Print
知
AC+AP二层注册典型组网配置案例(本地转发)
2024-09-08 发表
组网及说明
组网说明:
本案例采用H3C HCL模拟器的AC和AP实现AC+AP的集中转发组网,其中VLAN 10为管理VLAN,VLAN 20为业务VLAN。
VLAN 10:192.168.10.0/24
VLAN 20:192.168.20.0/24
配置思路:
1、在SW1配置VLAN 10和VLAN 20的IP,并启用DHCP功能。
2、配置SW1与AP、AC的互联接口。
3、在AC内配置AP上线的基本设置。
4、在AC内配置服务模板、射频接口。
特别说明:开局前,先收集AP的序列号,一般在AP的表面有,或者登录AP,使用dis device manunifo命令查看。
配置步骤
(1)SW1
<H3C>sys
[H3C]sysname SW1
[SW1]vlan 10
[SW1-vlan10]quit
[SW1]vlan 20
[SW1-vlan20]quit
[SW1]int vlan 10
[SW1-Vlan-interface10]ip address 192.168.10.1 24
[SW1-Vlan-interface10]quit
[SW1]int vlan 20
[SW1-Vlan-interface20]ip address 192.168.20.1 24
[SW1-Vlan-interface20]quit
[SW1]dhcp enable
[SW1]dhcp server ip-pool vlan10
[SW1-dhcp-pool-vlan10]network 192.168.10.0 mask 255.255.255.0
[SW1-dhcp-pool-vlan10]gateway-list 192.168.10.1
[SW1-dhcp-pool-vlan10]option 43 ip-address 192.168.10.1
[SW1-dhcp-pool-vlan10]quit
[SW1]dhcp server ip-pool vlan20
[SW1-dhcp-pool-vlan20]network 192.168.20.0 mask 255.255.255.0
[SW1-dhcp-pool-vlan20]gateway-list 192.168.20.1
[SW1-dhcp-pool-vlan20]dns-list 114.114.114.144
[SW1-dhcp-pool-vlan20]quit
[SW1]int gi 1/0/1
[SW1-GigabitEthernet1/0/1]po li tr
[SW1-GigabitEthernet1/0/1]undo po tr pe vlan 1
[SW1-GigabitEthernet1/0/1]po tr pe vlan 10 20
[SW1-GigabitEthernet1/0/1]quit
[SW1]int gi 1/0/2
[SW1-GigabitEthernet1/0/2]po li acc
[SW1-GigabitEthernet1/0/2]po acc vlan 10
[SW1-GigabitEthernet1/0/2]quit
[SW1]ip route-static 0.0.0.0 0.0.0.0 192.168.10.100
[SW1]dhcp server forbidden-ip 192.168.10.100
(2)AC1
<H3C>sys
[H3C]sysname AC1
[AC1]vlan 10
[AC1-vlan10]quit
[AC1]vlan 20
[AC1-vlan20]quit
[AC1]int vlan 10
[AC1-Vlan-interface10]ip address 192.168.10.100 24
[AC1-Vlan-interface10]quit
[AC1]ip route-static 0.0.0.0 0.0.0.0 192.168.10.1
[AC1]int gi 1/0/1
[AC1-GigabitEthernet1/0/1]po li tr
[AC1-GigabitEthernet1/0/1]undo po tr pe vlan 1
[AC1-GigabitEthernet1/0/1]po tr pe vlan 10 20
[AC1-GigabitEthernet1/0/1]quit
[AC1]wlan auto-ap enable
[AC1]wlan auto-persistent enable
[AC1]wlan global-configuration
[AC1-wlan-global-configuration]firmware-upgrade disable
[AC1-wlan-global-configuration]quit
[AC1]wlan service-template weijianing
[AC1-wlan-st-weijianing]ssid weijianing
[AC1-wlan-st-weijianing]vlan 20
[AC1-wlan-st-weijianing]service-template enable
[AC1-wlan-st-weijianing]client forwarding-location ac
[AC1-wlan-st-weijianing]quit
[AC1]wlan rename-ap ac57-e4c7-0300 AP1 //修改AP名字
[AC1]wlan ap AP1 model WA6320-HCL
[AC1-wlan-ap-AP1]vlan 10
[AC1-wlan-ap-AP1-vlan10]quit
[AC1-wlan-ap-AP1]vlan 20
[AC1-wlan-ap-AP1-vlan20]quit
[AC1-wlan-ap-AP1]radio 1
[AC1-wlan-ap-AP1-radio-1]radio enable
[AC1-wlan-ap-AP1-radio-1]service-template weijianing
[AC1-wlan-ap-AP1-radio-1]quit
[AC1-wlan-ap-AP1]radio 2
[AC1-wlan-ap-AP1-radio-2]radio enable
[AC1-wlan-ap-AP1-radio-2]servi
[AC1-wlan-ap-AP1-radio-2]service-template weijianing
[AC1-wlan-ap-AP1-radio-2]quit
[AC1-wlan-ap-AP1]quit
查看AP上线的情况,发现AP已上线。
加入一台手机,并启动。
选中手机,右键“配置”
选中SSID信号源,并连接。
在DHCP区域点击“启用”
手机能获取到IP地址
同时手机能跨网段PING通。
在AC内能看到手机注册上线的信息。
至此,AC+AP二层注册典型组网配置案例(集中转发)已完成!
