Print
某局点S10508X-G包过滤下发失败问题处理经验案例
2023-09-26 发表
组网及说明
组网不涉及
问题描述
包过滤下发失败,提示资源不足:
%Sep  1 16:10:41:006 2023 User-S10508X SHELL/6/SHELL_CMD: -Line=vty3-IPAddr=172.X.X.X-User=admin; Command is packet-filter 3042 inbound
%Sep  1 16:10:41:950 2023 User-S10508X PFILTER/3/PFILTER_IF_IPV4_DACT_NO_RES: -Chassis=2-Slot=6; Failed to apply or refresh the IPv4 default action to the inbound direction of interface Vlan-interface42. The resources are insufficient.
%Sep  1 16:10:42:113 2023 User-S10508X PFILTER/3/PFILTER_IF_IPV4_DACT_NO_RES: -Chassis=1-Slot=6; Failed to apply or refresh the IPv4 default action to the inbound direction of interface Vlan-interface42. The resources are insufficient.
过程分析
查看当前资源使用情况:
[User-S10508X-Vlan-interface42]dis qos-acl resource
Interfaces: GE1/6/0/1 to GE1/6/0/48, XGE1/6/0/49 to XGE1/6/0/52 (chassis 1 slot 6)
Type             Total      Reserved   Configured Remaining  Usage
IGS ACL          8192       1536       2844       3812       53%
EGS ACL          1536       0          4          1532       0%
IGS Counter      4096       768        1296       2032       50%
EGS Counter      768        0          0          768        0%
IGS Meter        8191       100        4          8087       1%
EGS Meter        2047       0          0          2047       0%
IMeter Counter   3327       300        12         3015       9%
EMeter Counter   3839       0          0          3839       0%
Interfaces: GE2/6/0/1 to GE2/6/0/48, XGE2/6/0/49 to XGE2/6/0/52 (chassis 2 slot 6)
查看板卡信息,报错的两个slot 6槽位板卡型号都是LSEM1GT48TSSD0:
  ===============display device verbose===============
Slot   Type                  State    Subslot  Soft Ver            Patch Ver
1/6    LSEM1GT48TSSD0        Normal   0        S10500XG-7753P07    None
2/6    LSEM1GT48TSSD0        Normal   0        S10500XG-7753P07    None
LSEM1GT48TSSD0单板IACL(入方向acl资源)有 8block(编号0-7);前四个可以各下发1536ACL,后四条可以各下发256ACL
0127都已使用;456被合并到3中被PFT L3使用
 ====display hardware internal qacl show acl-resc chassis 1 slot 6 chip 0====
---------------Qacl Group UsedResc Info---------------
Acl Hw Block: IACL 0
  GroupType: SYSTEM
    acl type                   usedEntries
    [ 19]RX IPv4 High                1
    [ 21]RX IPv4 Middle High         1
    [ 23]RX IPv4 Middle              2
    [ 25]RX Low                      7
Acl Hw Block: IACL 1
  GroupType: DP PKT
    [240]DROP GROUP BFD INTF         1
Acl Hw Block: IACL 2
 GroupType: EXCP
    [267]EXCP HIGH                   1
    [273]OSPF TO CPU                 3
Acl Hw Block: IACL 3
 GroupType: PFT L3
    [ 79]PktFilter IP on VRF         1411
Acl Hw Block: IACL 7
  GroupType: MQC
    [  0]MQC Vlan                    2
|  IACL 3  |Entry           3072        0           2822        250         |
|          |Entry640        0           0           0           0           |
|          |Block Counter   1536        0           1295        241         |
包过滤缺省动作被配置为deny,会下发default action;而LSEM1GT48TSSD0单板芯片支持微分段,需要将微分段的包过滤拆分到新的Group
packet-filter default deny
由于0127都已使用;456被合并到3中被PFT L3使用,因此没有多余的BLOCK下发微分段default action;导致提示资源不足
解决方法
修改packet-filter default的缺省动作为permit方式,并在acl中配置rule xx deny ip来替代packet-filter default deny
