组网如下:
FW作为日志源,将安全策略日志以快速日志的方式发送到日志服务器,并且要保证发送日志被加密
主要配置如下:
FW1日志源主要配置
路由配置:
ip route-static 0.0.0.0 0 202.0.0.2
ip route-static 2.2.2.0 24 Tunnel0
快速日志配置:
customlog format packet-filter
customlog host 2.2.2.1 export packet-filter
customlog host source LoopBack10
接口配置:
interface LoopBack0
ip address 11.11.11.11 255.255.255.255
interface LoopBack10
ip address 1.1.1.1 255.255.255.255
port link-mode route
combo enable copper
ip address 202.0.0.1 255.255.255.0
ipsec apply policy vpn
安全域与安全策略配置
security-zone name Trust
import interface GigabitEthernet1/0/1
import interface Tunnel0
security-policy ip(日志记录功能要打开)
rule 0 name 0
action pass
logging enable
GRE主要配置
一定不要配置探测
interface Tunnel0 mode gre
ip address 10.0.0.1 255.255.255.252
source LoopBack0
destination 22.22.22.22
gre key 123
IPSSEC主要配置
acl advanced 3000
rule 0 permit gre source 11.11.11.11 0 destination 22.22.22.22 0
ipsec transform-set tran1
esp encryption-algorithm aes-cbc-256
esp authentication-algorithm sha1
ipsec policy vpn 1 isakmp
transform-set tran1
security acl 3000
remote-address 202.0.0.2
ike-profile profile1
ike identity fqdn vpn1
ike profile profile1
keychain keychain1
local-identity address 202.0.0.1
match remote identity address 202.0.0.2 255.255.255.0
proposal 1
ike proposal 1
dh group2
ike keychain keychain1
pre-shared-key address 202.0.0.2 255.255.255.255 key simple 123
FW2主要配置如下:
路由配置:
ip route-static 0.0.0.0 0 202.0.0.1
ip route-static 1.1.1.0 24 Tunnel0
接口配置:
interface LoopBack0
ip address 22.22.22.22 255.255.255.255
interface GigabitEthernet1/0/0
combo enable copper
ip address 2.2.2.2 255.255.255.0
combo enable copper
ip address 202.0.0.2 255.255.255.0
安全域与安全策略配置
import interface GigabitEthernet1/0/0
security-policy ip
rule 0 name 0
action pass
GRE主要配置
一定不要配置探测
ip address 10.0.0.2 255.255.255.252
source LoopBack0
destination 11.11.11.11
gre key 123
IPSSEC主要配置
acl advanced 3000
rule 0 permit gre source 22.22.22.22 0 destination 11.11.11.11 0
transform-set tran1
security acl 3000
remote-address 202.0.0.1
ike identity fqdn vpn2
keychain keychain1
local-identity address 202.0.0.2
match remote identity address 202.0.0.1 255.255.255.0
proposal 1
ike proposal 1
dh group2
pre-shared-key address 202.0.0.1 255.255.255.255 key simple 123
日志服务器配置:
ip route-static 1.1.1.0 24 2.2.2.2
interface GigabitEthernet0/0
combo enable copper
ip address 2.2.2.1 255.255.255.0
配置完成之后测试结果如下:
FW1上以1.1.1.1为源地址ping2.2.2.1,可以看到FW1上IKE SA与IPSEC SA均已建立
[FW1]ping -a 1.1.1.1 2.2.2.1
Ping 2.2.2.1 (2.2.2.1) from 1.1.1.1: 56 data bytes, press CTRL+C to break
56 bytes from 2.2.2.1: icmp_seq=0 ttl=254 time=2.000 ms
56 bytes from 2.2.2.1: icmp_seq=1 ttl=254 time=1.000 ms
56 bytes from 2.2.2.1: icmp_seq=2 ttl=254 time=1.000 ms
56 bytes from 2.2.2.1: icmp_seq=3 ttl=254 time=3.000 ms
56 bytes from 2.2.2.1: icmp_seq=4 ttl=254 time=1.000 ms
--- Ping statistics for 2.2.2.1 ---
round-trip min/avg/max/std-dev = 1.000/1.600/3.000/0.800 ms
[FW1]
[FW1]
[FW1]%Jul 16 14:20:41:836 2022 FW1 PING/6/PING_STATISTICS: -COntext=1; Ping statistics for 2.2.2.1: 5 packet(s) transmitted, 5 packet(s) received, 0.0% packet loss, round-trip min/avg/max/std-dev = 1.000/1.600/3.000/0.800 ms.
dis ike sa
Connection-ID Remote Flag DOI
1 202.0.0.2/500 RD IPsec
Flags:
RD--READY RL--REPLACED FD-FADING RK-REKEY
[FW1]dis
[FW1]display ips
[FW1]display ipsec sa
IPsec policy: vpn
Sequence number: 1
Mode: ISAKMP
Tunnel id: 0
Encapsulation mode: tunnel
Perfect Forward Secrecy:
Inside VPN:
Extended Sequence Numbers enable: N
Traffic Flow Confidentiality enable: N
Transmitting entity: Initiator
Path MTU: 1428
Tunnel:
local address: 202.0.0.1
remote address: 202.0.0.2
Flow:
sour addr: 11.11.11.11/255.255.255.255 port: 0 protocol: gre
dest addr: 22.22.22.22/255.255.255.255 port: 0 protocol: gre
[Inbound ESP SAs]
SPI: 1902679672 (0x71689678)
Connection ID: 4294967296
Transform set: ESP-ENCRYPT-AES-CBC-256 ESP-AUTH-SHA1
SA duration (kilobytes/sec): 1843200/3600
SA remaining duration (kilobytes/sec): 1843195/1989
Max received sequence-number: 34
Anti-replay check enable: Y
Anti-replay window size: 64
UDP encapsulation used for NAT traversal: N
Status: Active
[Outbound ESP SAs]
SPI: 4170074684 (0xf88e4a3c)
Connection ID: 4294967297
SA remaining duration (kilobytes/sec): 1843190/1989
Max sent sequence-number: 47
Status: Active
在日志服务器上抓包,可以看到FW1产生的syslog日志向
配置关键点:
1.
2.
3.
4.
