Reboot
  2         4                 Reboot
  2         5                 Reboot
  2         6                 Reboot
  2         7                 Reboot
  2         8                 Reboot
  2         9                 Reboot
  2         10                Reboot
  2         11                Reboot
3、 关闭回滚
[2012-125X-AF]issu rollback-timer  0
Link-delay设置0
[2012-125X-AF]irf link-delay 0
路由NSR配上,检查设备聚合配置不存在短超时的配置,MAD关闭
<2012-125X-AF>dis cu configuration bgp
bgp 64521
 non-stop-routing
<2012-125X-AF>dis cu configuration ospf
ospf 1
 non-stop-routing
 area 0.0.0.0
检查系统状态都是stable
[2012-125X-AF]dis system stable state
System state     : Stable
Redundancy state : Stable
  Chassis    Slot    CPU    Role       State
  1          4       0      Active     Stable
  1          0       0      Other      Stable
  1          3       0      Other      Stable
  1          5       0      Standby    Stable
  1          6       0      Other      Stable
  1          7       0      Other      Stable
  1          8       0      Other      Stable
  1          9       0      Other      Stable
  1          10      0      Other      Stable
  1          11      0      Other      Stable
  2          1       0      Other      Stable
  2          3       0      Other      Stable
  2          4       0      Standby    Stable
  2          5       0      Standby    Stable
  2          6       0      Other      Stable
  2          7       0      Other      Stable
  2          8       0      Other      Stable
  2          9       0      Other      Stable
  2          10      0      Other      Stable
  2          11      0      Other      Stable
4、 检查聚合状态,路由状态,都是正常:
[2012-125X-AF-Bridge-Aggregation2]dis ip routing-table 192.2.2.2
Summary count : 1
192.2.2.2/32       O_INTRA 10  1           10.1.1.64       Vlan10
[2012-125X-AF-Bridge-Aggregation2]dis ip routing-table 20.1.1.1
 Summary count : 1
20.1.1.0/24        BGP     255 0           10.1.1.64       Vlan10
[2012-125X-AF-Bridge-Aggregation2]dis bgp peer ipv4 unicast
  BGP local router ID: 30.253.255.65
 Local AS number: 64521
 Total number of peers: 3                 Peers in established state: 1
  * - Dynamically created peer
  10.1.1.64              100       36       36    0       8 00:18:39 Established
  173.1.1.2              100        0        0    0       0 21:03:05 Connect
  192.168.12.2           100        0        0    0       0 21:03:05 Connect
[2012-125X-AF-Bridge-Aggregation2]dis ospf peer
         OSPF Process 1 with Router ID 30.253.255.65
               Neighbor Brief Information
 Area: 0.0.0.0
 Router ID       Address         Pri Dead-Time  State             Interface
 192.2.2.2       10.1.1.64       1   34         Full/BDR          Vlan10
Aggregation Mode: Dynamic
Loadsharing Type: Shar
Management VLANs: None
System ID: 0x8000, 74ea-c830-5000
Local:
  Port                Status   Priority Index    Oper-Key               Flag
  XGE1/3/0/1(R)       S        32768    2        2                      {ACDEF}
  XGE2/1/0/1          S        32768    5        2                      {ACDEF}
Remote:
  Actor               Priority Index    Oper-Key SystemID               Flag
  XGE1/3/0/1          32768    2        2        0x8000, 9ce8-9572-a12a {ACDEF}
  XGE2/1/0/1          32768    3        2        0x8000, 9ce8-9572-a12a {ACDEF}
Aggregate Interface: Bridge-Aggregation2
Local:
  XGE1/3/0/12(R)      S        32768    3        3                      {ACDEF}
  XGE2/3/0/12         S        32768    4        3                      {ACDEF}
Remote:
  XGE1/3/0/12         32768    5        4        0x8000, f474-88dd-ddf6 {ACDEF}
  XGE2/3/0/12         32768    2        4        0x8000, f474-88dd-ddf6 {ACDEF}
5、 执行第一步升级备框:
<2012-125X-AF>issu load file boot chassis1#slot4#flash:/S12500X-CMW710-BOOT-R271
3.bin system chassis1#slot4#flash:/S12500X-CMW710-SYSTEM-R2713.bin c
3.bin system chassis1#slot4#flash:/S12500X-CMW710-SYSTEM-R2713.bin chassis 2
This operation will delete the rollback point information for the previous upgrade and maybe get unsaved configuration lost. Continue? [Y/N]:y
Verifying the file flash:/S12500X-CMW710-BOOT-R2713.bin on chassis 1 slot 4...Done.
Verifying the file flash:/S12500X-CMW710-SYSTEM-R2713.bin on chassis 1 slot 4..............Done.
File flash:/S12500X-CMW710-BOOT-R2713.bin already exists on chassis 2 slot 4.
File flash:/S12500X-CMW710-SYSTEM-R2713.bin already exists on chassis 2 slot 4.
Overwrite the existing files? [Y/N]:n
File flash:/S12500X-CMW710-BOOT-R2713.bin already exists on chassis 2 slot 5.
File flash:/S12500X-CMW710-SYSTEM-R2713.bin already exists on chassis 2 slot 5.
Verifying the file flash:/S12500X-CMW710-BOOT-R2713.bin on chassis 2 slot 4............Done.
Verifying the file flash:/S12500X-CMW710-SYSTEM-R2713.bin on chassis 2 slot 4......................................................................................Done.
Verifying the file flash:/S12500X-CMW710-BOOT-R2713.bin on chassis 2 slot 5.............Done.
Verifying the file flash:/S12500X-CMW710-SYSTEM-R2713.bin on chassis 2 slot 5.....................................................................................Done.
  Running Version             New Version
  Release 2710                Release 2713
  2         1                 Reboot
  2         3                 Reboot
  2         4                 Reboot
  2         5                 Reboot
  2         6                 Reboot
  2         7                 Reboot
  2         8                 Reboot
  2         9                 Reboot
  2         10                Reboot
  2         11                Reboot
%Feb  1 05:52:36:238 2026 2012-125X-AF SHELL/5/SHELL_LOGIN: -MDC=1; TTY logged in from aux1/1.
%Feb  1 05:53:46:680 2026 2012-125X-AF LAGG/6/LAGG_INACTIVE_PHYSTATE: -MDC=1; Member port XGE2/1/0/1 of aggregation group BAGG1 changed to the inactive state, because the physical state of the port is down.
%Feb  1 05:53:46:684 2026 2012-125X-AF LAGG/6/LAGG_INACTIVE_PHYSTATE: -MDC=1; Member port XGE2/3/0/12 of aggregation group BAGG2 changed to the inactive state, because the physical state of the port is down.
%Feb  1 05:53:46:707 2026 2012-125X-AF IFNET/5/LINK_UPDOWN: -MDC=1; Line protocol state on the interface Ten-GigabitEthernet2/1/0/1 changed to down.
%Feb  1 05:53:46:731 2026 2012-125X-AF DEV/5/CHASSIS_REBOOT: -MDC=1; Chassis 2 is rebooting now.
%Feb  1 05:53:46:736 2026 2012-125X-AF IFNET/5/LINK_UPDOWN: -MDC=1; Line protocol state on the interface Ten-GigabitEthernet2/3/0/12 changed to down.
<2012-125X-AF>
<2012-125X-AF>
<2012-125X-AF>
<2012-125X-AF>
System is starting...
Press Ctrl+D to access BASIC-BOOTWARE MENU...
Press Ctrl+T to start memory test
Booting Normal Extended BootWare
The Extended BootWare is self-decompressing..........Done.
*                         BootWare, Version 1.58                           *
Compiled Date         : Sep  8 2017
CPU Type              : XLP316
CPU Clock Speed       : 1200MHz
Memory Type           : DDR3 SDRAM
Memory Size           : 16384MB
Memory Speed          : 667MHz
BootWare Size         : 1536KB
Flash Size            : 1024MB
BASIC CPLD Version    : 4.0
EXTENDED CPLD Version : 4.0
PCB Version           : Ver.A
BootWare Validating...
Press Ctrl+B to access EXTENDED-BOOTWARE MENU...
Loading the main image files...
Loading file flash:/S12500X-CMW710-SYSTEM-R2713.bin.........................
Loading file flash:/S12500X-CMW710-BOOT-R2713.bin...........................
Done.
Image file flash:/S12500X-CMW710-BOOT-R2713.bin is self-decompressing.......
System image is starting...
Waiting for StackBoard to insert, this process may occupy time up to 600 seconds.
STM Init Start.
Cryptographic algorithms tests passed.
Line aux2/1 is available.
Press ENTER to get started.
<2012-125X-AF>
<2012-125X-AF>%Feb  1 06:05:10:027 2026 2012-125X-AF SHELL/5/SHELL_LOGIN: -MDC=1; TTY logged in from aux2/1.
2/1    LSXM1TGS48HB1       Normal   0        S12504X-AF-2713      None
2/3    LSXM1TGS48HB1       Normal   0        S12504X-AF-2713      None
2/4    LSXM1SUP04H1        Standby  0        S12504X-AF-2713      None
2/5    LSXM1SUP04H1        Standby  0        S12504X-AF-2713      None
2/6    LSXM1SFH04D1        Normal   0        S12504X-AF-2713      None
2/7    LSXM1SFH04D1        Normal   0        S12504X-AF-2713      None
2/8    LSXM1SFH04D1        Normal   0        S12504X-AF-2713      None
2/9    LSXM1SFH04D1        Normal   0        S12504X-AF-2713      None
2/10   LSXM1SFH04D1        Normal   0        S12504X-AF-2713      None
2/11   LSXM1SFH04D1        Normal   0        S12504X-AF-2713      None
<2012-125X-AF>
路由正常:
<2012-125X-AF>dis ip routing-table
Destinations : 41Routes : 41
<2012-125X-AF>
聚合正常:
<2012-125X-AF>dis link-aggregation verbose Bridge-Aggregation 1
Port: A -- Auto port, M -- Management port, R -- Reference port
Flags:  A -- LACP_Activity, B -- LACP_Timeout, C -- Aggregation,
        G -- Defaulted, H -- Expired
Local:
Remote:
Local:
  XGE1/3/0/12         S        32768    3        3                      {ACDEF}
  XGE2/3/0/12(R)      S        32768    1        3                      {ACDEF}
Remote:
<2012-125X-AF>
Issu状态:
<2012-125X-AF>dis issu state
ISSU state: Loading
Compatibility: Compatible
Work state: Normal
  chassis 2
Previous version list:
Previous software images:
Upgrade version list:
  boot: 7.1.070P2216, Release 2713
  system: 7.1.070, Release 2713
Upgrade software images:
<2012-125X-AF>
<2012-125X-AF>
ISSU state: Loaded
Work state: Normal
Upgraded chassis:
  chassis 2
<2012-125X-AF>
<2012-125X-AF>
<2012-125X-AF>
7、执行主备倒换:
<2012-125X-AF>issu run switchover
%Feb  1 06:07:56:210 2026 2012-125X-AF PKG/5/PKG: -MDC=1; Boot image successfully loaded to the card.
  Chassis   Slot              Switchover Way
  1         4                 Global active standby MPU switchover
Before pressing ENTER you must choose 'YES' or 'NO'[Y/N]:
This command has been cancelled.
This operation might take several minutes, please wait.....%Feb  1 06:08:29:105 2026 2012-125X-AF PKG/5/PKG: -MDC=1; This operation starts to reboot the specified slot to complete upgrade.
....%Feb  1 06:08:32:816 2026 2012-125X-AF DEV/5/BOARD_REBOOT: -MDC=1; Board is rebooting on chassis 1 slot 4.
<2012-125X-AF>dis iss%Feb  1 06:08:44:431 2026 2012-125X-AF DEV/2/BOARD_STATE_FAULT: -MDC=1; Board state changed to Fault on chassis 1 slot 4, type is unknown.
ISSU state: Switching
Work state: Normal
Upgraded chassis:
  chassis 2
<2012-125X-AF>
<2012-125X-AF>
8、期间聚合状态:
Creation Mode: Manual
Local:
Remote:
Local:
Remote:
设备状态:
1/4    NONE                Fault    0        NONE                 None
2/4    LSXM1SUP04H1        Master   0        S12504X-AF-2713      None
<2012-125X-AF>dis irf
MemberID  Slot  Role    Priority  CPU-Mac         Description
   1      5     Standby 32        00e0-fc0f-8c06  ---
  *2      4     Master  1         00e0-fc0f-8c1d  ---
  +2      5     Standby 1         00e0-fc0f-8c1e  ---
<2012-125X-AF>%Feb  1 06:13:49:169 2026 2012-125X-AF HA/5/HA_BATCHBACKUP_STARTED: -MDC=1; Batch backup of standby board in chassis 1 slot 4 started.
%Feb  1 06:13:50:171 2026 2012-125X-AF HA/5/HA_BATCHBACKUP_FINISHED: -MDC=1; Batch backup of standby board in chassis 1 slot 4 has finished.
%Feb  1 06:13:51:535 2026 2012-125X-AF PKG/5/PKG: -MDC=1; Switchover completed for the node of chassis 1 slot 4 in MDC Admin.
  dis dev
1/4    LSXM1SUP04H1        Standby  0        S12504X-AF-2710      None
---- More ----
<2012-125X-AF>       dis devdis issu state
ISSU state: Switchover
Work state: Normal
Upgraded chassis:
  chassis 2
<2012-125X-AF>
8、升级主框:
<2012-125X-AF>issu commit chassis 1
File flash:/S12500X-CMW710-BOOT-R2713.bin already exists on chassis 1 slot 5.
File flash:/S12500X-CMW710-SYSTEM-R2713.bin already exists on chassis 1 slot 5.
Overwrite the existing files? [Y/N]:y
Copying file flash:/S12500X-CMW710-BOOT-R2713.bin to chassis1#slot5#flash:/S12500X-CMW710-BOOT-R2713.bin..........................................Done.
Copying file flash:/S12500X-CMW710-SYSTEM-R2713.bin to chassis1#slot5#flash:/S12500X-CMW710-SYSTEM-R2713.bin...........................................................................................................................................................................................................................................................................................................Done.
Verifying the file flash:/S12500X-CMW710-BOOT-R2713.bin on chassis 1 slot 5...Done.
Verifying the file flash:/S12500X-CMW710-SYSTEM-R2713.bin on chassis 1 slot 5................Done.
  1         0                 Reboot
  1         3                 Reboot
  1         4                 Reboot
  1         5                 Reboot
  1         6                 Reboot
  1         7                 Reboot
  1         8                 Reboot
  1         9                 Reboot
  1         10                Reboot
  1         11                Reboot
  1         0                 Reboot
  1         3                 Reboot
  1         4                 Reboot
  1         5                 Reboot
  1         6                 Reboot
  1         7                 Reboot
  1         8                 Reboot
  1         9                 Reboot
  1         10                Reboot
  1         11                Reboot
Upgrading software images to compatible versions. Continue? [Y/N]:n
  1         0                 Reboot
  1         3                 Reboot
  1         4                 Reboot
  1         5                 Reboot
  1         6                 Reboot
  1         7                 Reboot
  1         8                 Reboot
  1         9                 Reboot
  1         10                Reboot
  1         11                Reboot
%Feb  1 06:24:30:862 2026 2012-125X-AF LAGG/6/LAGG_INACTIVE_PHYSTATE: -MDC=1; Member port XGE1/3/0/1 of aggregation group BAGG1 changed to the inactive state, because the physical state of the port is down.
<2012-125X-AF>%Feb  1 06:24:30:865 2026 2012-125X-AF LAGG/6/LAGG_INACTIVE_PHYSTATE: -MDC=1; Member port XGE1/3/0/12 of aggregation group BAGG2 changed to the inactive state, because the physical state of the port is down.
%Feb  1 06:24:30:903 2026 2012-125X-AF IFNET/5/LINK_UPDOWN: -MDC=1; Line protocol state on the interface Ten-GigabitEthernet1/3/0/1 changed to down.
%Feb  1 06:24:30:909 2026 2012-125X-AF IFNET/5/LINK_UPDOWN: -MDC=1; Line protocol state on the interface Ten-GigabitEthernet1/3/0/12 changed to down.
%Feb  1 06:24:30:917 2026 2012-125X-AF DEV/5/CHASSIS_REBOOT: -MDC=1; Chassis 1 is rebooting now.
%Feb  1 06:24:33:949 2026 2012-125X-AF IFNET/3/PHY_UPDOWN: -MDC=1; Physical state on the interface Ten-GigabitEthernet2/1/0/11 changed to down.
%Feb  1 06:24:33:950 2026 2012-125X-AF STM/3/STM_LINK_DOWN: -MDC=1; IRF port 1 went down.
%Feb  1 06:24:33:951 2026 2012-125X-AF IFNET/5/LINK_UPDOWN: -MDC=1; Line protocol state on the interface Ten-GigabitEthernet2/1/0/11 changed to down.
%Feb  1 06:24:34:027 2026 2012-125X-AF DEV/2/BOARD_STATE_FAULT: -MDC=1; Board state changed to Fault on chassis 1 slot 0, type is LSXM1TGS48HB1.
%Feb  1 06:24:34:052 2026 2012-125X-AF SHELL/5/SHELL_LOGOUT: -MDC=1; TTY logged out from aux1/1.
%Feb  1 06:24:34:073 2026 2012-125X-AF IFNET/3/PHY_UPDOWN: -MDC=1; Physical state on the interface Ten-GigabitEthernet1/3/0/1 changed to down.
%Feb  1 06:24:34:076 2026 2012-125X-AF IFNET/3/PHY_UPDOWN: -MDC=1; Physical state on the interface Ten-GigabitEthernet1/3/0/11 changed to down.
%Feb  1 06:24:34:077 2026 2012-125X-AF DEV/2/BOARD_STATE_FAULT: -MDC=1; Board state changed to Fault on chassis 1 slot 3, type is LSXM1TGS48HB1.
%Feb  1 06:24:34:078 2026 2012-125X-AF IFNET/3/PHY_UPDOWN: -MDC=1; Physical state on the interface Ten-GigabitEthernet1/3/0/12 changed to down.
%Feb  1 06:24:34:088 2026 2012-125X-AF DEV/2/BOARD_STATE_FAULT: -MDC=1; Board state changed to Fault on chassis 1 slot 4, type is LSXM1SUP04H1.
%Feb  1 06:24:34:094 2026 2012-125X-AF DEV/2/BOARD_STATE_FAULT: -MDC=1; Board state changed to Fault on chassis 1 slot 5, type is LSXM1SUP04H1.
%Feb  1 06:24:34:098 2026 2012-125X-AF DEV/2/BOARD_STATE_FAULT: -MDC=1; Board state changed to Fault on chassis 1 slot 6, type is LSXM1SFH04D1.
%Feb  1 06:24:34:103 2026 2012-125X-AF DEV/2/BOARD_STATE_FAULT: -MDC=1; Board state changed to Fault on chassis 1 slot 7, type is LSXM1SFH04D1.
%Feb  1 06:24:34:107 2026 2012-125X-AF DEV/2/BOARD_STATE_FAULT: -MDC=1; Board state changed to Fault on chassis 1 slot 8, type is LSXM1SFH04D1.
%Feb  1 06:24:34:112 2026 2012-125X-AF DEV/2/BOARD_STATE_FAULT: -MDC=1; Board state changed to Fault on chassis 1 slot 9, type is LSXM1SFH04D1.
%Feb  1 06:24:34:120 2026 2012-125X-AF DEV/2/BOARD_STATE_FAULT: -MDC=1; Board state changed to Fault on chassis 1 slot 10, type is LSXM1SFH04D1.
%Feb  1 06:24:34:133 2026 2012-125X-AF DEV/2/BOARD_STATE_FAULT: -MDC=1; Board state changed to Fault on chassis 1 slot 11, type is LSXM1SFH04D1.
%Feb  1 06:24:34:144 2026 2012-125X-AF DEV/3/BOARD_REMOVED: -MDC=1; Board was removed from chassis 1 slot 0, type is unknown.
%Feb  1 06:24:34:146 2026 2012-125X-AF DEV/3/BOARD_REMOVED: -MDC=1; Board was removed from chassis 1 slot 3, type is unknown.
%Feb  1 06:24:34:150 2026 2012-125X-AF DEV/3/BOARD_REMOVED: -MDC=1; Board was removed from chassis 1 slot 4, type is unknown.
%Feb  1 06:24:34:151 2026 2012-125X-AF DEV/3/BOARD_REMOVED: -MDC=1; Board was removed from chassis 1 slot 5, type is unknown.
%Feb  1 06:24:34:191 2026 2012-125X-AF DEV/3/BOARD_REMOVED: -MDC=1; Board was removed from chassis 1 slot 6, type is unknown.
%Feb  1 06:24:34:195 2026 2012-125X-AF DEV/3/BOARD_REMOVED: -MDC=1; Board was removed from chassis 1 slot 7, type is unknown.
%Feb  1 06:24:34:199 2026 2012-125X-AF DEV/3/BOARD_REMOVED: -MDC=1; Board was removed from chassis 1 slot 8, type is unknown.
%Feb  1 06:24:34:203 2026 2012-125X-AF DEV/3/BOARD_REMOVED: -MDC=1; Board was removed from chassis 1 slot 9, type is unknown.
%Feb  1 06:24:34:206 2026 2012-125X-AF DEV/3/BOARD_REMOVED: -MDC=1; Board was removed from chassis 1 slot 10, type is unknown.
%Feb  1 06:24:34:208 2026 2012-125X-AF DEV/3/BOARD_REMOVED: -MDC=1; Board was removed from chassis 1 slot 11, type is unknown.
%Feb  1 06:24:34:230 2026 2012-125X-AF LLDP/6/LLDP_CREATE_NEIGHBOR: -MDC=1-Chassis=2-Slot=5; Nearest bridge agent neighbor created on port M-GigabitEthernet1/0/0/2 (IfIndex 46275), neighbor's chassis ID is c4ca-d9b9-bb86, port ID is GigabitEthernet2/0/22.
<2012-125X-AF> dis issu state
ISSU state: Committing
Work state: Normal
Upgraded chassis:
  chassis 2
  chassis 1
聚合状态:
Local:
  XGE2/1/0/1(R)       S        32768    5        2                      {ACDEF}
Remote:
Local:
Remote:
Work state: Normal
Upgraded chassis:
  chassis 2
  chassis 1
<2012-125X-AF>%Feb  1 06:36:46:990 2026 2012-125X-AF PKG/5/PKG: -MDC=1; Upgrade completed for the node of chassis 1 slot 0 in MDC Admin.
<2012-125X-AF>%Feb  1 06:37:45:519 2026 2012-125X-AF SHELL/5/SHELL_LOGIN: -MDC=1; TTY logged in from aux1/1.
%Feb  1 06:37:47:792 2026 2012-125X-AF PKG/5/PKG: -MDC=1; Upgrade completed for the node of chassis 1 slot 5 in MDC Admin.
%Feb  1 06:37:48:509 2026 2012-125X-AF PKG/5/PKG: -MDC=1; Upgrade Completed.
10、至此完成升级,查看状态又变成init状态
ISSU state: Init
Work state: Normal
<2012-125X-AF>
<2012-125X-AF>
丢包情况:
这是ping的通过ospf路由转发的报文地址,200ms一个
<2091-S6860>ping -m 200 -c 10000000 192.2.2.2
Ping 192.2.2.2 (192.2.2.2): 56 data bytes, press CTRL_C to break
56 bytes from 192.2.2.2: icmp_seq=0 ttl=254 time=2.445 ms
56 bytes from 192.2.2.2: icmp_seq=1 ttl=254 time=2.247 ms
--- Ping statistics for 192.2.2.2 ---
15432 packet(s) transmitted, 15432 packet(s) received, 0.0% packet loss
round-trip min/avg/max/std-dev = 1.409/2.234/51.065/0.690 ms
这是ping的通过BGP路由转发的报文,200ms一个
<2091-S6860>ping -m 200 -c 10000000 20.1.1.1
56 bytes from 20.1.1.1: icmp_seq=3544 ttl=254 time=2.149 ms
56 bytes from 20.1.1.1: icmp_seq=3545 ttl=254 time=2.782 ms
56 bytes from 20.1.1.1: icmp_seq=3546 ttl=254 time=2.033 ms
56 bytes from 20.1.1.1: icmp_seq=3547 ttl=254 time=2.491 ms
56 bytes from 20.1.1.1: icmp_seq=3548 ttl=254 time=1.923 ms
--- Ping statistics for 20.1.1.1 ---
15266 packet(s) transmitted, 15266 packet(s) received, 0.0% packet loss
round-trip min/avg/max/std-dev = 1.443/2.285/29.172/0.561 ms
解决方法
ISSU操作比较复杂,需要严格按照操作步骤进行
