暂无
暂无
现场在int valn 口下下发包过滤,测试发现未生效
interface Vlan-interface1400
description JRJG
ip address 40.108.1.252 255.255.255.0
vrrp vrid 140 virtual-ip 40.108.1.254 vrrp vrid 140 priority 120 vrrp vrid 140 track 1 priority reduced 40
packet-filter name JRJG inbound
排查发现底层包过滤都有正常下发:
acl advanced name JRJG
rule 0 permit icmp counting
rule 5 permit ip destination 224.0.0.0 0.0.0.255 counting
rule 10 permit ip destination 21.244.0.0 0.0.255.255 counting
rule 15 permit ip destination 21.4.0.0 0.3.255.255 counting
rule 20 permit ip destination 26.0.0.0 0.255.255.255 counting
rule 25 permit ip destination 25.0.0.0 0.255.255.255 counting
rule 30 permit ip destination 10.2.0.0 0.0.255.255 counting
rule 35 permit ip destination 10.8.0.0 0.0.255.255 counting
rule 40 permit ip destination 10.3.0.0 0.0.255.255 counting
rule 45 permit ip destination 10.9.0.0 0.0.255.255 counting
rule 50 permit ip destination 21.108.127.0 0.0.0.255 counting
rule 5000 deny ip counting
Acl-Type PktFilter IP on VRF, Stage IPCL 0, OuterPort, Installed, Active
Prio Mjr/Sub 0x202/0x11, RuleFormat INGRESS_EXT_NOT_IPV6, Vtcame/Idx 4/930,
ACL GroupNo : 637534213, RuleID : 0 这里的acl ruleID依次和上面的对应,也都对的上
Rule Match --------
Global range
Outer Vlan: 0x578, 0xfff
IP protocol: icmp
IP Type: Any IPv4 packet
Account or Logging
Mac to me: 1
Actions --------
Account mode packets, green and non-green
Permit
Accounting: Hi 0, Lo 0
Prio Mjr/Sub 0x202/0x11, RuleFormat INGRESS_EXT_NOT_IPV6, Vtcame/Idx 4/931,
ACL GroupNo : 637534213, RuleID : 5
Rule Match --------
Global range
Dest IP: 224.0.0.0, 255.255.255.0
Account or Logging
Mac to me: 1
Actions --------
Permit
Prio Mjr/Sub 0x202/0x11, RuleFormat INGRESS_EXT_NOT_IPV6, Vtcame/Idx 4/932,
ACL GroupNo : 637534213, RuleID : 10
Rule Match --------
Global range
Dest IP: 21.244.0.0, 255.255.0.0
Account or Logging
Mac to me: 1
Actions --------
Permit
继续排查流量进来的物理口,发现物理口也有下发包过滤:
interface GigabitEthernet1/0/28
port link-mode bridge
description to_HF-CB-17F-S1_XGE1/0/49
port link-type trunk
undo port trunk permit vlan 1
port trunk permit vlan 2 to 4094
packet-filter name deny-CO_To_CB inbound // 物理端口也有下发,而且对应的acl,最后一条配置为permit ip 放通所有,而 物理口下的包过滤优先级高于int vlan 口,所以int vlan 口下的包过滤无法生效
mirroring-group 1 mirroring-port both
acl advanced name deny-CO_To_CB
description deny-CO_To_CB
rule 5 deny ip source 22.0.0.0 0.255.255.255 destination 21.0.0.0 0.255.255.255
rule 10 deny ip source 28.0.0.0 0.255.255.255 destination 21.0.0.0 0.255.255.255
rule 15 deny ip source 29.0.0.0 0.255.255.255 destination 21.0.0.0 0.255.255.255
rule 20 deny ip source 24.0.0.0 0.255.255.255 destination 21.0.0.0 0.255.255.255
rule 45 deny ip source 21.0.0.0 0.255.255.255 destination 22.0.0.0 0.255.255.255
rule 50 deny ip source 21.0.0.0 0.255.255.255 destination 28.0.0.0 0.255.255.255
rule 55 deny ip source 21.0.0.0 0.255.255.255 destination 29.0.0.0 0.255.255.255
rule 60 deny ip source 21.0.0.0 0.255.255.255 destination 24.0.0.0 0.255.255.255
rule 70 permit ip source 28.0.0.0 0.255.255.255 destination 22.5.0.0 0.0.255.255
rule 71 permit ip source 22.5.0.0 0.0.255.255 destination 28.0.0.0 0.255.255.255
rule 72 permit ip source 28.0.0.0 0.255.255.255 destination 22.4.1.161 0
rule 73 permit ip source 28.0.0.0 0.255.255.255 destination 25.64.0.33 0
rule 74 permit ip source 22.4.1.161 0 destination 28.0.0.0 0.255.255.255
rule 75 permit ip source 25.64.0.33 0 destination 28.0.0.0 0.255.255.255
rule 76 permit ip source 28.0.0.0 0.255.255.255 destination 22.108.1.3 0
rule 77 permit ip source 22.108.1.3 0 destination 28.0.0.0 0.255.255.255
rule 78 permit ip source 28.0.0.0 0.255.255.255 destination 22.108.1.4 0
rule 79 permit ip source 22.108.1.4 0 destination 28.0.0.0 0.255.255.255
rule 80 permit ip source 28.0.0.0 0.255.255.255 destination 22.4.52.20 0
rule 81 permit ip source 22.4.52.20 0 destination 28.0.0.0 0.255.255.255
rule 85 permit ip source 28.0.0.0 0.252.255.255 destination 22.4.102.42 0
rule 86 permit ip source 22.108.130.35 0 destination 28.4.0.7 0
rule 87 permit ip source 28.4.0.7 0 destination 22.108.130.35 0
rule 150 deny ip source 22.0.0.0 0.255.255.255 destination 28.0.0.0 0.255.255.255
rule 151 deny ip source 28.0.0.0 0.255.255.255 destination 22.0.0.0 0.255.255.255
rule 200 permit ip
调整物理接口下的包过滤后,测试正常生效
