Print
HPE服务器VMware系统定制镜像获取方法
1天前 发表
组网及说明
使用须知:
1、由于VMwareBroadcom收购,目前VMware镜像无法在HPE官网提供的链接直接下载。需要跳转至Broadcom下载。HPE官网VMware下载页展示如下公告:
Please be advised effective Monday May 6th, 2024 the VMware Customer Connect site will be replaced by the Broadcom Support Portal. Due to the existing architecture of the Broadcom Support Portal, there are no direct links possible to any specific Custom Image or Addon and the HPE direct links on this page will no longer be functional. The steps for viewing and downloading the Custom Images and Addons will change since it is a different portal. Broadcom has issued a new knowledge base article with specific steps to find and download Custom Images and Addons.
2、本文档为便利客户下载镜像使用,仅展示Broadcom账号注册以及下载HPE VMware镜像过程,如遇注册账号异常、下载镜像异常、Broadcom官网其他操作指引请联系Broadcom获取支持。
3、下载镜像前请查询主机系统兼容性:HPE服务器系统兼容性查询方法 - 知了社区 (h3c.com)
配置步骤
账号注册及镜像下载指引
1. Broadcom账户注册:
1)首先登录到博通Support网站,链接:Home - Support Portal - Broadcom support portal
点击 “Register
2)输入需要注册得邮箱并填写验证码,验证成功后点击“Next”
3)点击“Next”之后查看注册邮箱,会收到一个验证码
4)输入邮件里的验证码,点击“Verify&Continue
5)完善注册基本信息填写。然后接受使用条款并点击“Create Account
6)此位置可以选择“I’ll do it later,账号注册成功后返回主页登录即可
注:邮箱注册账号过程中,如果邮箱不符合要求会有如下提示,可以更换邮箱或者联系Broadcom支持
The domain 163.com has been flagged as a blacklisted domain. If you wish to continue to register, please use another domain. If this domain is wrongly blacklisted, please approach your Broadcom contact helpdesk.
2.HPE VMware镜像下载
1VMware镜像下载路径:
https://support.broadcom.com/group/ecx/productfiles?subFamily=VMware%20vSphere&displayGroup=VMware%20vSphere%20-%20Enterprise&release=8.0&os=&servicePk=202627&language=EN
2)主页点击SoftwareàVMware Cloud FoundationàMy Downloads
3)进入My Downloads页面后查找VMware vSphere
4)选择需要的版本vSphere-Enterprise进行下载。
5)选择需要的Customer ISOs进行下载(检索HPE即可)
补充:
1)、按照SynergyProLiant(见下图举例)等机器类别会有对应得镜像区分,按需下载。Synergy机器需要下载有Synergy标记的ISOProLiant正常下载无特殊标记的镜像即可。
2)由于HPE VMware镜像从Gen9代存在区分,镜像命名含Gen9标记的ISO举例:
Gen9plus: Gen9 Servers and forward(表示此镜像属于Gen9Gen9之后的机器使用)
PreGen9: Last Pre-Gen9(表示此镜像属于Gen9之前的机器使用)
注:高版本镜像例如ESXi 8.0不再显示Gen9plus等标记,直接下载无特殊标注镜像即可。
