Print
某局点S10508-V 查看配置文件为空问题处理经验案例
4天前 发表
组网及说明
组网不涉及
问题描述
查看当前配置文件显示为空
过程分析
以往案例:https://zhiliao.h3c.com/Theme/details/124253
设备未进行主备倒换:
  ===============display irf===============
MemberID  Slot  Role    Priority  CPU-Mac         Description
*+1      4     Master  10        00e0-fc0f-8c05  ---
   1      5     Standby 10        00e0-fc0f-8c06  ---
   2      4     Standby 1         00e0-fc0f-8c17  ---
   2      5     Standby 1         00e0-fc0f-8c18  ---
保存过程无报错:
WUH-NZ-HX-S10508-ST-01 SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=X.X.X.X-User=wuhadmin; Command is save startup.cfg all
WUH-NZ-HX-S10508-ST-01 SHELL/6/SHELL_CMD_CONFIRM: Confirm option of command save startup.cfg all is yes.
WUH-NZ-HX-S10508-ST-01 SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=X.X.X.X-User=wuhadmin; Command is display startup
WUH-NZ-HX-S10508-ST-01 SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=X.X.X.X-User=wuhadmin; Command is save startup.cfg chassis 1 slot 4
WUH-NZ-HX-S10508-ST-01 SHELL/6/SHELL_CMD_CONFIRM: Confirm option of command save startup.cfg chassis 1 slot 4 is yes.
解决方法
设备空配置启动的情况下是正常现象
Current Startup saved-configuration file
当前启动使用的配置文件
若该字段后有“*”标识,则表示当前的启动配置文件为二进制类型
Next main startup saved-configuration file
下一次启动时使用的主用配置文件
Next backup startup saved-configuration file
下一次启动时使用的备用配置文件
验证:
[H3C]display startup
MainBoard:
Current startup saved-configuration file: NULL
Next main startup saved-configuration file: NULL
Next backup startup saved-configuration file: NULL
[H3C]qu
<H3C>save force
<H3C>sys
MainBoard:
Next main startup saved-configuration file: flash:/startup.cfg
[H3C]qu
<H3C>reboot
Now rebooting, please wait....%May 31 10:05:03:222 2023 H3C DEV/5/SYSTEM_REBOOT: System is rebooting now.
..Cryptographic algorithms tests passed.
Line con0 is available.
Press ENTER to get started.
* Copyright (c) 2004-2022 New H3C Technologies Co., Ltd. All rights reserved.*
<H3C>%May 31 10:05:50:936 2023 H3C SHELL/5/SHELL_LOGIN: Console logged in from con0.
sys
MainBoard:
Current startup saved-configuration file: flash:/startup.cfg(*)
