Print
S6800 DRNI场景下配置镜像导致IPL链路震荡的案例
2022-09-27 发表
问题描述
两台S6800设备做DRNI,分别做了镜像的配置后出现了IPP链路震荡,引发备设备被MAD DOWN
%@47308%May 26 22:16:11:468 2022 SW2 LAGG/6/LAGG_INACTIVE_PARTNER: Member port FGE1/0/53 of aggregation group BAGG10 changed to the inactive state, because the aggregation configuration of its peer port is incorrect.
%@47309%May 26 22:16:11:475 2022 SW2 IFNET/5/LINK_UPDOWN: Line protocol state on the interface FortyGigE1/0/53 changed to down.
%@47310%May 26 22:16:11:537 2022 SW2 LAGG/6/LAGG_ACTIVE: Member port FGE1/0/53 of aggregation group BAGG10 changed to the active state.
%@47311%May 26 22:16:11:552 2022 SW2 IFNET/5/LINK_UPDOWN: Line protocol state on the interface FortyGigE1/0/53 changed to up.
%@47312%May 26 22:16:11:633 2022SW2 LAGG/6/LAGG_INACTIVE_PARTNER: Member port FGE1/0/54 of aggregation group BAGG10 changed to the inactive state, because the aggregation configuration of its peer port is incorrect.
过程分析
1、检查配置发现两台设备配置的镜像目的口都是BAGG200,这个口配置为了DR口。
interface Bridge-Aggregation200
port drni group 200
undo stp enable
mirroring-group 1 monitor-port
2、而镜像源端口为其他动态聚合DR的成员口,这种场景下,镜像流量会包括源端口的LACP报文。
3、由于SW1设备的BAGG200本地成员口是down的,所以镜像流量会经过IPL发给SW2,IPL会收到其他接口的LACP报文,引发震荡。
解决方法
对于镜像来说,不允许源和目的口都是动态聚合,否则会导致LACP报文影响目的端口。
而在DRNI场景下,目的口不能为DR口,否则也会出现镜像流量跨IPL的情况,引起DR系统震荡。
