Print
知
H3C Comware V7 平台交换机链路聚合 + BFD 部署配置案例
组网及说明
如下图拓扑所示:
SW1 与 SW2 交换机采用静态链路聚合模式部署。
为避免由于链路感知延迟(如长距离链路,或链路中存在有源传输设备),导致可能出现的“黑洞”现象(一端链路接口UP,另一端链路接口Down),增加BFD功能。实现链路聚合快速毫秒级感知链路状态。
配置步骤
<SW1>
interface Bridge-Aggregation1
 link-aggregation bfd ipv4 source 1.1.1.1 destination 2.2.2.2
 bfd authentication-mode simple 1 plain 123 //可选,配置密钥123
 port link-mode bridge
 link-aggregation port-priority 4096
 port link-aggregation group 1
<SW2>
 link-aggregation bfd ipv4 source 2.2.2.2 destination 1.1.1.1
配置关键点
当链路正常情况下:
<SW1> display link-aggregation verbose
Aggregation Mode: Static
Loadsharing Type: Shar
Management VLANs: None
  Port             Status      Priority  Oper-Key
  XGE1/0/1(R)      S       4096     1
  XGE1/0/3           S       32768   1
<SW1> display bfd session
 Total Session Num: 2     Up Session Num: 2     Init Mode: Active
 LD/RD          SourceAddr      DestAddr        State    Holdtime    Interface
 257/257        1.1.1.1         2.2.2.2         Up       1983ms      XGE1/0/1
 258/258        1.1.1.1         2.2.2.2         Up       1703ms      XGE1/0/3
<SW2>display link-aggregation verbose
  XGE1/0/1(R)      S       32768    1
  XGE1/0/3           S       32768    1
<SW2>display bfd session
 257/257        2.2.2.2         1.1.1.1         Up       2000ms      XGE1/0/1
 258/258        2.2.2.2         1.1.1.1         Up       1966ms      XGE1/0/3
若SW2本地XG1/0/1接口down后,及链路故障时:
<SW1>
%Jan 28 03:34:10:784 1980 sw1 BFD/5/BFD_CHANGE_FSM: Sess[1.1.1.1/2.2.2.2, LD/RD:259/259, Interface:XGE1/0/1, SessType:Ctrl, LinkType:INET], Ver:1, Sta: UP->DOWN, Diag: 1 (Control Detection Time Expired)   //SW1的bfd会话快速感知到会话down
*Jan 28 03:34:10:785 1980 sw1 LAGG/7/Event: Group 1 updated because of member port BFD session up/down.
*Jan 28 03:34:10:830 1980 sw1 LAGG/7/Event: Group 1 updated because of other reason.
%Jan 28 03:34:10:838 1980 sw1 LAGG/6/LAGG_INACTIVE_BFD: Member port XGE1/0/1 of aggregation group BAGG1 changed to the inactive state, because the BFD session state of the port is down.  //BFD模块通知链路聚合模块相关接口出现“异常”,需要将SW1本地对应链路接口置为Unselected状态。
%Jan 28 03:34:10:843 1980 sw1 IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet1/0/1 changed to down.    //SW1本地XG1/0/1接口逻辑链路层快速被down掉。
<SW1>display link-aggregation verbose
  XGE1/0/1         U          4096     1
  XGE1/0/3(R)    S          32768    1
<sw1>display bfd session
 258/258        1.1.1.1         2.2.2.2         Up       1737ms      XGE1/0/3
<SW2>display bfd sesion
 258/258        2.2.2.2         1.1.1.1         Up       1899ms      XGE1/0/3
