Print
知
HCL模拟MSR V7平台路由器GRE over IPSec VPN多分支互通
2024-08-22 发表
组网及说明
1.组网拓扑
2.需求描述:
实现两个分部内网终端能够通过GRE over IPSec VPN隧道访问到总部,也能通过总部实现两个分部的内网终端互通。
分部与总部终端用loopback接口替代,ip地址固定。
3.配置思路:
配置各个端口ip地址与静态路由,配置GRE隧道与IPSec VPN相关命令实现流量的GRE封装,并通过IPSec隧道进行保护传输至目的地。
配置步骤
1.RT1
1.1ACL列表:
Advanced IPv4 ACL 3001, 2 rules,
ACL's step is 5
 rule 0 permit ip source 1.1.1.0 0.0.0.255 destination 2.2.2.0 0.0.0.255
 rule 1 permit ip source 1.1.1.0 0.0.0.255 destination 3.3.3.0 0.0.0.255
Advanced IPv4 ACL 3002, 3 rules,
ACL's step is 5
 rule 0 deny ip source 1.1.1.0 0.0.0.255 destination 2.2.2.0 0.0.0.255
 rule 1 deny ip source 1.1.1.0 0.0.0.255 destination 3.3.3.0 0.0.0.255
 rule 2 permit ip
1.2 关键配置:
interface Tunnel0 mode gre
 ip address 10.0.0.1 255.255.255.0
 source 1.1.1.1
 destination 2.2.2.2
ipsec transform-set 1
 esp encryption-algorithm 3des-cbc
 esp authentication-algorithm md5
ipsec policy RT1 1 isakmp
 transform-set 1
 security acl 3001
 remote-address 2.2.2.2
 ike-profile RT1
ike profile RT1
 keychain RT1
 local-identity address 1.1.1.1
 match remote identity address 2.2.2.2 255.255.255.0
 proposal 1
ike proposal 1
ike keychain RT1
 pre-shared-key address 2.2.2.2 255.255.255.0 key cipher $c$3$SyBhccDEm/kTkb3J7k6o2PZq10DEypOVEg==
interface LoopBack0
 ip address 192.168.1.10 255.255.255.0
interface GigabitEthernet0/0
 port link-mode route
 combo enable copper
 ip address 1.1.1.1 255.255.255.0
 nat outbound 3002
 ipsec apply policy RT1
 ip route-static 0.0.0.0 0 1.1.1.254
 ip route-static 192.168.2.0 24 Tunnel0
 ip route-static 192.168.3.0 24 Tunnel0
2.RT2
2.1ACL列表
ACL's step is 5
 rule 0 permit ip source 2.2.2.0 0.0.0.255 destination 1.1.1.0 0.0.0.255
 rule 1 permit ip source 3.3.3.0 0.0.0.255 destination 1.1.1.0 0.0.0.255
Advanced IPv4 ACL 3002, 2 rules,
ACL's step is 5
 rule 0 permit ip source 2.2.2.0 0.0.0.255 destination 3.3.3.0 0.0.0.255
Advanced IPv4 ACL 3003, 5 rules,
ACL's step is 5
 rule 0 deny ip source 2.2.2.0 0.0.0.255 destination 1.1.1.0 0.0.0.255
 rule 1 deny ip source 2.2.2.0 0.0.0.255 destination 3.3.3.0 0.0.0.255
 rule 2 deny ip source 1.1.1.0 0.0.0.255 destination 3.3.3.0 0.0.0.255
 rule 5 deny ip source 3.3.3.0 0.0.0.255 destination 1.1.1.0 0.0.0.255
 rule 6 permit ip
2.2关键配置:
 ip address 10.0.0.2 255.255.255.0
 source 2.2.2.2
 destination 1.1.1.1
interface Tunnel1 mode gre
 ip address 20.0.0.2 255.255.255.0
 source 2.2.2.2
 destination 3.3.3.3
ipsec policy RT2 1 isakmp
 transform-set 1
 security acl 3001
 remote-address 1.1.1.1
 ike-profile RT2-RT1
ipsec policy RT2 2 isakmp
 transform-set 1
 security acl 3002
 remote-address 3.3.3.3
 ike-profile RT2-RT3
ike profile RT2-RT1
 keychain RT2-RT1
 local-identity address 2.2.2.2
 match remote identity address 1.1.1.1 255.255.255.0
 proposal 1
ike profile RT2-RT3
 keychain RT2-RT3
 match remote identity address 3.3.3.3 255.255.255.0
 proposal 1
ike proposal 1
ike keychain RT2-RT1
 pre-shared-key address 1.1.1.1 255.255.255.0 key cipher $c$3$w74T8OIbosspb4Evy/1aSu3S+fb5SUJjeA==
ike keychain RT2-RT3
 pre-shared-key address 3.3.3.3 255.255.255.0 key cipher $c$3$YDfVYtM49YVzXjOKCn8NQFd8yN/D+Xpq2zzLZw==
interface LoopBack0
 ip address 192.168.2.10 255.255.255.0
 combo enable copper
 ip address 2.2.2.2 255.255.255.0
 nat outbound 3003
 ipsec apply policy RT2
 ip route-static 0.0.0.0 0 2.2.2.254
 ip route-static 192.168.1.0 24 Tunnel0
 ip route-static 192.168.3.0 24 Tunnel1
3.RT3
3.1ACL列表:
ACL's step is 5
 rule 0 permit ip source 3.3.3.0 0.0.0.255 destination 2.2.2.0 0.0.0.255
ACL's step is 5
 rule 0 deny ip source 3.3.3.0 0.0.0.255 destination 2.2.2.0 0.0.0.255
 rule 1 deny ip source 3.3.3.0 0.0.0.255 destination 1.1.1.0 0.0.0.255
 rule 2 permit ip
3.2关键配置:
 ip address 20.0.0.1 255.255.255.0
 source 3.3.3.3
 destination 2.2.2.2
ipsec policy RT3 1 isakmp
 transform-set 1
 security acl 3001
 ike-profile RT3
ike profile RT3
 keychain RT3
 local-identity address 3.3.3.3
 proposal 1
ike proposal 1
ike keychain RT3
 pre-shared-key address 2.2.2.2 255.255.255.0 key cipher $c$3$Fx1hsMm+uamipkMpvCFJr6wGrLORTkkBbgESOQ==
interface LoopBack0
 ip address 192.168.3.10 255.255.255.0
 combo enable copper
 ip address 3.3.3.3 255.255.255.0
 nat outbound 3002
 ipsec apply policy RT3
 ip route-static 0.0.0.0 0 3.3.3.254
 ip route-static 192.168.1.0 24 Tunnel1
 ip route-static 192.168.2.0 24 Tunnel1
4.Internet
4.1关键配置:
 combo enable copper
 ip address 1.1.1.254 255.255.255.0
interface GigabitEthernet0/1
 combo enable copper
 ip address 3.3.3.254 255.255.255.0
interface GigabitEthernet0/2
 combo enable copper
 ip address 2.2.2.254 255.255.255.0
 ip route-static 192.168.1.0 24 1.1.1.1
 ip route-static 192.168.2.0 24 2.2.2.2
 ip route-static 192.168.3.0 24 3.3.3.3
5.测试
RT1内网终端(分部1)ping通RT2内网终端(总部)
RT1内网终端(分部1)ping通RT3内网终端(分部2)
RT2总部查看ike sa与ipsec sa相关信息:
 <RT2>dis ike sa
    Connection-ID   Local               Remote              Flag      DOI
    1               2.2.2.2             1.1.1.1             RD        IPsec
    2               2.2.2.2             3.3.3.3             RD        IPsec
Flags:
RD--READY RL--REPLACED FD-FADING RK-REKEY
<RT2>dis ipsec sa
Interface: GigabitEthernet0/0
  IPsec policy: RT2-RT1
  Sequence number: 1
  Mode: ISAKMP
    Tunnel id: 0
    Encapsulation mode: tunnel
    Perfect Forward Secrecy:
    Inside VPN:
    Extended Sequence Numbers enable: N
    Traffic Flow Confidentiality enable: N
    Transmitting entity: Responder
    Path MTU: 1444
    Tunnel:
        local  address: 2.2.2.2
        remote address: 1.1.1.1
    Flow:
        sour addr: 2.2.2.0/255.255.255.0  port: 0  protocol: ip
        dest addr: 1.1.1.0/255.255.255.0  port: 0  protocol: ip
    [Inbound ESP SAs]
      SPI: 3085965188 (0xb7f01784)
      Connection ID: 4294967296
      Transform set: ESP-ENCRYPT-3DES-CBC ESP-AUTH-MD5
      SA duration (kilobytes/sec): 1843200/3600
      SA remaining duration (kilobytes/sec): 1843197/3577
      Max received sequence-number: 19
      Anti-replay check enable: Y
      Anti-replay window size: 64
      UDP encapsulation used for NAT traversal: N
      Status: Active
    [Outbound ESP SAs]
      SPI: 3622549341 (0xd7ebb75d)
      Connection ID: 4294967297
      SA remaining duration (kilobytes/sec): 1843198/3577
      Max sent sequence-number: 18
      Status: Active
  Sequence number: 2
  Mode: ISAKMP
    Tunnel id: 1
    Inside VPN:
    Transmitting entity: Initiator
    Path MTU: 1444
    Tunnel:
        remote address: 3.3.3.3
    Flow:
        dest addr: 3.3.3.0/255.255.255.0  port: 0  protocol: ip
    [Inbound ESP SAs]
      SPI: 1899742260 (0x713bc434)
      Connection ID: 4294967298
      SA remaining duration (kilobytes/sec): 1843199/3587
      Max received sequence-number: 9
      Status: Active
    [Outbound ESP SAs]
      SPI: 62185102 (0x03b4de8e)
      Connection ID: 4294967299
      Max sent sequence-number: 9
      Status: Active
配置关键点
1.如果之前已经在外网口配置了 nat outbound,需要先undo掉
2.隧道两端注意加密算法和认证算法的统一
3.注意创建相关正确的ACL,把IPSec感兴趣流从NAT转换的数据deny掉,防止IPSec数据流被NAT优先转换
4.ipsec policy RT2中创建序列号为1和2分别用于目的为分部1和分部2的策略
