Print
知
802.1X+MAC认证接入后5s内进入guest vlan
2024-08-29 发表
问题描述
交换机上配置了802.1X+MAC认证+guest vlan:
 dot1x
 dot1x authentication-method eap
 dot1x quiet-period
 dot1x timer quiet-period 10
 dot1x timer tx-period 5
 mac-authentication
 mac-authentication timer quiet 1
 mac-authentication user-name-format mac-address with-hyphen uppercase
 dot1x
 undo dot1x handshake
 dot1x mandatory-domain imc_dot1x
 undo dot1x multicast-trigger
 dot1x unicast-trigger
 dot1x timer reauth-period 60
 mac-authentication
 mac-authentication carry user-ip
 mac-authentication domain imc_dot1x
 mac-authentication timer auth-delay 10
 mac-authentication guest-vlan 450
 undo mac-authentication offline-detect enable
测试认证终端接入认证到进入guest vlan需要花30s以上,想要实现接入后进入guest vlan的时间在5s内。
过程分析
收集debugging dot1x all、debugging mac-authentication all、debugging radius all
从debug看整个流程都是正常的:
*Jul  3 02:08:19:982 2024 S5130 DOT1X/7/EVENT: Processing new mac event: UserMAC=****.****.****.****, VLANID=450, Interface=GigabitEthernet1/0/2.
====1x处理newmac;
*Jul  3 02:08:31:993 2024 S5130 MACA/7/EVENT: Processing MAC authentication delay: UserMAC=****.****.****.****, VLANID=450, Interface=GigabitEthernet1/0/2.
====1x 客户端2次没有应答,总共10秒左右超时,转mac-auth;macauth添加延迟表;
*Jul  3 02:08:42:402 2024 S5130 MACA/7/EVENT: Authentication delay timer expired: UserMAC=****.****.****.****, VLANID=450, Interface=GigabitEthernet1/0/2.
====在10秒后,开始触发macauth;
*Jul  3 02:08:42:403 2024 S5130 MACA/7/EVENT: Notified PortSec of new MAC processing result 3: UserMAC=****.****.****.****, VLANID=450, Interface=GigabitEthernet1/0/2.
====但认证直接结束,看配置有mac-authentication carry user-ip, 分析是由于驱动上报newmac的ip为0被拦住了
*Jul  3 02:08:44:628 2024 S5130 DOT1X/7/EVENT: Processing new mac event: UserMAC=****.****.****.****, VLANID=450, Interface=GigabitEthernet1/0/2.
====然后还是上面这个逻辑,1x收到newmac在重新处理,再转macauth, 等macauth延迟认证超时,再触发macauth,但这回真正触发了macauth,即new mac报的ip非0,然后认证失败加gvlan.
发现按照目前的配置是需要等待802.1X超时,进入MAC认证,MAC认证失败后才进入到guest vlan中。
查询配置发现可以配置802.1X的guest vlan,实现触发802.1X认证就进入guest vlan。
更改后实测在接入后的两秒内可以进入guest vlan:
%Jul  4 06:22:41:807 2024 S5130 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/0/2 changed to up.
*Jul  4 06:22:42:746 2024 S5130 DOT1X/7/EVENT: Processing new mac event: UserMAC=****.****.****.****, VLANID=450, Interface=GigabitEthernet1/0/2.
*Jul  4 06:22:42:811 2024 S5130 DOT1X/7/EVENT: Started the user aging timer in the guest VLAN: Length=1000(s), UserMAC=****.****.****.****, VLANID=450, Interface=GigabitEthernet1/0/2.
解决方法
更改配置为:
 dot1x
 dot1x guest-vlan 450
 mac-authentication
 mac-authentication guest-vlan auth-period 5
