组网如图:
FW1与FW2建立IPSEC,内网口g1/0/0属于VPN test1,外网口g1/0/1属于VPN test。
刚兴趣流:10.1.1.2-------->10.1.2.2
MSR的主要配置:
interface GigabitEthernet0/0
port link-mode route
combo enable copper
ip route-static 0.0.0.0 0 10.1.1.1
FW1主要配置:
ip vpn-instance test
ip vpn-instance test1
interface GigabitEthernet1/0/0
combo enable copper
ip binding vpn-instance test1
combo enable copper
ip address 202.38.160.1 255.255.255.0
ipsec apply policy policy1
security-zone name Trust
import interface GigabitEthernet1/0/0
import interface GigabitEthernet1/0/1
security-policy ip
rule 0 name 0
action pass
vrf test
rule 1 name 1
action pass
vrf test1
ip route-static vpn-instance test1 10.1.2.0 24 vpn-instance test 202.38.160.2
acl advanced 3001
rule 15 permit ip vpn-instance test1 source 10.1.1.0 0.0.0.255 destination 10.1.2.0 0.0.0.255
ipsec transform-set tran1
esp encryption-algorithm des-cbc
esp authentication-algorithm sha1
ipsec policy policy1 1 isakmp
transform-set tran1
security acl 3001
remote-address 202.38.160.2
ike-profile profile1
ike profile profile1
keychain kechain
local-identity address 202.38.160.1
match remote identity address 202.38.160.2 255.255.255.255 vpn-instance test
proposal 1
inside-vpn vpn-instance test1
ike proposal 1
ike keychain kechain vpn-instance test
pre-shared-key address 202.38.160.2 255.255.255.255 key simple 123456
FW2主要配置:
interface LoopBack0
ip address 10.1.2.2 255.255.255.255
combo enable copper
ip address 202.38.160.2 255.255.255.0
ip route-static 10.1.1.0 24 202.38.160.1
acl advanced 3001
rule 0 permit ip source 10.1.2.0 0.0.0.255 destination 10.1.1.0 0.0.0.255
transform-set tran1
security acl 3001
remote-address 202.38.160.1
keychain keychain1
local-identity address 202.38.160.2
match remote identity address 202.38.160.1 255.255.255.255
proposal 1
ike proposal 1
ike keychain keychain1
pre-shared-key address 202.38.160.1 255.255.255.255 key simple 123456
security-policy ip
rule 0 name 0
action pass
配置完成后,MSR1可以ping通FW2的loopback地址10.1.2.2
[H3C]ping 10.1.2.2
Ping 10.1.2.2 (10.1.2.2): 56 data bytes, press CTRL+C to break
Request time out
56 bytes from 10.1.2.2: icmp_seq=1 ttl=254 time=1.000 ms
56 bytes from 10.1.2.2: icmp_seq=2 ttl=254 time=1.000 ms
56 bytes from 10.1.2.2: icmp_seq=3 ttl=254 time=0.000 ms
56 bytes from 10.1.2.2: icmp_seq=4 ttl=254 time=1.000 ms
FW1上可以看到IKE SA与IPSEC SA
<H3C>dis ike sa verbose
Connection ID: 1
Outside VPN: test
Inside VPN: test1
Profile: profile1
Transmitting entity: Initiator
Initiator COOKIE: 80164735071382aa
Responder COOKIE: bb3c629bb0cdb70a
Local IP: 202.38.160.1
Local ID type: IPV4_ADDR
Local ID: 202.38.160.1
Remote IP: 202.38.160.2
Remote ID type: IPV4_ADDR
Remote ID: 202.38.160.2
Authentication-method: PRE-SHARED-KEY
Authentication-algorithm: SHA1
Encryption-algorithm: DES-CBC
Life duration(sec): 86400
Remaining key duration(sec): 86341
Exchange-mode: Main
Diffie-Hellman group: Group 1
NAT traversal: Not detected
Extend authentication: Disabled
Assigned IP address:
Vendor ID index:0xffffffff
Vendor ID sequence number:0x0
<H3C> dis
<H3C>display ips
<H3C>display ipsec sa
IPsec policy: policy1
Sequence number: 1
Mode: ISAKMP
Tunnel id: 0
Encapsulation mode: tunnel
Perfect Forward Secrecy:
Inside VPN: test1
Extended Sequence Numbers enable: N
Traffic Flow Confidentiality enable: N
Path MTU: 1444
Tunnel:
local address: 202.38.160.1
remote address: 202.38.160.2
Flow:
sour addr: 10.1.1.0/255.255.255.0 port: 0 protocol: ip
dest addr: 10.1.2.0/255.255.255.0 port: 0 protocol: ip
[Inbound ESP SAs]
SPI: 3264279281 (0xc290f2f1)
Connection ID: 4294967296
Transform set: ESP-ENCRYPT-DES-CBC ESP-AUTH-SHA1
SA duration (kilobytes/sec): 1843200/3600
SA remaining duration (kilobytes/sec): 1843199/3538
Max received sequence-number: 4
Anti-replay check enable: Y
Anti-replay window size: 64
UDP encapsulation used for NAT traversal: N
Status: Active
[Outbound ESP SAs]
SPI: 45649012 (0x02b88c74)
Connection ID: 4294967297
Max sent sequence-number: 4
Status: Active
配置关键点:
FW1配置关键点:
配置注意关键点:
1.安全策略中加VRF
2.要有路由
3.ike keychain要带VPN实例(公网侧VPNtest)
4.ike profile中要带VPN实例(remote为公网侧test,inside为内网侧test1)
