Print
知
AC+AP跨三层注册典型组网配置案例(本地转发)
2024-09-10 发表
组网及说明
组网说明:
本案例采用H3C HCL模拟器的AC+AP模拟跨三层注册,在本案例中,DHCP服务器放置在AC1上,AC1与MSW通过配置静态路由,AP通过跨三层网络在AC上注册上线。
特别说明:
1、DHCP服务器放置在AC1。
2、开局前先收集AP的序列号,在AP表面可以看到,或者命令行dis device manunifo命令查看。
配置思路:
1、按照网络拓扑图配置VLAN和IP地址。
2、配置MSW与AC1的三层互联和默认路由协议。
3、在AC1配置AP的注册上线和服务模板、射频接口。
4、AC1开启WEB功能。
5、编写map文件并在上传到AC1内下发给AP。
配置步骤
(1)SW1
<H3C>sys
[H3C]sysname SW1
[SW1]vlan 10
[SW1-vlan10]quit
[SW1]vlan 20
[SW1-vlan20]quit
[SW1]int gi 1/0/1
[SW1-GigabitEthernet1/0/1]po li tr
[SW1-GigabitEthernet1/0/1]undo po tr pe vlan 1
[SW1-GigabitEthernet1/0/1]po tr pe vlan 10 20
[SW1-GigabitEthernet1/0/1]quit
[SW1]int gi 1/0/2
[SW1-GigabitEthernet1/0/2]po li tr
[SW1-GigabitEthernet1/0/2]undo po tr pe vlan 1
[SW1-GigabitEthernet1/0/2]po tr pe vlan 10 20
[SW1-GigabitEthernet1/0/2]port trunk pvid vlan 10
[SW1-GigabitEthernet1/0/2]quit
[SW1]save force
[SW1]
(2)MSW
<H3C>sys
[H3C]sysname MSW
[MSW]vlan 10
[MSW-vlan10]quit
[MSW]vlan 20
[MSW-vlan20]quit
[MSW]int gi 1/0/1
[MSW-GigabitEthernet1/0/1]po li tr
[MSW-GigabitEthernet1/0/1]undo po tr pe vlan 1
[MSW-GigabitEthernet1/0/1]po tr pe vlan 10 20
[MSW-GigabitEthernet1/0/1]quit
[MSW]dhcp enable
[MSW]int vlan 10
[MSW-Vlan-interface10]ip address 192.168.10.1 24
[MSW-Vlan-interface10]dhcp relay server-address 10.0.0.2
[MSW-Vlan-interface10]dhcp select relay
[MSW-Vlan-interface10]quit
[MSW]int vlan 20
[MSW-Vlan-interface20]ip address 192.168.20.1 24
[MSW-Vlan-interface20]dhcp relay server-address 10.0.0.2
[MSW-Vlan-interface20]dhcp select relay
[MSW-Vlan-interface20]quit
[MSW]int LoopBack 0
[MSW-LoopBack0]ip address 1.1.1.1 32
[MSW-LoopBack0]quit
[MSW]ip route-static 0.0.0.0 0.0.0.0 10.0.0.2
[MSW]int gi 1/0/2
[MSW-GigabitEthernet1/0/2]port link-mode route
[MSW-GigabitEthernet1/0/2]ip address 10.0.0.1 30
[MSW-GigabitEthernet1/0/2]quit
[MSW]save force
[MSW]
(3)AC1
<H3C>sys
[H3C]sysname AC1
[AC1]int gi 1/0/2
[AC1-GigabitEthernet1/0/2]port link-mode route
[AC1-GigabitEthernet1/0/2]ip address 10.0.0.2 30
[AC1-GigabitEthernet1/0/2]quit
[AC1]int loopback 0
[AC1-LoopBack0]ip address 2.2.2.2 32
[AC1-LoopBack0]quit
[AC1]dhcp enable
[AC1]dhcp server ip-pool vlan10
[AC1-dhcp-pool-vlan10]network 192.168.10.0 mask 255.255.255.0
[AC1-dhcp-pool-vlan10]gateway-list 192.168.10.1
[AC1-dhcp-pool-vlan10]option 138 ip-address 10.0.0.2
[AC1-dhcp-pool-vlan10]quit
[AC1]dhcp server ip-pool vlan20
[AC1-dhcp-pool-vlan20]network 192.168.20.0 mask 255.255.255.0
[AC1-dhcp-pool-vlan20]gateway-list 192.168.20.1
[AC1-dhcp-pool-vlan20]dns-list 114.114.114.114
[AC1-dhcp-pool-vlan20]quit
[AC1]ip route-static 0.0.0.0 0.0.0.0 10.0.0.1
[AC1]wlan auto-ap enable
[AC1]wlan auto-persistent enable
[AC1]wlan global-configuration
[AC1-wlan-global-configuration]firmware-upgrade disable
[AC1-wlan-global-configuration]quit
[AC1]acl number 3000
[AC1-acl-ipv4-adv-3000]rule 10 permit udp destination-port eq bootps
[AC1-acl-ipv4-adv-3000]rule 20 permit udp destination-port eq bootpc
[AC1-acl-ipv4-adv-3000]quit
[AC1]vlan 10
[AC1-vlan10]quit
[AC1]vlan 20
[AC1-vlan20]quit
[AC1]wlan forwarding-policy weijianing
[AC1-wlan-fp-weijianing]classifier acl 3000 behavior remote
[AC1-wlan-fp-weijianing]quit
[AC1]wlan service-template weijianing
[AC1-wlan-st-weijianing]ssid weijianing
[AC1-wlan-st-weijianing]client forwarding-location ap
[AC1-wlan-st-weijianing]vlan 20
[AC1-wlan-st-weijianing]client forwarding-policy enable
[AC1-wlan-st-weijianing]client forwarding-policy-name weijianing
[AC1-wlan-st-weijianing]service-template enable
[AC1-wlan-st-weijianing]quit
[AC1]wlan ap AP1 model WA6320-HCL
[AC1-wlan-ap-AP1]serial-id H3C_b0-60-d6-d1-01-00
[AC1-wlan-ap-AP1]vlan 10
[AC1-wlan-ap-AP1-vlan10]quit
[AC1-wlan-ap-AP1]vlan 20
[AC1-wlan-ap-AP1-vlan20]quit
[AC1-wlan-ap-AP1]radio 1
[AC1-wlan-ap-AP1-radio-1]radio enable
[AC1-wlan-ap-AP1-radio-1]service-template weijianing
[AC1-wlan-ap-AP1-radio-1]quit
[AC1-wlan-ap-AP1]radio 2
[AC1-wlan-ap-AP1-radio-2]radio enable
[AC1-wlan-ap-AP1-radio-2]service-template weijianing
[AC1-wlan-ap-AP1-radio-2]quit
[AC1-wlan-ap-AP1]quit
[AC1]
在AC内能看到AP已上线。
(4)开启AC1的WEB功能,为后续下发map文件到AP奠定基础。
[AC1]ip http enable
[AC1]ip https enable
[AC1]local-user admin
[AC1-luser-manage-admin]password simple Aabc123456
[AC1-luser-manage-admin]service-type http https
[AC1-luser-manage-admin]authorization-attribute user-role network-admin
[AC1-luser-manage-admin]quit
[AC1]int gi 1/0/1
[AC1-GigabitEthernet1/0/1]port link-mode route
[AC1-GigabitEthernet1/0/1]ip address 192.168.1.10 24
[AC1-GigabitEthernet1/0/1]quit
[AC1]
输入用户名、密码后点击“登录”进入到AC1的WEB主界面。
(5)编写map文件脚本,通过AC1的WEB界面下发到AP。
回到AC1的WEB主界面。
点击“无线配置-“AP管理“
点击右边相应AP的修改按钮
往下拉,到MAP文件这里
选择MAP文件
再往下拉,点击“确定“
点击右上角的“保存”
点击“是”
(6)测试无线接入
添加手机进来,并启动
选中手机,右键点击“配置”
打开WIFI
选择相应的SSID,并点击连接的按钮。
手机能连接上无线,并能获取到IP地址。
手机能跨网段PING通。
在AC1能查看到手机接入的信息。
至此,AC+AP跨三层注册典型组网配置案例(本地转发)已完成!
